Question about Samsung Refrigerators
How do I replace a water tube from my Samsung SRS615DP fridge with water dispenser please?
Posted by Paul James on
David Spradling
    Top Expert:
  • Samsung Master
  • 10,974 Answers
Pull unit out and get new hose from store then follow tube from inside to water source
Posted on Feb 01, 2020
5 Related Answers
dcp2
Daniel Phillips
  • 63 Answers
SOURCE: Water leaks from tube at the bottom of fridge for water dispenser only
If it is a plastic compression fitting you can tighten each one a little(careful not to tighten them too much cause they can strip out) Use a small crescent wrench with a back up wrench.
Posted on Jan 28, 2008
Anonymous
  • 132 Answers
SOURCE: water dispenser inside fridge does not dispense water
Are the water inlet / outlet correctly fitted onto the filter ??
Sounds silly - but very easy mistake seen several times.
Is the water supply for the filter turned on . . remove hoses from filter to verify. - YOU WILL GET WET.
Posted on Aug 15, 2008
Anonymous
  • 750 Answers
SOURCE: Bad water & ice cube taste
Hello redwood City
Welcome
You said,
Your Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. You replaced the copper tubing which delivers the water to the fridge and that didn't help. You replaced the copper tubing again with plastic tubing...no better. Any suggestions? Your tap water doesn't taste this bad.You bought a Kenmore french door fridge with water dispenser in the door in July 2008. The fridge has a filter. A few weeks after the fridge came the water and ice started tasting really bad, unlike any bad water taste I have ever tasted. And your tap water is fine. The bad taste appears to be random. Sometimes you get a cup full of nasty water and sometimes it tastes fine.
First you must know you have a 1 year warranty and can have them come out to fix anything, no charge.If it persists. You will have to get tough and you , MUST INSIST THEY REPLACE YOUR FRIDGE
When installing the water line these were a part of the directions!
Did you do this before connecting the water line to your fridge?
"Place the free end of the tubing in a container or sink, and
turn ON the main water supply. Flush the tubing until water is
clear. Turn OFF the shutoff valve on the water pipe. Coil the
copper tubing."
Whirlpool remedy
Off-taste, odor or gray color in the ice
1.Are the plumbing connections new, causing discolored or
off-flavored ice? Discard the first few batches of ice.
2.Have the ice cubes been stored too long? Throw old ice
away and make a new supply.
3.Does the freezer and ice storage bin need to be cleaned?
See “Cleaning” or “Ice Maker and Storage Bin.”
4.Has food in the freezer or refrigerator been wrapped
properly? Use airtight, moisture-proof packaging to help
prevent odor transfer to stored food.
5.Does the water contain minerals (such as sulfur)? A filter
may need to be installed to remove the minerals.
6. Is there a water filter installed on the refrigerator? Gray or
dark discoloration in ice indicates that the water filtration
system needs additional flushing. Run additional water
through the water dispenser to flush the water filtration
system more thoroughly (at least 2 to 3 gal. [8 to 12 L] or 6 to
7 minutes initially). Discard discolored ice.
Let me know what works,
Thank You ,
HUUUM!!
Please remember to leave a rating.
Posted on Oct 12, 2008
Anonymous
SOURCE: Water Dispenser Drips
Had the same problem after replacing over seven water valves and installing a water regulator in the water line to the refrigerator with no help. Had to reduce the water pressure to about 27 pounds the reduce most of the drips. It drips an amount about the size of a quarter and when the water gets the coldest it stops the drip, but there is always a droplet at the end of the water disperser tube.
The problem is with water stored in the refrigerator side of the box. Water come in and does not leak. After the water gets colder it expands and oozes drips from the water dispenser. It is worse with the roll of tubing behind the crisper drawer on the bottom, because there is no room for expansion in the tubing. We replaced the tubing with and older style tank and it helped some, but not completely. The solution is 1. Try to buy a refrigerator with a tank instead of the roll of tubing in the bottom of the refrigerator side. 2. Don't use the water dispenser. 3. Reroute the tubing directly to the water dispenser and bypass going into the refrigerator, the water will not be as cold. 4. Avoid those built by Whirlpool.
