Kitchen Appliances - Others Logo
Question about Electric Kitchen Appliances - Others
I need a manual for the Cooks Electric Pressure Cooker. Or can you tell me what is wrong when I put the meat & water in cooker, put top on & plug it in. It starts beeping and E1 keeps blinking on the cooker & it cannot be programmed. Help!!
Posted by Kimberly D. Jeffries on
  • Electric Master
  • 6,611 Answers
I do not know the Cooks Electric Pressure Cooker. There is the Cook's Essential Digital Pressure Cooker. This model gives an E1 error when there is a broken circuit to the sensor. The manual recommends unplugging the unit and letting it cool. Then restarting the pressure cooker. Since you have the error when the unit is cool, the wiring is broken or the pressure transducer or thermisitor is damaged in the pressure cooker. See https://www.hippressurecooking.com/manuals/Cook/cooks_essentials_K36000_Manual_opt.pdf for this pressure cooker manual. Most likely you have broken wires between the control unit and the pressure and temperature sensors.
Based on the design of the unit, it could be that the wiring is broken between the outer pot and the control panel. If the wiring is damaged between the outer and inner pots, do not try to repair the wiring yourself.
If your pressure cooker is under warranty, I suggest you contact the manufacturer. Otherwise, it may be better for you to get a new unit rather than risk damaging the pressure cooker. Damaged pressure cookers can become dangerous.
Posted on Jan 25, 2020
5 Related Answers
Anonymous
SOURCE: cooks essenial small pressure cooker
Keystone is the manufacture for the Cooks essentials K5963 pressure cooker. Keystone authorized Deni to sell the same product as the Deni model 9700 Pressure cooker. I found the manual on the deni site in PDF formate. This is the exact same pressure cooker with a different name on it.
http://www.deni.com/index.cfm?fuseaction=page.product&category_id=27&product_id=21
Posted on Oct 13, 2008
ginko
Ginko
  • 19396 Answers
SOURCE: my deceased mother received this as a gift and I
There are two manuals available, see below:
cook's essentials'
COOK'S ESSENTIALS®
Posted on May 03, 2009
Anonymous
  • 2049 Answers
SOURCE: Need manual for 5 1/2 qt pressure cooker cooks essential
While these may not be for that exact model, I'll bet they will help immensely...
Here's a link to the free downloads at QVC...
http://www.qvc.com/man/k/K97438_man.pdf
http://www.qvc.com/man/k/K37000_man.pdf
Posted on Sep 02, 2009
Anonymous
  • 121 Answers
SOURCE: I HAVE LOST THE MANUAL
Here is the ink to the manual in PDF form: http://www.qvc.com/man/k/K97438_man.pdf?&cookie=set
Good Luck, RJ
Posted on May 13, 2011
Testimonial: "Thank you for the answer,very helpful"
mc1bean
Mike Cairns
  • 3053 Answers
SOURCE: Need manual for a Cook's Essentials Electric Pressure Cooker. Any suggestions?
Hello Marie,
I believe this is the manual you are looking for. It is here to view and download in pdf. I hope this is the one you were looking for, if so please rate my solution and free help. Thanks Mike
Posted on Oct 21, 2011
1helpful
2answers
How to I brown meat with model SEPC01 electric pressure cooker?
If your book say that you can "brown"with it, please check!! Then take bowl out of cooker and brown meat on your stove top then put back into cooker then cook with your slow cooker! Note:only sum cookers allow u to do this, if it doesn't tell u it can then u could possibly crack your bowl!
1helpful
Technique model 89759. Where can I get a user's manual?
pressure cooker manual & recipe booklet library ' hip ...
www.hippressurecooking.com/pressure-cooker-manual-library/
Dec 14, 2015 - Free downloadable copies of pressure cooker instruction manuals for stove top ... Farberware Quick Cuisine Pressure Cooker Recipe Booklet .... SunbeamPressure Cooker Manual; Technique Pressure Cooker (see Deni); T-fal ... Tower (see Fagor for similar models); Tramontina Pressure Cooker Manuals ...
