SOURCE: Opening the CD player on a JVC UX-RC7 micro component system
Hello i had the same problem..maybe you have already fixed this but on the back you have the speakers and a pair of red and black switches, you have to put the wires into the holes on the TOP (not the sides) of the little box on the back...then once you have put the wires in flick the flaps UP :)
Sorry if you have already solved this problem but I hope it will come in use for someone.
Thanks
StepheeJay..x
SOURCE: CD CHANGER SAYS NO DISK.
Hi it could be one of two problems it could just be that the laser lense is dirty and you can by a lense cleaning cd for this but dint buy cheap ones as they tend not to work.
If after doing this the same message comes up then the chances are that the laser has failed and would need replacing. The problem with this is it is going to be expensive to get done as its impossible to do yourself as it needs special tools. As for the cost it would be cheaper to replace the whole unit than get the laser repaired.
Try the lense cleaner first as this is the cheapest option usually 9 out of 10 of the times this solves the problem.
Let me know how you get on and if you need further assistance ok..
SOURCE: jvc xl-f254 cd changer for home. 5 disc
Take the cover off and inspect for a jammed disc.
If there are no jammed discs you either have a broken belt or stripped gear.
You will have to take the unit apart and inspect, belts are commercially available from electronic stores and are a cheap easy fix!
Let me know if you need more details or guidance.
Cheers!
Kevin
SOURCE: how to unlock protected mode on a jvc 5 disc cd changer?
cheack the speaker wireing.if thats not the pro i sugg the repair shop your unit could have over heated.
