Question about VIA Computers & Internet
Hi internet. I am on Windows 10 version 1903 and I decided to install TOCA Race Driver 3 onto my PC. Upon installation, I clicked on the game, and it didn't initially load, so I started it as an administrator. Then I got a yes/no pop up from the game stating my computer needed to restart. After clicking yes, my PC got stuck in an endless cycle of Automatic Repair, so I disabled Automatic Repair via command prompt. Then when I restarted, it said that the driver verification (or something like that) of sfsync03.sys failed, so I then went back into command prompt, and I tried to locate and delete that file, only to see that it was not present in my x:\windows\system32\drivers folder (the drive is x because I am doing this through Windows 10's built-in recovery tool). So now I've started chkdsk /r, but I'm stumped and I need access to my computer. Please, kind internet passerby, do help me! Thank you, Orange.
Posted by Orange Juice on
Larry Ng
  • VIA Master
  • 6,019 Answers
My guess is this software is infected.
no source stated, URL
and you did not run VIRUSTOTAL.com on the install file first.
you will learn from this mistake.
1: only get games from maker or STEAM
2: run AV virustotal.com free on the installer.
3: set restore point in W10
4: load the game and pray.
or use , REvo uninstaller, and run it and pick Install the game. now it will remove it later if bad..by the roots.
Posted on Feb 04, 2020
4 Related Answers
Anonymous
  • 1605 Answers
SOURCE: Ethernet Drivers (slow internet access)?
the fastest speed is the slowest path on the network.
right click on the my network place.
right click on the NIC local connection
click on configuration at the right of the connect using (NIC)
second tab, "advanced" check the speed & duplex- it should be auto, but you can change it. do not recommend it.
check resources- make sure it has no conflect with any other device.
if that doesn't help. uninstall the NIC driver and try to find a older driver. Sometime that works better, don't ask me, but it works.
Posted on Oct 30, 2008
Anonymous
  • 240 Answers
SOURCE: Windows boot manager problem acer aspire 5920
Creating recovery discs After setting up the computer for the first time, be sure to create a set of recovery discs of the full factory image. the recovery discs are used to start up (boot) the computer and recover the operating system and software to factory settings in case of system instability or failure.
Posted on Jun 16, 2009
jasonmteat
Jason M Teat
  • 111 Answers
SOURCE: I have installed TOCA Race Driver 3 and when I
You may need to change the setting on the games desktop shortcut. "Right click" on the game icon, click on properties. Then click on the "compatibility" tab. Check the "Run this program as an administrator" Click appy then ok. The game should run.
Posted on Jan 28, 2010
engineerayo
OJO Emmanuel Ayodele
  • 169 Answers
SOURCE: i have life book E
the Operating System is faulty..
Reload the Operating system and your laptop will be back to life...
Enjoy..
Posted on Dec 21, 2010
How can i get toca 2 to work on win 7
Not sure which one it is your trying to get working toca2 or toca3
I cannot get toca2 working at all toca3 requires you to right click game icon once installed and set compatibility to windows xp and put a tick in run as administrator
Nov 28, 2013 | Codemasters TOCA Race Driver 3 for Windows
I downloaded toca race driver through torrent but all are mdf files how to install the files are mdf in winrar how to extract
Hi aditya374,
MDF files can be opened by DAEMON Tools & Alcohol 120%.
WinRar will NOT open or extract them.
Get them here:
ALCOHOL 120%
www.alcohol-soft.com/
DAEMON TOOLS
www.daemon-tools.cc/eng/downloads
Kind Regards :-)
If you found this solution helpful, please vote accordingly.
May 08, 2011 | Codemasters TOCA Race Driver 3 for Windows
Ive downloaded Toca Race driver 2 (about 2.8 gb). when i opened the rar file it ask for password for the encrypted file. please help
Smartkey RAR Password Recovery can help you remove the password if the file is legal to you. You can download the program from its official website and try its trial version.
Sep 26, 2010 | Codemasters ToCA Race Driver 2: The...
My Windows 7 PC crashed when I installed Toca Race Driver 3 and essentially restored itself without the game (although it did not delete the gamedat file). What do I need to do to successfully install TRD3...
I have done a little research on this and the only thing i can find is this hope it helps ;)
Ok. so i have heard that people have had a fare bit of trouble getting toca race driver to work on windows 7 but that starforce wont let you. well for thoughs of you i am here to help. lets get straight into it, first open device manager then click the view tab, then click on show hidden devices. then scroll down till you find the starforce driver, then uninstall it then come back to this page. then go to my computer then go to c drive/windows/system32/drivers. then look for a trio of files called sfdrv01.sys, sfhlp02.sys,sfsync02.sys and then delete them. the numbers may be different, e.g sfhlp03 instead of 02. but delete them all. then open run, then type regedit. then click the edit tab and click on find, searc for the phrases, sfdrv, sfhlp and sfsync. they will most likely all come up in the same area. delete them all, the actual folder is best. then download d3dx9_27.dll and place this in the folder c/windows/system not system32 just system. and thats it enjoy. any more questions just post your question here and ill get back tp you. and yea it is a boring process but its worth it. since ihepled you out can someone please give me a link for a recording software and ill upload to youtube and show you it running and what to do if you are lost with how to do this.
Aug 28, 2010 | Codemasters TOCA Race Driver 3 for Windows
I have installed TOCA Race Driver 3 and when I click 'play' a message says "To install the application, you must have administrator priviliges on your computer"...I am the administrator!!! Help!
Jan 19, 2010 | Codemasters TOCA Race Driver 3 for Windows
I enter the game, and when I want to enter World Tour or something else it gives me an error report(the with Don't Send)
you should check if on your system can run this game ,if yes just reinstal the latest driver of your video card.
Dec 15, 2009 | Codemasters TOCA Race Driver 3 for Windows
I bought Toca Race Driver 3
on the back. does it say compatible with mac?
Sep 04, 2009 | Codemasters ToCA Race Driver 2: The...
When i start Toca Race Driver 3 the videos are so
The only think I can think of is the dvd its self is bad and there could be some hairline scratch or dirt that you cant see, i'd try cleaning it and if that doesnt work, they might have sold you a bum disc. I hope i could help
Wayne
Jun 25, 2009 | Codemasters TOCA Race Driver 3 for Windows
Game will not start. Says there is a problem with rd3.exe and it has to close.
Hmmm try using different cracks, using cracks often help. Or it might be just that your graphics card can't play that game. I'll give u the link where u'll find the cracks, the no-cd ones are the cracks, good luck
http://www.spacetarget.com/games/pc_toca_race_driver_3.shtml
Nov 07, 2008 | Codemasters TOCA Race Driver 3 for Windows
Computers & Internet Logo
Top VIA Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
Atiq
Joe Goldman
Joe Goldman
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
