SOURCE: repair GE electric range
Door motor safety circuit you may have a faulty Electronic Range Control (ERC).. let us know what you find out.. krazytech
SOURCE: Re: GE Electric Range JBP67BD1WH Baking Element Problem
Before you replace the range, I'd try replacing the oven temp sensor (part number
WB21T10007 ) which is rather inexpensive. If I were able to get my hands on your range I'd first test to see if the control is sending 240 volts to the bake element. We know there is 240 to the range because the burners and broiler work, but is the control sending the full 240 to the bake element ? The only way for you to know this is to use a meter and test the voltage across the terminals of the bake element when in bake. Of course you should also test the bake element with power off and at least one terminal disconnected to see if you have about 20 ohms resistance across the terminals and no resistance from a terminal to the frame of the range. If not, you may need a new bake element (part number
WB44T10010 )
Let me know if I can be of further assistance. Thanks for using fixya.
If this helps, a fixya rating would be appreciated. Thanks.
SOURCE: My broiler works - but the oven does not - GE Dual Fuel range
Thanks for providing the full model number, which allows us to look up part numbers and see exploded views of your product.
Most likely the bake ignitor is bad (even if it still glows, it may not draw enough amperage to allow the gas safety valve to open). One way you can test this on your model is to swap out the broil ignitor for the bake ignitor, as they are the same part number on your model. (part number WB13T10045) The broiler is normally used much less than the oven, so the part does not fail very often on the broiler. You will have to take the cover off the floor of the oven, then the flame spreader, to reach the burner area. The ignitor is the rectangular part at the back, on the side of the burner. (only two wires to deal with) (By the way, for future reference, your model number ends is SS, as in stainless steel, not a 55)
SOURCE: GE Spectra XL44 Gas Kitchen Range - suddenly only top works
where do I find the pilot light?
SOURCE: Have xl44 GE Range /Oven--Oven and Broiler will
Date: 8/2/2010
I have a GE XL44 oven. It's about ten years old. Oven would not turn on, so I replaced the igniter. The igniter has to light to "tell" the gas to come on. The part was $80 here in Oklahoma and it was super simple fix.
Pull the oven out of it's place and unplug. You can shut off the gas if your buidler placed a shut off valve.
1. The oven door pulls off without tools (I wish I knew this when I cleaned the oven last year) just open the door about three inches and pull toward your chin.
2. Remove the lower storage drawer.
3. Then remove the racks.
4. Remove oven floor. The oven floor comes off with two screws in back, then lift it about an inch from the rear and you can pull the front up, clearing the lip. This is a good time to clean the ten year old food off the oven floor.
5. You will see the aluminum burner. The lower ignighter is attached to the burner. The screws to the ignighter are at an angle, dont try to remove them with out taking the burner out. To remove the lower burner, get on your side and look way in the back of the lower drawer area. Remove the two screws at the very back where the oven drawer goes. You will also unplug the two (2) wires and the then the whole burner will lift up and come out, then you can remove the ignighter screws. Take the ignighter off and take it to a appliance repair store and they will sell you a new igniter. You can look on-line as well.
The new part does not have the connectors like the original, Just cut the old wires in half and pig tail them to the new part. The new part will come with ceramic wire nuts. This whole install takes about an hour, and will save you a service call. It can seem like a hard fix, but once you dig into it, it's pretty easy. Everything goes back together in reverse. This would be a good time to change the light bulb while you are at it.
These are the same type of ignighters that are on everything these days, hot water heaters, furnaces and they are the most likely to go out since they are used quite a bit.
