Question about Video Cameras
I have an nv ds 60, play back was fine , then horizontal wide bands appeared 5 to 7 with square pixel colors in them. also there is no sound on all 10 tapes.
Posted by michael clayton on
abdul rauf
    Dedicated:
    Visited the website for 20 consecutive days.
  • Video Cameras Expert
  • 483 Answers
Head is weak, change it.
Posted on Feb 29, 2020
5 Related Answers
Anonymous
  • 1476 Answers
SOURCE: Video playback is distorted and has no sound
Usually head cleaner tapes do not do much more than wear the heads out and move the dirt around or in some cases if it is an old tape it may add dirt to the system!!! Someone needs to remove the cassette cover and clean the video drum, tape path, pinch roller and capstan with denatured alcohol. Do not use anything but 100% alcohol as anything else will have contaminates in it. The video head pole pieces are extremely small (we're talking microns) and can be plugged easily. Cleaning the tape guides, audio heads, erase head, capstan and pinch roller is pretty straight forward and the same as any audio deck. Using a lint free Q-tip (or special head cleaning sticks from electronic stores) dip in alcohol and remove any dirt etc from the pieces. Cleaning the video drum is a little trickier. Using the same kind of cleaning stick dipped in alcohol, gently wipe around the video drum assembly. Never, ever go up and down across the face of the head or you could break the video heads!! If you do not know the proper way to do this you should take it to a qualified tech or you could do more damage than good. If you clean your unit the way that I described it should be fine. On occasion I have had a unit with a clogged head that requires a different technique to clean but you would not be able to do this. If cleaning does not work you will need to take it to a repair shop for service. Good luck.
Posted on Jul 20, 2006
Anonymous
  • 934 Answers
SOURCE: picture limited to a single pixel horizontal line, sound fine
This is actuall quite a simple problem... What you have explained here is a loss of vertical deflection. By the symptoms you described, working now and not working it's most likely the the vertical IC an LA7847-E has probably become ring-cracked at the point where the pins are soldered to the pc board. Depending on how long it has been allowed to arc the IC may have failed also, but they are not terribly expensive or difficult to repair - at least not here in the shop. The main board has to be removed. Locate the vertical IC - it will be mounted to a metal heat sink and the IC will be stamped LA7847. Then turn the board over and inspect where the pins are soldered to the foil side of the board. One or more will look ring cracked or fractured all the way around the pin. At this point you have two options, carefully reflow solder over each pin and put it back together or replace the IC by de-soldering it and removing it from it's heatsink. remember to use a good heat sink grease when applying the new IC.. There should also be a couple of caps in pretty close proximity to that IC... One should be about 50v/100uf and in the shop here we test em all... You might also just replace that one for good measure - they're not expensive either... If any of this sounds too complicated take it to a reputable shop and pick it up in a day or two.. Job shouldn't be that expensive or time consuming. My record in the shop here for doing those is 15 in one day. Average cost for that set, we charge is under $100 if you bring it in and pick it up.. Hope this helps Bill If you're calling around to the repair shops you might just ask if they have that IC on-hand or if they will need to order it..
Posted on Jun 07, 2007
Anonymous
  • 73 Answers
SOURCE: Hi8 playback problem
your guides have come loose , probably - the digital sound will be next to go because the bottom edge of your tapes are being folded - open the cassette tape lid by pressing the small pin near one hinge and gently lifting the door - if there are any creases ? get the guides aligned ! to protect your library ; ( if there are no creases , try a sony d8 cleaning tape - once ! before getting a repair quote ) ;
Posted on Jul 29, 2007
Anonymous
SOURCE: 4-5 Grey Lines appearing in the Playback Mode when playing tape
I have the same problem happening and can't find a straight answer. Some posts are leading me to believe that it may be dirty heads, and that the camera needs cleaning.
Posted on Dec 08, 2007
Anonymous
  • 10 Answers
SOURCE: 5 Grey Horizontal Lines across the screen during play back and distorted sound.
Someone here recommended on another post to put the lense cap on & videotape the blackness in a quiet room for 5-10 mins. I tried this as a last resort & it worked. When I played back the tape, no more skipping or gray lines. I had 4-5 SOLID gray lines with skipping video & audio in between on every tape I put in. I think the person who helped me solve this said that it was a result of the tape alignment going off. My camera is a Canon zr80 digital camcorder. (Called Canon, they had me reset it & then recommended sending it in).
Posted on Nov 28, 2008
Grey spots black screen
could be a dead pixel you can some times get them back by tapping the pixel with the stylus off a nintendo ds have the tv on a white screen when doing it so you can see when it has worked. need to tap just the pixel square do it to each pixel.
1helpful
Hello, I bought an LG 47LH50 HDTV exactly 1 1/2 years ago. Black horizontal lines suddenly appeared one night after getting home from work. Over the past two weeks I've seen it go from 3 lines, to 4...
Hi, I purchased the same model in November 2009. About 2 weeks ago a single horizontal line appeared. Each day another appeared until today when the video went out. Now it displays bands of vertical colored lines like a pastel colored rainbow. Did you find a solution to the problem?
1helpful
Wide vertical bands of color through the viewing area. The sound is fine
One of your "X" buffer boards is defective. In Panasonic plasma tv's they are located at the bootom of the set and connect directly to the plasma diplay panel via a thin ribbon cable. The board you want to replace will be directly in line with the discolored vertival line in the picture. The part number is on the circuit board and usualy starts with "tnp..." or "txp..."
15helpful
5answers
The xbox 360 screen is messing up and pixelating
After a lot of calls and finally a return to MS for RMA, MS checked and agreed to change the motherboard... it seems quite common issue (full HD seems to be a stretch for the console for games or for movies...). So the only way is to return it for repair....
Playback Problems
heads may be worn ( LP suffers , more ) but try cleaning cassette , first ;
2answers
Grey bands horitontally in LCD screen
Hello, please try to clean the head with mini DV tape cleaning cassette. Best regards. Arpi
Black bands and skipping in playback
Thank You Guest, this this solution is helpful, I clean the head with alcohol and the problem is solved.
And thanks for FixYa for the technical support.
2helpful
2answers
Wide Horizontal lines on playback
Wide bands in the playback video indicate a clogged or defective video head assembly. If your cleaning tape appears to resolve the problem, the heads are getting contaminated. I would not use the same tape in this unit. Try cleaning the heads and then use a brand new tape to avoid clogging the drum assy again. If this does not resolve the problem, the drum assembly will have to be replaced. Hope this helps. Joe Weibel customelectronics.org
Pixel color fade
You are about reade to have a scan ic failure.Try to get it to a repair center asap.Have them replace the top 2 scan ic's
Video Cameras Logo
Top Video Cameras Experts
Tony Parsons
Tony Parsons
Tom Chichester
Are you a Video Camera Expert? Answer questions, earn points and help others
