Question about Pride Health & Beauty
Blinking yellow wrench light on pride jazzy 614 HD I'm getting 8 flashes with power indicator going left to right too.
Posted by Jeff Albritton on
jws1013
  • Pride Master
  • 1,708 Answers
8 flashes means there is a power module issue. Check the connections at the battery and power module. If ok, check the battery, it may need replacing.
Posted on Jan 28, 2020
Testimonial: "Thanks for your reply...I'll check battery and see what I find."
5 Related Answers
HoverTech
Donna Angelo
  • 232 Answers
SOURCE: chair no longer charges, no flashing or blinking, lights,
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
Posted on Oct 20, 2010
lennieg2000
  • 692 Answers
SOURCE: don't run light go from left to right on a "Jazzy
carly that indication is the charging inhibit mode and the joystick still thinks the charger is still plugged in. Unfortunately there is no quick fix for this and usually requires a joystick or controller replacement. I would have your provider check it for you and maybe try another joystick from another chair to see if that fixes the error if it does then you'll have to replace the joystick. If Medicare paid for your chair then they will pay for most of the replacement cost Hope this helps
Posted on Nov 19, 2010
Louis Smith
  • 104 Answers
SOURCE: pride jazzy 600 power wheelchair controller lights flash
make sure the motors are not disengaged, turn off chair, can you move it by pushing it? if so lock the wheels and try again. next is the controller in lockout. press and hold the on button till it beeps push joystick forward til it beeps pull it back til it beeps turn off try again. you can call 1-800-800-8586 for tech support
Posted on Oct 01, 2012
bill cooper
SOURCE: My jazzy pride 614 wont go anywhere when i push the joystick forword a yellow light flashes but its yo hard to see
if it can be pushed then the free wheel locking lever is needing to be put in the locking position
Posted on Mar 18, 2013
gewiz
Rob Hill
  • 1414 Answers
SOURCE: Have a jazzy pride 614 and it is hard to get it to back up and it
hi, where are you please ? ... there can be number of reasons for this, the most common...
1. the reverse logic of the controller is breaking down..
2. the joystick mech ...
Regards
Rob
www.gewizrepairs.co.uk
Posted on Jan 10, 2015
Red flashing wrench light power comes on then goes off no power
check your battery connections they are giving a code that something there maybe wrong. For instance cable slipped off or the battery connections. The connections may have been installed wrong, especially if this happen directly after someone changed the batteries. Strege Mobility
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
May 01, 2016 | Pride Jazzy 614 Hd JAZZY 614HD
What does a wrench light that flashes twice mean
I'd be thinking that it's suggesting there are mechanical issues that need to be attended to.
Jul 27, 2015 | Pride Mobility Jazzy 614 HD Power...
How do I repair wrench flash 8
If its a Shark then fault 8 : SHARK Power Module Fault
Check SHARK Connections and Wiring Replace the Power Module
if its a DX fault 8 : Over Voltage Fault
Check Battery voltage is below 32V Check Battery wiring and terminating is secure
Oct 20, 2014 | Pride Jazzy 614 Hd JAZZY 614HD
My lights are blinking and can get it to run
The lights are a message.. Record the number of flashes. Then go to Pride Mobility Products Corp Basic Troubleshooting Instructions go to bottom of first section under Jazzy http://www.pridemobility.com/includes/download.php?f=troubleshooting/INFINFB2468_Jazzy_614_614HD_Troubleshooting.pdf match your flashes to the third page and you will have an idea what is wrong. Best of luck.
You must have pdf reader to read this file Free download at:
http://www.adobe.com/products/reader.html
Jul 31, 2014 | Pride Jazzy 614 Hd JAZZY 614HD
What does a jazzy 614 power chair 9 flashing wrenches need?
hi, that is the code for a brake fault , check the wiring to the brakes located on top of the motors...
Regards
Rob
Jul 05, 2014 | Pride Jazzy 614 Hd JAZZY 614HD
Flash code list #7
Go to Pride's website to download the service manual. It has more information than the owner's manual does.
May 31, 2014 | Pride Jazzy 614 Hd JAZZY 614HD
What does a flashing yellow light mean on the joystick? the light looks like the shape of a wrench.
Hi Judy,
According to Pride's troubleshooting documents the service indicator (wrench icon) will flash when a fault is detected by the dynamic controller.
The number of flashes, followed by a 2 second pause, indicates the issue. You will need to count the flashes to determine the cause and a possible solution.
I have typed the flash codes below, but you can also see them on a larger table here: http://www.fixya.com/support/p3641679-pride_jazzy_614_hd_jazzy_614hd/usermanual-6B42026-pdf
FLASH CODES
Code #1
  • Flash Code: One, pause, one
  • Cause: Possible Stall Timeout
  • Possible Solution: Turn joystick off, then on.
Code #2
  • Flash Code: Two, pause, two
  • Cause: Battery Fault
  • Possible Solution: Charge batteries, check battery connections and fuses.
Code #3
  • Flash Code:Three, pause, three
  • Cause: Left Motor Fault
  • Possible Solution: Make sure the left motor is plugged in.
Code #4
  • Flash Code: Four, pause, four
  • Cause: Right Motor Fault
  • Possible Solution: Make sure the right motor is plugged in.
Code #5
  • Flash Code: Five, pause, five
  • Cause: Left Park Brake Fault
  • Possible Solution: Make sure the left brake is not in freewheel mode.
Code #6
  • Flash Code: Six, pause, six
  • Cause: Right Park Brake Fault
  • Possible Solution: Make sure the right brake is not in freewheel mode.
Code #7
  • Flash Code: Seven, pause, seven
  • Cause: Joystick Fault
  • Possible Solution: Check the joystick connection.
Code #8
  • Flash Code: Eight, pause, eight
  • Cause: Power Module Fault
  • Possible Solution: Check connections to the power module and batteries.
Code #9
  • Flash Code: Nine, pause, nine 9
  • Cause: Controller Communication Fault
  • Possible Solution: Check bus connections from the joystick to the power module.
Code #10
  • Flash Code: Ten, pause, ten
  • Cause: Controller Fault
  • Possible Solution: Contact Technical Service for assistance.
Code #11
  • Flash Code: Eleven, pause, eleven
  • Cause: Incompatible Device Fault
Sep 05, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
Mar 18, 2013 | Pride Mobility Products Pride Jazzy 614
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
Jan 06, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
Jazzy 614HD will not move. Lights flash from right to left, then cuts off. Unlock instructions are not effective. Chair is fully charged.
If chair has a tilt, recline or lift seat on it it may be going into lock-out mode on its own due to a limit switch fault. If you don't have any of these options then I suggest you remove the joystick, controller and any wire harness between the two and send them to a shop like mine for repair.
The usual lock out light chase is from left to right - not right to left so this is suspect of a different issue.
Dec 28, 2012 | Pride Jazzy 614 Hd JAZZY 614HD
Health & Beauty Logo
111 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
