Question about Whistler Vehicle Parts & Accessories
How do i factory reset a whistler 1025 scanner. i think i messed it up and would like to strat all over from out the box.
Posted by Loni Bender on
How do i reset the memory on a uniden bearcat ubc360clt
To reset the scanner to factory defaults, turn off the scanner. Then, while holding down 2, 9, and HOLD, turn on the scanner. All scanner memory contents are erased.
Jan 05, 2015 | Uniden Radio Communications
Owners manual for whistler 1455
Most Whistlers you press and hold the POWER and QUIET buttons, while holding in these buttons; plug in the power cord. THe unit will beep twice indicating that it has been reset.
Apr 07, 2014 | Vehicle Parts & Accessories
Whistler xtr 690 voice need to be fix
If your unit is under 3 years old, contact Whistler at [email protected] for info on how to have warranty service performed. If its over 3 years old then you can call them at 800-531-0004 to order a speaker. This assumes that you tried a factory reset and that the auto quiet and City modes are off which basically leaves only the speaker as the possible problem.
Sep 28, 2011 | XTR-690 Radar Detector
Whistler 1783 detector shuts as soon as it goes thru start up mode. seems to get very hot to touch.
Try the factory reset - hold in the power and quiet buttons, while holding in these buttons plug in the power cord. Unit should beep twice. The unit will get warm to the touch.
Aug 22, 2011 | All Band Laser-radar Detector Radar...
Recently installed... "comm error" with
need to make sure that the radar antenna is plugged into the correct port on the display unit. Also make sure that the plugs are FULLY inserted, the water tightness of the plug can make it feel that its fully inserted but it may not be. For more info contact Whistler at 800-531-0004.
Jun 09, 2011 | Cruisader Radar Detector
Hi everyone, I have got a panasonic KX TES824 system. The guy before me changed the default password of the system. How do i reset the password? I tried opening the box and i see two buttons. one...
First the button clear position
anfter press hold reset 20sec
it will reset
after turn off PABX
move the button to open position
and strat the PABX
Please let me know this is helpful
Jan 06, 2011 | Panasonic KX-T7730 Corded Phone
My whistler 1778 radar detector wont pick up a signal? ive went past tons of cops but it never shows up. i have all my bands on. is there any settings i need to change or what?
Have you tried a factory reset? Hold in the power and quiet buttons at the same time. While holding in these buttons plug in the power cord. The unit should beep twice. Try that. If the unit still isn't right, call Whistler at 800-531-0004.
Aug 27, 2010 | DE-1778 Radar Detector
Need a speaker for Whistler Pro 73 . Do you remember the old Charlie Brown cartoons? Do you remember what the teacher in the class sounded like? Well thats what my radar detector sounds like. I think the...
call whistler 800-531-0004 i believe you can buy the factory one from them or pick up an 8 ohm mini speaker at an electrics store this may take some splicing as the ones from electronics store usually are not exact but you can make them work , just make sure you take the old one with you it is easier to match up at the store
Apr 08, 2010 | Pro-73 Radar Detector
I recently bought a used whistler pro 73. The unit looks to be like new but after a week of use I havent received any alerts. How do I test this unit to see if it is defective?
Perform a factory reset (hold the power and quiet buttons in, while hold in these buttons plug in the power cord. Unit should beep twice) and see if this corrects it. If not contact Whistler at 800-531-0004.
Jun 27, 2009 | Pro-73 Radar Detector
Vehicle Parts & Accessories Logo
132 people viewed this question
Top Whistler Vehicle Parts & Accessories Experts
Marvin
Marvin
ray gallant
Are you a Whistler Vehicle Part and Accessory Expert? Answer questions, earn points and help others
