Question about Sharp Office Equipment & Supplies
How do I set the time and date on a sharp yo-430 organizer. The NY & London time are shown but I want to replace them.
Posted by richard johns on
Terry
  • Sharp Master
  • 11,377 Answers
5 Related Answers
Anonymous
SOURCE: Setting time & Date
I copied this from another post & it worked for me:
To enter the date
1. Be sure to switch to "rate set" from GT
2. Enter the month
3. Press the decimal point
4. Enter the day
5. Press the decimal point
6. Enter the year
Example 3.09.2007
7. Press the button that look like a clock/calendar
To enter the time
2. Enter the hour (please use military time)
4. Enter the minutes
Example: 13.24 or 9.24
5. Press the button that look like a clock/calendar
Then change the "rate set" back to the GT setting.
Posted on Mar 24, 2008
Anonymous
SOURCE: how do i set the date and time on a sharp
one of the easier ways would be to download a software that makes it so you can edit your calculators data... but i'm honestly not sure
Posted on Mar 22, 2009
shannongreer
Shannon Greer
  • 75 Answers
SOURCE: HOW CAN I SET THE DATE AND TIME ON SHARP
http://www.sharpusa.com/files/cal_man_EL1750PIII.pdf
Posted on Jun 03, 2009
Anonymous
SOURCE: Retrieve Password without losing data with Sharp Organizer
According to the YO-370 Operation Manual:
What To Do If You Forgot The Password -
When you have forgotten the passord for the SECRET function, you have to delete the password along with all secret data by selecting "DATA DELETION" from the Function menu. Once the password is deleted, a new password can be entered. Follow the procedure below to delete the password (and the secret data along with it).
1. Recall the Function menu (2nd, FUNCTION)
2. Select "3 DATA DELETION", and press v (3, v)
3. Select "3 SECRET DATA". (3)
The delete prompt "DELETE ? Y/N" appears
4. Press Y (To retain the data, press N)
When Y is pressed, both the password and the secret data are deleted, and the initial display for the previous mode in use will reappear on the display.
Posted on Sep 23, 2009
Anonymous
SOURCE: Sharp Electronic Organizer Model ZQ-5200 how do I reset the date
I just ran across my manual. My organizer died, but here goes. You have to set the home date and time as the city's date and time for your time zone. Press Shift-Home. Select 1 to choose the City. Cities are listed according to their country. Press U for United States. Press the up or down arrow to scroll. When you see your City or one in the same time zone, input that number. If DST in effect, press shift-number for the city. To set time, select 2,or Shift-Home-2. Set the time. Press enter. Good Luck.
Posted on Oct 18, 2009
Hi! I need help with my Sharp YO-520 and my Rupp Lynx software!
Ahaaaa Grasshopper... it is WISE to say (simply), "That was then and WHY didn't YOU tell me sooner?!"
Don't take 'responsibility' for it... "HE" KNEW it was failing (getting dimmer and dimmer) but did nothing about it until it was too late.
HIS fault ~ not yours... step back from that yoke... no yoke.
BUT ~ make sure you install the FRESHEST "LR03 x 2" you can find!
Be SURE to check the Link below... I hope it helps you BOTH... TRY not to make "his BIG problems" yours.
Anthony
Sharp YO 150 Operation Manual Troubleshooting Replacing Batteries
Dec 15, 2017 | Computers & Internet
THE 7THTHRU 12 COLUMNS ARE UNREADBLE VERTICLE CAN THIS BE FIXED OR DO I NEED A NEW ORGANIZER???? IT IS THE YO-190 256KB ORGANIZER.
The screen has lines on it? This can be fixed by replacing the screen, I don't know if parts are available, I think your best shot is to find another organizer with the same screen and replace the screen or use the other one.
seem a new one costs around 100usd
http://cgi.ebay.com/BRAND-NEW-SHARP-YO-190-256KB-MEMO-MASTER-ORGANIZER-SET!_W0QQitemZ160282250449QQcmdZViewItemQQimsxZ20080912?IMSfp=TL080912112005r33862
I think you should contact sharp for the replacement il look up the contact details.
Sep 29, 2008 | Sharp Computers & Internet
How to set date and time onxe-a102 cash register
turn key to PGM then
for Date enter MMDDYYYY press CA button (example) 09282012
for time enter hhmm press CA button (example) time must be in military time increments for example 11:00PM will be entered as shown (2300).2300 hours will showupon your receipt as 11:00 PM. If you have any problems with SHARP equipment call 1-800-BE-SHARP.
Sep 27, 2012 | Sharp XE-A102 Cash Register
Looking for software for OZ-730. Found that www.mywizard.com is no longer an accessible site.
CALL thewizardshop.net 803-736-4382 they have software and sharp organizers.The wizardshop can help you with ALL your Sharp Organizer needs.
Cords,software for Windows XP and 7. They have Sharp OZ-730,OZ-770 and YO-520. They also repair ALL Sharp organizers with a keyboard.
www.thewizardshop.net
803-736-4382
Nov 29, 2010 | Sharp Wizard OZ-730
Setting the correct dateon a sharp organizer yo 530
first of all you shoud find the time and date setting on sharp pw then set it if it not work same problem again then open carefully your sharppw and find the cell battries and replace it
Mar 29, 2010 | Sharp PW-E350 Electronic Dictionary
I have a sharp YO 610 organizer. replaced the 4 batteries- now won't turn on. need cord and software to download information into my laptop. can I do this although I cannot get the organizer "on"?
FROM MY YO-610 USER MANUAL--IF THE UNIT DOES NOT TURN "ON" AFTER REPLACING THE BATTERY (MEMORY) CAREFULLY REPEAT THE BATTERY REPLACEMENT PROCEDURE.
Dec 22, 2009 | Sharp YO-170
Sharp OZ-730 sticky keys
I have a a Sharp yo-480. I've fixed sticky keys many times. I back-up data in the organizer first. (yo-480 doesn't have a flash memory) then carefully dissasemble unit. Lift out rubber keypad and use WD-40 to wipe circut board and keypad. It's the sticky residue that makes the keys stick
Nov 16, 2009 | Sharp Wizard OZ-730
Sharp YO-520 organizer - "data has been impaired" screen
You got "data has been impaire" on your Sharp last year.
I've got the same problem.
What solution did you find ?
Thanks,
Aug 19, 2009 | Sharp YO-520P
Apr 17, 2009 | Sharp Office Equipment & Supplies
Sharp YO-520 SEEMS TO BE BROKEN
sharp yo 520
I have lines all thru it.
Apr 26, 2008 | Sharp YO-520P
Top Sharp Office Equipment & Supplies Experts
k24674
George Mclaughlin
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