Posted on Mar 07, 2009
aborcass
Ron Coons
  • 2651 Answers
SOURCE: I need to replace the water line tubing in the
the front dispensor panel can be removed by lookin under the panel you see too little spaces in which ti insert a screw driver,by pushing down on the top, you cantwist the screwdriver in the opening eleasing the tabs, and simply lifting off the top tabs, dependingon model you may need to un plug a wire or 2.. the tubing should be able to be removed be releasing the connector undeer the door and simply refeeding the new hose back into unit
Posted on Jan 27, 2010
How big is the reservoir for the water dispenser? Also, what is the normal temperature of the water being dispensed?
??? You never gave make or model and your mouth is that accurate to tell a 17 degree difference in water temp?
Jul 02, 2015 | Refrigerators
I have a very small dribble of water leaking from the bottom of the control panel on the freezer door. Is there a simple fix or do I need a technician? Unit is a SRS615DP.
Maybe and maybe not.
Page 9 of the user manual mentions a anti sweat heater that you can turn on or off.
Samsung SRS579NP User Manual Ice cold Water Dispenser
It maybe that the water line to the water dispenser is leaking
I am including a link to youtube videos about refrigerator water leaks but there is little about Samsung. Hopefully turning on the heater will solve your problem. At least one of the videos shows how to replace the tubing in a different brand of refrigerator.
samsung side by side water leak from freezer door YouTube
Sep 29, 2014 | Refrigerators
My Amana french door/bottom freezer is leaking water. Did the procedure with hot water the drain in back of the freezer, although it seemed clear of ice. That didn't help. The leaking stops when I...
Two possibilities:
1. A cracked plastic tube. These will leak whenever there's a call for water - either the chilled water dispenser, or re-filling the icemaker tray (two seperate tubes). Pay particular attention to anywhere the tubes are clamped to the chassis; anywhere they're routed near or under the refrigeration unit; and near the solenoid valve - especially if there's a tight loop in the tube there.
2. A bad (leaking) connection where one of the tubes exits the water valve. Again, these will leak whenever the valve is activated.
Those plastic tubes don't last forever. I've replaced many of them for the same symptoms. They're known to simply deteriorate with age.
Manuf's make good money selling replacement tubing kits.
Aug 15, 2011 | Amana AFB2534DE Bottom Freezer French Door...
Electrolux side by side door refrigerator. White
This can be pulled out of the door and replaced with new tubing.You may need to remove the front dispenser panel in order to get the tubing out of the dispenser.
Once you do that then you can pull the remove the tubing and replace it with new line.
Jan 01, 2011 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Whirlpool GR2FHTXVQ00 fridge. Water dispenser
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
You can thaw out the fill tube and replace the inlet valves.
Oct 13, 2009 | Freezers
Samsung fridge freezer fridge is registering 13 and not cold
YOU WILL HAVE TO THAW OUT THE FRIG SO THAT THE WATER WILL FLOW THROIUGH THE TUBING TO THE DISPENSER.
Feb 23, 2009 | Samsung RS2534 Side by Side Refrigerator
Water Dispenser Not Working
the water spout on the dispensor unscrews this is a clog issue take it off and then run water becarful this does have a spray effect all over but it allows water to flow
also there is the problem of the water tube up the door has kinked when closed this is a big deal with front fridge water the ice dispensors tube goes up the back
May 13, 2008 | Samsung RS2630SH Side by Side Refrigerator
Fridge is in lock mode
Please press the white wine key and interior lamp button together for 3 seconds.
Jan 09, 2008 | Refrigerators
Oct 04, 2007 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Gerry Harvey
Gerry Harvey
jasbo
jasbo
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
