Question about Maytag Washing Machines
How to byepass the lid lock in a Maytag washer top load
Posted by Tony Smith on
David Spradling
    Top Expert:
  • Maytag Master
  • 10,936 Answers
Jump the wires for testing then replace
Posted on Mar 08, 2020
5 Related Answers
Anonymous
  • 130 Answers
SOURCE: Maytag washer MAV551EEWW top load with loose tub
If the tub seal lets go water will weep into the tub bearing. This will rust the basket shaft and normally wreck the tub bearing. Once the bearings starts to get worn enough it usually gets very noisy. The tub bearing is pressed onto the outer back half of the tub shell assembly. Normally need to replace the inner basket/shaft assembly  and the outer shell with the tub bearing.
Sometimes the inner basket support will crack, this can give an clicking or banging noise as well.
Pictures of this job...
A sure indication was the brown junk/gookus leaking out if the rear bearing area and the belt has spewed it around in the drum that the rear bearing and seal was bad...
Picture1 - Picture2
The whole outer shell and basket come out to do this repair....what bad bearing and rusted shaft looked like...
Picture1 - Picture2 - Picture3
I had to remove the back panel. Undo the pump hose & water level hose, remove the 2 shocks, remove the motor, undo the front boot from the outer panel and remove the 2 springs to lift the whole assembly out from the back to work on it.
Picture1 ( boot pushed inside ) Help page1 - Help page2
Posted on May 07, 2009
Anonymous
  • 37 Answers
SOURCE: Maytag Washer lid switch
Ohm out the blue/ blk terminals on the sw (remove wire harnes first and notate wire color connection) with an ohmmeter-- Reading should be zero (closed lid position)
Then ohm the ylw and white sw terminals-- reading should be 0 as well.
If I am not mistaken this sw has a plunger that sticks out, if hte unit goes off balance this could push the plunger in. to reset- pull the plunger out
Lou
AFFORDABLE APPLIANCE REPAIR
(949) 855-0788
Posted on Jun 20, 2009
Anonymous
  • 572 Answers
SOURCE: The lid will not lock on my Whirlpool Cabrio
id change the door switch
Posted on Feb 06, 2010
kevin_getz
Kevin Getz
  • 1032 Answers
SOURCE: kenmore top loading washer locking lid switch bypass
Yes. Snip the wires at both sides of the switch. Then fuse the wires together with electrical tape. But before you do that...you state it's a 2011 model? It should still be under warranty.
Posted on May 18, 2012
jamesstoner
jamesstoner
SOURCE: want to disengage lid lock on maytag centennial
I had the same problem. The lid lock assembly is broken. If you are under warranty get it replaced. If not remove the top of the washer and take out the switch assembly. The 4 wires going in are Yellow, Red, White, and Blue. If you short the white and blue together, the washer thinks the lid is closed. If you short the red white and blue together the washer thinks the lid is closed and locked. The yellow is only there to activate the electromagnetic switch.
Disconnecting the switch assembly will not work.
The electromagnet locks the lid and it also unlocks the lid. It is not a matter of cutting the power to the magnet.
Installing 2 switches that connect the red white and blue is the best option if you want to remove the lock.
The first switch should connect the white and blue. (LID CLOSED)
The second should connect the red to the white/blue connection. (LID LOCKED)
After that the lid should work.
Please post a follow-up if this works for you.
GOOD LUCK
Posted on Aug 06, 2012
I can not open the door on my Maytag top loading washer
Many new washer use a lid lock instead of a brake to keep people from reaching into the spinner before it stops. You probably have a
bad lid lock. Have a repair man open the top cover and repair or replace the lid lock.
Jul 06, 2016 | Maytag Washing Machines
Need to remove the glass lid to get to an area of rust caused by a maytag technician chipping the paint and they won't fix it
Tape the washer lid closed. Using a putty knife, press and unlock the two front top locks. The locks are approximately six and a half inches from the outside edge of the washer
Mar 10, 2014 | Maytag Bravos MTW6600T Top Load Washer
Maytag bravos x lid lock overide or bypass
Washer not starting Cycle:
I would have to slam the washer lid before the washer recognized the lid was shut.
What I did to fix:
1. Ref the link below for Schematics
http://blog.kennyluong.com/Tricking-A-Maytag-Bravos-Washer/
2. Looking at the Lid Lock section of the Schematic:
Place a jumper between pins 2 and 3 of J15
This engages the 1st switch (Lid switch) so, I don't have to slam the lid anymore
3. Since my Lock switch (2nd switch), which is engaged with a magnetic, is working, my work is done.
If you find that your machine is still not starting the cycle after jumpering pins 2 and 3, you will need to replace the Lid Lock mechanism or ref the above link for temp bypass.
Feb 11, 2013 | Maytag Bravos Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Code reads "OP" what does this mean?
Go here Neptune TL Washer FAV6800AWW
read the 7th post down ""issues related to the Left Hand Lid Lock for FAV6800A or FAV9800A machines.""
Mar 18, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag top load washer op error code, washer wont start. Checked and magnet is in place, what else can it be?
If you place a couple magnets over the left gray bumper and the "OP" error code doesn't clear then I feel you have a problem with the Left Hand Lid Lock.
See if this post will help; Left Hand Lid Lock Troubleshooting
Sep 29, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune tl code od
You have lost signaling from the Left Hand Lock. The washer has not see the lid go open thru the signaling with the magnetic reed relay in the Left Hand Lid Lock.
See if this post will help you Left Hand Lid Lock Troubleshooting
The p/n for the Left Hand Lid Lock is 25001048
Some other handy links. The Service Manual for reference. Sears Parts Direct for reference..........Rich
Jun 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I can't get the washer to unlock. The cycle is stuck and I think the load is unbalanced but I can't get the washer door electronic lock to open even after I turn the washer off and unplug it
Manual Door Unlocking Procedure for Maytag Neptune Top Load Washers
  1. Safety first. Unplug the machine.
  2. Insert a plastic putty knife blade in the front edge of the machine between the top cover and the cabinet and in line with the lid seam on the left and on the right.
  3. Push in to release the latches holding the top cover to the cabinet.
  4. Lift the front of the top cover and release the lid from the lid locks.
  5. Disconnect the wiring harness from the lid locks. Clean the terminals to ensure good connection.
  6. Reconnect the lid locks wiring harness and push the top cover back into the cabinet until the latches lock up.
Please let me know if the problem comes back for further troubleshooting and repair guide.
Jan 24, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I posted a problem with a Neptune top load washer
The lid lock is bad part # is left side  25001048 runs around $80,the problem tends to stem from the dispensers water and bleach work their way into the switch and I have never had much luck cleaning them out and getting them to work.. and that is left hand side as you are facing the machine.
Sep 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Top load washer
1. Remove top. 2. remove left side lock accuator. 3. open accuator case. 4. Solder small broken wire back to diode. 4. reassemble 5. enjoy.
Oct 04, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
87 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
