I find you can use a 12 volt laptop charger, it has the same 5.5mm tip, it worked fine on a stick light I once had it should work fine with the vector brand, if the LED lights up you'll be able to recharge from across the room
Order direct from the Distributor
4140 SW 28TH WAY, FT. LAUDERDALE, FL 33312
TEL 954-584-4446 • FAX 954-584-5556
TOLL FREE: 866-584-5504
WWW.VECTORMGF.COM
Table of Contents
https://www.manualslib.com/manual/587582/Vector-Mega-Sport-Spot-Vec139.html#manual
Go shopping where you got it
SOURCE: Vector Sport Spot 1,000,000 candle power spotlight
6 Volts, here is info from site.
VEC127Y
VECTOR SPORT SPOT 1 MILLION CANDLE POWER CORDLESS-RECHARGEABLE SPOTLIGHT
SOURCE: Vector Super Sport Spot VEC127Y replacement battery
I need a new power supply for my Vector Spotlight, Model VEC127Y. Any suggestions as to where one can be purchased?
John [email protected]
SOURCE: how do i find charger for cyclops 15 million candl...
INPUT: 120VAC 60Hz 18W
OUTPUT 12VDC 1A.
This is the spec for the 18 million thor cyclops which i presume will be the same for the 15 million.
Red light on torch flashes while charging. As soon as full charge is done red light stays lit.
SOURCE: looking for replacement parts for vector spot light
In March, 2006, Black & Decker purchased Vector Products, Inc. Since the acquisition, Black & Decker has assumed the manufacturing of all Vector products. For customer service and warranty information for Vector products, please contact Black & Decker Customer Service. www.blackanddecker.com/CustomerCenter/Default.aspx
I had one of them awhile back, I used a 12 volt laptop charger, polarity should be the same, if the red LED LIGHTS up you are set to charge it from across the room
