SOURCE: Sharp AR-M165, maintenance led and developer replacement leds on
It's the drum thats causing the lines to happen. Youre going to have to get that replaced before you can reset the counters.
If you get light copies, then the developer should be replaced.
SOURCE: Philips 42PF7220A/37 Chassis Number BP2.3U
I think its something on the picture frame board or on the line output board. I would sway to the line output simply because I think but not sure that error code is linked to the line output stage plus when you unplugged the cable the voltage seems within parameters. Good luck.
SOURCE: Philips 42PF7220A/37 April 2006. Chassis Number BP2.3U
Most likely the YSCAN UPPER board and/or YSCAN LOWER Board also gone. Your new YSUS board may damage again if you don't replace the bad YSCAN boards. Try to replace the three boards together and then to verify which boards are bad one by one. Good luck.
SOURCE: plasma tv has no picture but green led is on
Try unplugging the TV for a few minutes (discharges the ballast/ps) then plug in and attempt to power on. I have the 42P Vizio over two years old and ran into the same problem a few times. First thought was a power supply issue, but the unplugging trick worked. Good luck.
SOURCE: Screen on my Samsung LE32R87BD goes black for a
Contact Samsung . There is a software upgrade for this.
