Question about Samsung Televison & Video
My samsung smart tv screen went black, then came up with the image showing to connect the tv to the samsung black box by cable- this was already connected. I have updated batteries in remote
Posted by Nicky Todd on
    Top Expert:
  • Samsung Master
  • 76,625 Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Posted on Mar 08, 2020
5 Related Answers
Anonymous
  • 119 Answers
SOURCE: hi denon to cable box to samsung lcd
Unless you are having res. issues you can use component / optical / coaxial cables to connect all your devices to your denon and from your denon to your tv using component cables also
Posted on Feb 25, 2009
Anonymous
  • 37 Answers
SOURCE: No video with HDMI port
try 2 things, first use the rgb cables or video (yellow) cable and plug it into the tv using one of the imports..(vid 1,2,3 etc...) and see if that works. then check to see if you get a picture by not using the cable box, by pass it and connect it connect it in the uhv channel. also make sure you have it on the right input of the tv (meaning scroll through the input button on your remote to find the picture...i've done this a million times). still no picture try your dvd player input and if you have a vhs input see if that works. if it is the hdmi input...to be honest it's expensive and a pain to replace...
Posted on Mar 12, 2009
Anonymous
  • 3 Answers
SOURCE: The screen shows ''Weak Signal'' and no picture.
Mine did the same thing once. I think all I did was hit the setup on the remote, and let it run back through all the channels and then it worked just fine.
I hope this works for you.
Posted on Mar 21, 2009
Anonymous
  • 541 Answers
SOURCE: Samsung plasma R4272, sound, but no image on
Sounds like an X or Y drive board. They are the heart beat for driving the plasma display. Without them both you won't see anything.
Posted on Oct 13, 2009
key-kun
Karl Roche
  • 84 Answers
SOURCE: SEGA MEGADRIVE
dont know how many times ive said this but
GET AN OLDER TV
it saves all that time you use trying to hook it up to a new one..it doesnt even have to be that old just not a plasma or HD tv, its much MUCH easyer and saves lots of time, and mabie even money
Posted on May 02, 2010
2answers
What is wrong with my Samsung TV? Black screen.
If you wish to get some details; visit the site linked here. Pull up older posts.
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
{View the site in web view or by a desktop to see the search box. Mobile view has no search box.}
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
2answers
How do I fix my Samsung 40 LED TV that has sound but no picture?
When repairing LED TV Back light assembly you need to contact expert person because lifting of LCD TV panel is very dangerous for non technical person. Be careful
Sony flat-screen bravia tv picture goes black but keeps playing audio when playing Netflix or DVDs.
your dvd player needs its own connection as does netflix and cable,get a new hdmi cable for each
My screen turned blue and I can't change it back.
Try unplugging it from the wall outlet. Press the power button once to release any stored power. Plug it back into the wall outlet and turn power back on to see if this helps. If it is connected to a cable box make sure all the cables and connections are not loose. Check to see if the cable box is loose from the wall outlet.
Half a screen on my sharp aqous
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Television Won't Display Certain Cable Shows
Okay,i assumed this is what you have:
HD cable box with HDMI cable connection to the Samsung TV.
Listen careful as follow:
First you want to make sure using the same HD comcast box with HDMI connection for our Samsung TV as well as your other TV.Be sure the other TV do received the missing channels from the Samsung TV.You must be SURE you have tested both TVs with the same HDMI cable with the SAME HD cable box.
Now that you have confirmed the both TVS are using the same HD comcast box and the same HDMI cable but the connection that goes to the Samsung TV are missing some channels,at this point,use another HDMI connection behind your Samsung TV and see if you have the same problem.If so,please also try the left side of the HDMI connection and see if you could get the other channels.
Let me know!
solutiondoct
Televison & Video Logo
Demonic-2011
Demonic-2011
 Grubhead
Grubhead
