Question about Icom Radio Communications
How to reset mmsi for icom mh/hf 801 - Icom Radio Communications
Posted by Khairuzz Aman on
2 Related Answers
Birchwood33
SOURCE: how to reset mmsi number Raymarine 215
This secret code is for the Raytheon / Raymarine RAY 220 VHF. It may work on other Raytheon/Raymarine radios also.
Here you go:
With the Power OFF, Press and HOLD the FUNC, 16/9 and DSC keys while you power ON. Do not release the keys until you hear the audio BEEP which means your done. Then reprogam your NMSI number as per the manual. Pretty easy, hey?
Posted on Nov 17, 2010
Microyacht
SOURCE: need to reset the mmsi
Did you ever solve this problem. I have just purchased a little Leisure 17-SL with a fairly new one of theses radios. I have the handbook and discover you can only program the MMSI once and then return to a dealer to clear it!
Many thanks
Steve http://www.withamweather.co.uk
Posted on Dec 16, 2010
Can I use an Icom AT-180 ATU with my ICOM IC-7300 HF radio
AT-180 ATU is not intended for IC-7300. Icom IC-7300 have a built-in tuner already. maybe you can use a special cable or interface to use the AT-180 on IC-7300.
Feb 18, 2018 | Icom Radio Communications
How to repair Icom IC-M700 HF transeiver?
Does it have an external speaker plugged in the back? If so try unplugging it see if the internal speaker works, if it doesnt have an external speaker plugged in try one, maybe the internal speaker went bad from moisture.
May 28, 2014 | Icom M700 Pro - IC AT-130 automatice tuner
My icom 706 mk2g transmits on VHF uhf but not on HF whats the possible problem
My icom 706mk2g does no give me hf power on the hf bands but on uhf is working wel.
On the s meter the last blok is turn on.
Reseiver is working wel.
Wat can it be?? Transistor Finals broken???
The two srfj?
May 19, 2013 | Icom IC-706MKIIG
How can i do a factory reset on an icom ic-706, basically i want to clean it all off and have it like it came out the factory, it this possible??
Hi Paul,
The best I can come up with is Try this: join yahoo group Specific to your radio Make/Model, the experts there will help you with useful info and you can download manuals, schematics and software, if available, for your radio and all this is free.
I hope I have been of assistance to you.
Regards,
Peter
Nov 29, 2012 | ICOM Informatique Icom IC-F21 16ch UHF...
Mmsi reset icom
You've not given much info here, we need not only the Make (Icom), but the Model No. as well to be able to assist you. Could you pls re-post all details of your radio, so that we can follow up on your query.
Cheers, [email protected] Team
Nov 21, 2012 | Radio Communications
Need to reset the mmsi
Many thanks
Dec 14, 2009 | Icom M302 VHF Radio
Radio Communications Logo
56 people viewed this question
Top Icom Radio Communications Experts
Perry Mellott
Perry Mellott
Robert McClure
Vincent G
Vincent G
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