Technique Oval Talking Electric Pressure Cooker Manual ...
www.hippressurecooking.com/technique-oval-talking-electric-pressure-c...
Oct 7, 2009 - Technique Oval Talking Electric Pressure Cooker Manual. 44 ... ForTechnique Pressure Cooker model numbers: 99800, 99801, 99802, 99803, ...
Technique by Cook's Essentials Digital Pressure Cooker ...
www.hippressurecooking.com/technique-by-cooks-essentials-digital-pres...
Oct 18, 2009 - For Cook's Essentials Model Number: DYB350 Please wait a moment for ... Technique by Cook's Essentials Digital Pressure Cooker Manual.
Jan 19, 2016 • Home
I need to find a cool touch handle for the cooks essential pressure cooker model 99700
Cooks Essentials 99700 5 qt Electric Pressure Cooker ' eBay
www.ebay.com/.../Cooks-Essentials-99700...Pressure-Cooker-/2211...
eBayItems found similar to "Cooks Essentials 99700 5 qt Electric Pressure Cooker". Items in search results. Item image · Cook's Essentials 5qt Electric Pressure CookerPressure Regulator Knob & .... Aluminum Pressure Cooker XLT Model YPC-1045 ...Cooks Essentials liner/pot for Pressure Cooker #99790 Replacement part ...
How to Replace Parts on a Cook's Essentials Pressure Cooker
www.ehow.com > Home
Your Cook's Essentials pressure cooker is manufactured to work without ... for myCook's Essential pressure cooker model 99700...any suggestions where I can ...
I need a rubber seal for my pressure cooker model 99700 ELECTRIC PRESSURE COOKER
4 quart cooks essentials pressure cooker - YouTube
? 7:04
www.youtube.com/watch?v=JIGVz1HcDlc
Jan 6, 2012 - Uploaded by wtbm123 My magic pot. ... Electric pressure cooker that has a timer so u set it and... ... without some kind of water ,it would not make enough pressure to seal the pot . .... I cant find one online anywhere, is there another model that fits?
Cook's Essentials PRESSURE COOKER - Fixya
www.fixya.com/support/t318063-cooks_essentials_pressure_cooker
Cook's Essentials PRESSURE COOKER WOULD YOU KNOW WHERE TO GET A NEW GASKET FOR CEPC600S PRESSURE COOKER? ... part,, pressure regulator knob cooks essentials electric pressure cooker model # 99700 5 qt. ..... Looking for a replacement gasket for my 10 qt Innova model 42010 pressure cooker.
How can I tell what pressure the cooker is making so as to determine how long to proceed pressuring???
Follow the instructon from manfatures users manuals and add your recipes and put meat amoung vegies and every thing you like and spices in the cooker and ad 4 cup water and cook for 15 minutes
Cooks essentials manuals
Well, it depends on the model, I looked the digital pressure cooker manual (found here http://www.hippressurecooking.com/category/manuals/cooks-essentials/) E4 is a Signal Switch Malfunction. The recommend turning off and un-plugging the pressure cooker and letting it cool of completely before trying to use it again.
I have a cooks essential electric pressure cooker model #99740 and when I plug it in all the lights flash and won't do anything else.
It shouldn't do anything until you set the program. Did you try putting your cooker through the water test?
Check this chart to see how your pressure cooker SHOULD work:
http://www.hippressurecooking.com/infographic-the-pressure-cooker-trouble-shooter/
22helpful
3answers
To add water or not to add water????
Slow cookers do not need water in the base unit to cook the food in the ceramic insert. The ceramic insert gets hot from the base and cooks the food. Here is a good guide to cooking with a slow cooker. enjoy
http://busycooks.about.com/library/print02/ncrockpot101.htm
Top Electric Kitchen Appliances - Others Experts
Marvin
Marvin
vince
Are you an Electric Kitchen Appliances - Other Expert? Answer questions, earn points and help others
