Question about Refrigerators
The compressor is self contained in a sealed enclosure. The noise means that the anchors inside the enclosure have broken. This does not affect the performance or life of the whole unit but it can be annoying. There is nothing you yourself can do about it and it would require the compressor assembly to be replaced. It would be better to get a new appliance.
Posted on Jan 31, 2020
Actually Excellent. I'm also an expert in this final fantasy brave exvius guide so I can understand your effort.
Posted on Feb 13, 2020
SOURCE: compressor makes loud noise when it shuts off
If you know that the compressor is making the noise, I really believe you need to prepair to replace the the air conditioner. If under warranty it would be wise to contact the dealer for options.
Posted on Oct 21, 2007
SOURCE: loud noise at end of spin cycle
The most common cause of the symptom you are describing is a bad drive block which has probably ruined your basket drive as well. Let me give a quick explination. The weight of the basket you put your clothes in is supported entirely in the center of the washer underneath your agitator. It rests on an aluminum block called your drive block. So that the basket will move back and forth while the washer agitates, there are two tabs on the drive block that lock your basket drive underneath in place. Once the drive block wears out or round down these tabs, the basket will raise slightly and "skip" across the top when the spin cyle is stopped. To verify this, you can check one of two things. First (and easiest) is put a heavy, large load in the washer, get it wet then spin it out. Once the washer reaches the maximum spin speed, open the lid. The washer should snap to a halt when functioning properly. What I belive you'll find is that even with the lid open, the basket will continue to spin. The other method to verify this is take the top of the agitator off. Next remove the bolt in the middle of the agitator and lift the agitator off. In the middle, you should find a large flat metal colored nut.In the middle of that nut, you should see two tabs across from one another. There should be two straight pieces of metal coming up from the bottom which have nice, straight sharp corners. Again, if I am correct, you will find they have been rounded off and there may even be shavings of metal visable.
To replace a basket drive and drive block, you will need to purchase the parts and also a specialty tool from removal and instalation. These will probably run you around 125-175. If you are interested in giving it a go, reply back to me and I will get you some step-by-stpe instructions typed up.
Posted on Jun 26, 2008
SOURCE: Sub-zero 650 makes loud gurgling sound
gurgling is not unusual and is caused exactly by fluid bubbling thro a pipe.
Posted on Nov 04, 2008
SOURCE: My new Kenmore window unit 76081 makes loud rattle
If it does not make the noise when the fan is ruunin you may ahve abroken sping in the compressor. Make sure you Window unit is level. If not the compressor will knock on the inside. Rusty
Posted on Jun 13, 2009
SOURCE: Whirlpool top freezer refrigerator- compressor makes a loud noise
The compressor is that black casing you see at the bottom of your refrigerator - inside this sealed case is the motor assembly which stits on 3 or 4 springs that act like a cushion - you have a little gap at the bottom where the lubricating oil is present. Your springs have likely worn out and when the compressor shuts off the assembly is banging against the rigid casing make that loud "klonk" or bang noise. It IS normal for compressor to make some faint "tick-tick-tick...tick.....tick" when shutting off, but loud banging, bell sounds, etc, means the assembly is banging on the case from the inside - you can indeed live with the noise, your compressor will function normally, probably for months, or even years - it can also keep wearing out and one day the noise might get very loud (like a very high humming noise) - There is NOTHING that can be fixed, you either pay $400+ to change the compressor or buy a new refrigerator - If you DO replace a compressor usually the replacement will be noisier - Keep a thermostat inside your refrigerator at all time to make sure your compressor is still keeping your refrigerator and freezer cool.
Posted on Aug 16, 2009
Oct 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Jun 12, 2009 | Kenmore 76081 Wall/Window Air Conditioner
Mar 20, 2009 | Refrigerators
Jan 20, 2009 | GE (GTS16BBS) Top Freezer Refrigerator
Dec 31, 2008 | Whirlpool Refrigerators
Dec 10, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Nov 30, 2008 | Kenmore 98702 Stacked Washer/Dryer
May 16, 2008 | Haier ESA3245 Thru-Wall/Window Air...
Feb 11, 2008 | Refrigerators
Dec 16, 2007 | Jenn-Air JCD2290HES Side by Side...
468 people viewed this question
