Question about Kenmore Refrigerators
I have kenmore refrigerator # 795.71099.111. Milk in door as well as tray of eggs stored in plastic container placed on top of crisper unit are both frozen
Posted by bill lefferts on
David Spradling
    Top Expert:
  • Kenmore Master
  • 10,914 Answers
If unable to turn down bad temp sensor from fridge to control board
Posted on Jan 28, 2020
5 Related Answers
Robert Fawbush
  • 178 Answers
SOURCE: i need new parts for
www.partstoday.com they will need the model number to be able tro search for the parts, enjoy.
Posted on Apr 06, 2008
freetek
Steve Allison
  • 5569 Answers
SOURCE: Freezer section of Kenmore Self Defrost Refrigerator Mfg. 4/07
What you have found as a model number may in fact, be a part number for the inner lining.
Check your owner's manual for the model number.
Check to see if your unit is equipped with a setting for humid/dry climates and if it is present, it should be set to correspond to yours.
The defrost cycle melts concealed, built-up frost, with an internal heating element.
That produces water that should normally drain through a hidden path down to the evaporation tray at floor level under your unit.
If the path is blocked, the water will find its way into the interior and refreeze wherever it lands.
Gaining access to the element and the drainage path can be a real pain in some refrigerators and requires removal of the liner of the freezer for access.
Good luck.
Posted on Jun 15, 2008
louislevel_2
Louis Magpantay
  • 374 Answers
SOURCE: frigidaire refrigerator freezes everything with setting on lowest
hello there,
try to check your thermostat setting adjust below gradually,
you set it up to coldest point that's why it's doesn't cycle on no auto shutt off and shut on,
if still not change for 12 hours still freezing up,replace thermostat by your technician,might defective.have a nice day
don't forget to rate me,thank's a lot.
Posted on May 05, 2009
Anonymous
SOURCE: Freezing eggs in fridge area and freezing produce in crisper
HOW TO STOP MY PRODUCE FROM FREEZING
Posted on Aug 26, 2009
Anonymous
SOURCE: Milk container doesn't heat milk..only the steam is released.
I was told this was a problem with the O rings on the machine (you need to keep these clean or replace them (if necessary) to keep the milk container working properly).
I did this and still had the same problem. Turns out the top on the milk container needed to be replaced. It's $20 from Delonghi but at the time of this writing is out of stock (I have waited three seeks so far and Delonghi is supposed to be escalating my request).
I finally got frustrated with the whole thing and completely disassembled the milk container top (there are a total of 5 screws and you need to remove the froth control slider to get to one of them) and gave everything a good cleaning. Pay attention to the small orifice on the inside of the chrome tube that the milk comes out of. Using a dental gum cleaning brush or similar sized brush and some hot soapy water should get the dried milk residue out. Inside the top is also a rubber piece that the froth regulator inserts into. Reomve this rubber piece and clean thoroughly. Make sure and clean all other areas inside the top with hot soapy water. Make sure to look the top over well as you disassemble to be sure note all component positions for reassembly. Make sure when reassembling that the cleaning button and its spring are reassembled correctly. The small red O ring on the end of the cleaning button's rod should be cleaned well and the small tube into which it inserts should be free of any milk residue. One last item to check is the rubber bushing that rubber milk uptake tube inserts into is clean and making a good seal. Note that this bushing should make a good seal on both sides (the side the rubber uptake insrts into and the side the upper side of the top inserts into. Make sure all parts are reassembled correctly. In general if you clean and rejuvinate all areas that need to make a tight seal you should get good results. I have no experience here but it would be my observation that even with a good thorough cleaning job the results may not last a real long time as it seems that parts in the top show wear after about a year and a half of daily use. In my oppinion the purchase of a new $20 top makes sense, but if you can get one or don't want to wait you can spend the 30 minutes to do the above cleaning. Because of apparent backorder issues at Delonghi this may also be a good idea to buy upfront. Make sure to include the 5 O rings in the order ($1 each) to avoid paying two shipping fees. I have found one of the O rings at Lowe but was unable to find a few of the sizes (smaller than Lowes sells).
Posted on Aug 30, 2009
My kenmore trio refrigerator ice maker is not producing ice, inside the fridge my milk spoils but my eggs get frozen any ideas?
Am surprised your refrigerator is 'blowing hot and cold thru the same mouth!. Try turning the power off and keep the doors be open for 12 hrs. Wipe off water under the fridge and turn on power.Good luck.
Mar 08, 2014 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Tip
Keeping your eggs at their freshest
Although it is very thoughtful of refrigerator manufacturers to provide us with special containers for our eggs, did you know that eggs stay fresher in their original containers (not the hen)? Research has shown that both cardboard and styrofoam egg cartons provide identical results regarding keeping eggs at a safe temperature. To be even safer, place the styrofoam or cardboard carton in the bottom of the refrigerator, NOT THE DOOR, The door is one of the warmest places in the refrigerator and dairy products (eggs, milk, cheese, yogurt, sour cream, etc.) should NEVER be stored there!
on Dec 02, 2010 | Refrigerators
The light is remain lite and the plastic cover is malted.
The switch at the bottom of the door is bad, not turning the light off when the door is closed
Mar 01, 2012 | Kenmore Elite 78722 78729 Bottom Freezer...
I have a tefal TT550015 toast 'n' Egg and have no instructions on how to use it. Please advise
To use the egg side only, fill the measuring cup with the correct amounts of water. (One side is for boiled eggs, one is for poached eggs.) Pour the water into the basin at the bottom. For boiled- Place 1-4 eggs in the tray with the four holes. Use the sharp thing at the bottom of the measuring cup to pierce the egg shell. Place the lid over top, and hit the 'egg' button. When the light on the button goes out, remove the lid. For poached, grease the pan. Spray/ butter, whatever. DO NOT rely on the non-stick. The thick black tray for boiling eggs goes on first. With the egg in the greased pan (scrambled or whole) place the pan into the unit. There are four plastic pieces in the boiling tray to show you where it goes, the handles aligned. The round tray, with the square holes in it, can be used to warm pre-cooked meat.This is optional, and that tray goes on top. Place the lid over the top, and press 'egg'.
WARNING: this cooks by steam, and any remainder can cause burns. Be careful when removing the lid. Same goes for the product. The boiled eggs should not be touched directly.
To make an egg sandwich, load the egg side and the bread/english muffin/bagel into the toaster. Press the 'egg/toast' button BEFORE starting the toaster. The toaster will start on a timer so that the egg and toast will be done at the same time. When the toast pops up, you are good to go.
Note: there should be no water afterwards, maybe a little oil if you cooked meat. Hard water residue is easily removed with vineger and a paper towel.
Dec 02, 2008 | Back to Basics TEM-500 Egg & Muffin...
Crisper Door broken
Repairclinic.com had the parts I needed (crisper drawer lid and the longer drawer lid.
Nov 17, 2008 | LG LRFD25850 French Door Refrigerator
Refrigerator
check behind the drawers is there a water tank for water in thew door that would be my first guess
Feb 10, 2008 | Kenmore 63074 Top Freezer Refrigerator
Refrigerators Logo
54 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
geob91
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
