Question about Vision Televison & Video
Where is the AV button on the remote control for a Tevion vision 2368 portable dvd player
Posted by Natalie Jones on
Will
    Habit-Forming:
  • 91 Answers
Look for the source / input button on the remote to change the AV input.
where is the AV button on the remote control for a - 201507201500607_xok0lk7c-undefined-undefined-0.gif
Posted on Mar 27, 2020
5 Related Answers
Benimur
Louie Role
  • 6966 Answers
SOURCE: RE; Remote control TV/AV button doesn't work LXI series
Hi, Based on your post/description: 1. the TV is stuck to A/V; 2. you have two video sources - VHS & DVD (assuming both are external and both have A/V outputs with the VCR also with inputs); 3. you want to use either VHS & DVD, one at a time. You can do it the old fashion way, remove yellow, red, white RCA connectors from DVD and plug them at the outputs of the VHS when you want to use the VCR; or Connect the A/V outputs of the DVD to the inputs of the VCR, connect the outputs of the VCR to the A/V inputs of the LXI TV. Hopes this give you an idea. Post back how things are or should you need further information. Good luck and kind regards.
Posted on Aug 24, 2007
Anonymous
SOURCE: Tevion 19 LCD TV Model Number 1961HDT
eh, that should be 0871 663 1540
Posted on Jun 25, 2008
Anonymous
SOURCE: Diamond Vision DVD Player 803-04
call number of back of manuel and they can sent you one for 12. If you need number you can message me or look it up,
Posted on Sep 25, 2008
Kiri Amarakoon
  • 290 Answers
SOURCE: connected DVD player to Sanyo DS27930 TV via input
According the manual for this TV the remote control has an input button, it is left of the power button. Make sure that the remote mode slected for TV not VCR or DVD and press input button to make a selction, make sure that the power to the DVD player is on. If yours is different try stepping through the channels buttons, some TVs input is selected through the channel buttons.
Posted on Jan 02, 2010
Anonymous
SOURCE: missing portable dvd player remote. need code
In the book with the new remote will be all the codes for a bunch of different brands. Try all the codes under your brands selection. If non of them work, atleast you tried. You can always return the remote.
Posted on May 04, 2010
Tip
Tevion DVD-200 VCD Fix
Tevion DVD-200 DVD Player VCD Playback Fix
Would you like to unlock your Tevion DVD-200 DVD Player to play VCD's?
Follow these steps to unlock your Tevion DVD-200 DVD Player:
  1. Press the Open button on your remote control to open the drive tray
  2. Place an audio CD in the drive tray
  3. Press the Open button on your remote control to close the drive tray
  4. Press the Menu button on your remote control
  5. Press the 1 button on your remote control
  6. Press the Index (1-All) button on your remote control
  7. Press the Open button on your remote control
  8. Press the 1 button on your remote control
Your Tevion DVD-200 DVD Player can now play VCD's.
I hope that helps.
_____________________________________
Tevion DVD-200 Region Free Fix
on Apr 25, 2010 | Televison & Video
Tip
Tevion DVD-200 Region Free Fix Would you like to unlock your Tevion DVD-200...
Would you like to unlock your Tevion DVD-200 DVD Player to Region Free?
  1. Press the Menu button on your remote control.
  2. Press the 1 button on your remote control.
  3. Press the 6 button on your remote control.
  4. Press the 7 button on your remote control.
  5. Press 1 for Region 1, 2 for Region 2, and so on, or alternatively press the Mute button on your remote control for All Regions.
Your Tevion DVD-200 DVD Player is now Region Free.
I hope that helps.
_______________________________________
Can you pls tell me if your remote will work on a Tevion vision DVD player
this site does not sell ,issue or have remotes for any thing
contact the manufacturer for the answers that you seek
May 19, 2015 | Televison & Video
I need hack to provide Multiregion code for Tevion MD 2744, which is a DVD/VCR Combo from 2003.
Press the Menu button on your remote control then, 1, 6, 7, xm where x is the region number, or mute for all regions
This is the only code I have for Tevion dvd players, its for Tevion DVD-200, Tevion DVD-2001, but may work on yours.
May 15, 2010 | Televison & Video
Cant use scart socket
Press the "TV/AV/PC" button to display the choice of input sources, move to the required choice (SCART in your case) using the channel up/down buttons, then press the volume + or - button to selectyour choice.
Feb 18, 2010 | Televison & Video
I have a Tevion (Tev 8400) from Aldis that hardly plays any DVDs. How can I unlock this? I've searched and other models of Tevion require pressing the mute button in the instructions, but my remote for...
Maybe what you could try is getting a one for all remote control with a mute button on it. This may make the DVD play if you say that some other models work this way.
Nov 26, 2009 | JVC AV-27230 27" TV
Want to unlock my TEVION portable car dvd player and make it regine free
Tevion 81771 Portable DVD Player.
1) open the tray door
2) using the remote, press 9 7 3 5 (you will then see a hidden menu)
3) Choose the region 0 for region free
simple
Thanks thow
Aug 24, 2008 | Televison & Video
Unlock region codes for portable dvd player - panasonic DVD LS80
1. Press the Menu button on your remote control 2. Press the 5 button on your remote control
3. Press the 7 button on your remote control
4. Press the 5 button on your remote control
5. Press the 3 button on your remote control
6. Press the 8 button on your remote control
7. The currently selected region will be indicated on the TV.
8. Press the 1 button on your remote control for region 1, the 2 button for region 2, and so on, or the 9 button for multi-region playback
9. Press the Menu button on your remote control
10. Press the Menu button on your remote control
Tested with Region 1 DVD's on my UK player (Region 2 bought from Comet)
Aug 04, 2008 | Car Audio & Video
Diamond Vision TV/Remote
SOLUTION: I had the same problem with a Diamondvision DTV3913. After trying many universal remote controls, I found one that worked. The RCA universal remote CRCR3273 / CRCR3373 (also referred to as RCR3273 / RCR3373) was the answer. It has 3 codes (1232, 1233,1234) for DiamondVision TVs and the first one worked. It gives me all the control I needed including the hard to get ones like input selection, main setup menu etc. It also has codes for DiamondVision DVD players and VCRs. I see it at BestBuy for $8.
Jan 10, 2008 | Yahoo Diamond Vision DVDC803-04 DVD Player
Televison & Video Logo
53 people viewed this question
Top Vision Televison & Video Experts
Marvin
Marvin
ray gallant
Are you a Vision Televison and Video Expert? Answer questions, earn points and help others
