Fix my scanner - Office Equipment & Supplies
How to fix scanner error 6?
herewith 3 suggestions (try searching the HP forum or search engine 'scanner error 6'). Read all of them before you decide to do anything and only then decide which order if any to do them depending on ease vs likely effectiveness.
HP LaserJet 3055 Scanner Error 6
HP Laserjet 3055 Scanner Error 6
6.July.2015
Jul 06, 2015 | HP LaserJet 3052 All-In-One Printer
How to fix Aj5030 error clean up scanner
Clean scanner lamp and optical lance .if not the problem fix need to change scanner unit
Jul 14, 2014 | Sharp AJ-5030 InkJet Printer
My HP screen says Scanner failed. Can I fix this/
no u can't fix it because ur scanner has a rode, i.e looking like a tublight when u scanned a document the rode move one direction to other direction, rode don't move on ur scanner, so ur hp screen says scanner failed, if ur printer is in warranty goto to service center , if out of warranty, open scanne glass cover and check light rode on the scanner, lightly try to move the rode and see is something
bump with this rode , fix it
Jun 26, 2014 | HP Officejet 4620 e-All-in-One Printer,...
Error 120 code
To reset the SC code follow these directions:
Resetting Ricoh Savin Lanier Gestetner SC Error Code
Error code 120 is scanner home position sensor problem. If it's a recurring problem, here are some troubleshooting tips:
SOLUTION:
Turn the main switch off and on.
Check the wires between Home Position sensor and the SBU.
Fix scanner board or the SBU .
Check the wires between scanner motor and the scanner I/O board
Fix the scanner motor.
Fix the Home Position sensor.
Fix pulley, timing belt, the scanner wire,
Fix the carriage.
Jun 17, 2014 | Gestetner Office Equipment & Supplies
Pro 97 Scanner. I boght the 20-047 USB Programing cable. I have Windows 7. The CD does not have Windows 7. Is there a fix or upgrade ?
No there is no fix or upgrade for the scanner software. I suggest using software from http://www.butel.nl for your scanner.
Programming information can be obtained from www.radioreference.com
Jul 21, 2011 | Radio Shack Pro-97 Handheld Scanner
PGM WIRED
pgm wired how do i fix this?
Sep 19, 2009 | Radio Shack Pro-84 Handheld Scanner
I got a new computer (Gateway) and I installed the software for my canon scanner and whenever I try to open it I get a box that says ''insufficient memory.'' How can I fix this?
Since you're getting this error, I believe that the software is not completely installed. To fix it:
* Uninstall the scanner software.
* Check the target location (if you're going to install it in drive C: or D: or any drive letters). Make sure that the location has enough memory space to accommodate the file size of the scanner software.
* Delete some unnecessary files.
* Re-install the scanner software.
This should fix the problem. Have a great day!
Sep 13, 2009 | Canon Office Equipment & Supplies
Hi there, I have a Canon Flatbed scanner (Lide 25) and when i try to scan i get an error message as follows: 'Unable to load TWAIN server'. How can i fix this?
Hi Jason
A Simple fix just reinstall your software that came with the scanner and this should re establish the link between twain and your scanner
Regards Alan (alstech)
Please dont for get to leave feedback if this was helfull
May 12, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
How do fix a blown scanner?
hi
no, you must buy a power supply to 4.5 / 6 vlot. The scanner fails with high voltage.. Roberto
Apr 21, 2008 | Metrologic Instruments MS7120 ORBIT...
32 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
