SOURCE: Error message E9
gebje,
error codes on pentax camera's are in the repair manual to help the technician find the problem faster. e9 is shutter failure and will need to be repaired.
SOURCE: i have a SVC E9 error what does that mean
SVC E9 is an OPC Marker sensor error. Here is the service manual. See page 64 (or2-4 in the manual) for troubleshooting steps:
http://transfer.barrister-net.com/download/Lexmark/Color%20Laser/Lexmark%E2%84%A2%20C500n%205023-110.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
I happen to work for Rome Industries and can help you out. The "LP" code on your control board represents "Low Pressure". This is referring to the refrigerant pressure within the unit. The unit is equipped with a low pressure safety switch that when activated shuts the unit down. This could be caused by a refrigeration leak, a stuck thermal expansion valve, or even a faulty pressure switch. If you live within the state of Florida contact Rome Industries and you will receive a free of charge service call including parts and labor as long as your unit is under warranty. If your outside of the state please contact your dealer to handle the claim. Have a good day.
Hi
E9 means the water level sensor is
defective or the pipe connected to it is faulty.Generally error E9 means a
problem with your water pressure sensor. do you have water in the tub? Check
the sensor by pulling the hose attached to the bottom part of the tub and blow
on it and test the terminals of the sensor if it will close or open.
Please get back to us if you have
further query else please accept the suggestion.
Thank you for contacting fixya.com
