Question about GE Ovens
Hi. I have a GE profile wall oven and it won't turn on. The screen is black, even after I just replaced the control panel.
Posted by Estee S on
5 Related Answers
Powerman
Charlie Popeck
  • 68 Answers
SOURCE: ge double wall oven repair
You need to tell us the model number. I can then give you specific information.
Posted on Nov 18, 2007
aborcass
Ron Coons
  • 2651 Answers
SOURCE: GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Posted on Mar 30, 2008
Cathy Shin
  • 3 Answers
SOURCE: ge profile oven loc
hey - I figured it out! hold down the 9 and 0 at the same time for 3 seconds! or it might be another combination depending on your oven - it is probably the 2 keys that the messge is under
Yay!
Island2
Posted on Oct 03, 2008
Anonymous
SOURCE: ge profile advantium 120, scb1001 oven, display panel out
Turned off breaker for 30 seconds. Display returned.
Posted on Jan 20, 2010
kel1guy2002
Kelly
  • 3740 Answers
SOURCE: getting F7 code on a ge profile performance oven
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Try gliding your finger flat across the keypad rapidly and see if you can unstick the key / touch pad. Usually once this code appears it will repeat.
On self cleaning ovens this is the service check:
Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Thanks for using FixYa!
Kelly
Posted on Mar 09, 2010
Why is there a loud noise coming from control panel when I turn on the oven?
How often does it happen? Sounds like your control board is starting to fail. The Repair Shack can fix the oven control board if it needs repaired.
Nov 29, 2015 | GE Profile PT916SRSS 30" Single Electric...
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    Double wall oven F0 error code
    The F0 error code means that the control board has detected a defect within the control board itself, the F0 code can be cleared by pushing the CANCEL/OFF button and if it goes away and returns all is well,however if a short time later the F0 returns the control board would need to be replaced.
    GENE
    Oct 04, 2011 | GE Profile 30" Built-In Double Electric...
    I have a JT955 GE Profile 30"double oven...when the food is cooked, and I press "clear/Off", the oven won't shut off...continues to maintain temperature? Tonight, I had to shut it off,...
    Your wall oven has two main components that control the oven. The main control computer and the user interface. Your problem is probably in the user interface, although it could be the main control or both. I have had some success cleaning the ribbon that connects the user interface to the control with a little rubbing alcohol. That only works some of the time though. Due to the fact that the oven works except for the cancel button I would lean towards replacing the user interface if cleaning the ribbon dose not work.
    Aug 29, 2011 | GE Profile JK955SFSS Electric Double Oven
    My GE wall Oven Model #jctp18ba1bb is not working.the board is blankm the only thing that works is the oven light.Is there any kind of thermal fuses etc. in this oven.thge control board was replaced 8...
    When you say board I assume you mean the electronic clock/timer. This timer directly affects the oven operation. Even if the internal oven fuse is blown or the thermal overload is tripped the electronic timer and oven light will always work. If the oven light works and the electronic timer/clock does not I'd say that the timer/clock is faulty.
    Feb 10, 2011 | GE Profile 30" Built-In Single Electric...
    GE profile wall, single, Get a
    Hello,The "FO " reading you get is as a result of "Shorted Clear/Off key due to the membrane switch,control or connector".And these mean you have to check the Shorted key panel membrane switch; Check Electronic Range Control(ERC)
    Thanks
    Jun 02, 2010 | GE Profile JTP18 Electric Single Oven
    Ge profile wall oven - f7 but I fix with eraser trick - now the clock can't be reset and the 4 does not always work on the keypad
    F7 stuck keypad
    Stuck keypad may mean relay is turned on.
    Determine if problem is with the Key Panel or Control by:
    Aug 28, 2009 | GE Profile Advantium 30" Built-In Single...
    Ge Profile built-in 27 inch wall oven -- When I
    f9 means your control panel needs to be replaced..chances are part is not covered and if it is the only way you can obtain it is through having service
    Jun 18, 2009 | GE Profile JT912 Electric Single Oven
    GE Profile JGB97 Self Cleaning Oven Controls won't work
    You have a problem that may be solved with my solution to the Dreaded F7 Problem. Even though you don't have a F7 error on the display the symptoms are all the same. You can find my fix at the following links.
    http://www.fixya.com/howto/h155060-dreaded_f7_error
    I have shared this with more than 1550 folks and most report success. This problem often develops after a self clean cycle.
    I hope it works for you too. Please let me know at the following:
    [email protected]
    Good Luck,
    Charlie Popeck,P.E.
    Consulting Engineer
    Feb 06, 2008 | Ovens
    Ovens Logo
    73 people viewed this question
    Top GE Ovens Experts
    William Miller
    William Miller
    Ekse
    Marvin
    Marvin
    Are you a GE Oven Expert? Answer questions, earn points and help others
