Question about Seiki Televison & Video
Seiki tv, model Se40fy. Is this tv compatible with a hdmi/ micro usb cable to connect android phone for viewingmirroring?
    Top Expert:
  • Seiki Master
  • 10,790 Answers
Go into input or source change to one you need then picture settings and activate the source on phone settings to other screen
Posted on Jan 28, 2020
5 Suggested Answers
Anonymous
  • 520 Answers
SOURCE: connect computer HDMI to Projection TV HDMI to watch web TV
use a s-video cable or a monitor ext cable and use fn+f4 to switch
pc mon to ext mon.
n.b. f key is usually f4 , models vary.look for square icon on f key.
fn+ that key; thats fn and say f4 pressed together.
Posted on Jan 29, 2009
John Riley
  • 441 Answers
SOURCE: LG HT502 wont recognize hdmi cable. it says hdmi
go into the video setup menu, and select HDMI set up and select "ON" that should do it
Posted on Jul 15, 2009
Anonymous
  • 12 Answers
SOURCE: HDMi ( no signal, not supported) doesn't work with Dmr-Ez47v
Any HDMI cable manufactured in the last couple of years should all be HDMI 1.1 compliant, your problem is most likely the logic board in the TV itself or the HDMI connector on the logic board has a bad connection..
Have you tried hooking-up a standard DB15 VGA cable to the AKAI TV and your laptop?
If this works your problem is in the TV and will most likely have to be repaired to receive the HDMI signal since your Panasonic DVR and your laptop are not recognized by the HDMI input on the TV.
Ren
Posted on Aug 28, 2009
Anonymous
  • 10 Answers
SOURCE: Philips LCD TV "47, model PFL 8404H/12, NO SIGNAL on all 4 HDMI
This is quite tricky as it was working until last night and suddenly stopped receiving signals. What can happen wrong?
Do you have any other Player or other HDMI cables to try out. Sometimes the cables would be damaged or PC may fail to detect the HDMI.
Try this out from Philips helpdesk where there is new SW and FAQs are available.
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PFL8404H/12&slg=en&scy=CZ
Let me know if you are not able to upgrade the FW (if you do not get the support on ugprading)
Posted on May 11, 2010
Adinarayan Raghu
  • 15 Answers
SOURCE: when i connect (samsung s3650
reinstall again
Posted on Sep 04, 2011
Does a Seiki SE40FYM have a QAM tuner?
I do not believe the Seiki SE40FYM has a QAM (unencrypted digital cable) tuner. The specification sheet for the SE40FY says that the model has over-the-air ATSC and NTSC tuners. See https://www.qvc.com/footers/el/pdf/E227730_SpecSheet.pdf . The M indicates that this model was sold through one store/chain.
I hope this helps.
Jul 27, 2018 | Seiki Televison & Video
I bought a 6-foot micro USB to full size HDMI MHL cable for my RCA Android Voyager to connect to TV will that work it's not working now I don't know how
Looking at various versions of the RCA Voyager tablet manuals, these tablets do not support MHL connections to a TV. See https://rcaav.com/computing/user-manuals/ to find the manual for your device. The Voyager models only support storage (connecting to a computer or flash drive) and charging on the USB port.
Some of the other RCA tablets may have HDMI, mini-HDMI or MHL support.
I wish that I had better news for you.
Mar 24, 2018 | RCA Televison & Video
Can I connect my fire hd 10 to my tv using a cable.
It seems as if it is possible to connect your Fire HD 10 to a TV via a HDMI cable. In order to do this you will either need:
  • Amazon HDMI adapter for fire tablets
  • Micro HDMI/ USB to HDMI cable
Here is a helpful article with ways to connect to a TV and links to the types of adapters on amazon.
How to Connect Kindle Fire to TV
Amazon com Amazon HDMI Adapter for Fire Tablets 4th Generation Kindle Store
Amazon com AmazonBasics High Speed Micro HDMI to HDMI Cable 3 Feet Latest...
Apr 02, 2016 | Amazon Kindle Fire HD
How would I connect my acer a1 830 to to my tv to watch showbox ... I was told i could use a micro usb to HDMI adapter to do this and cannot figure it out....
No, the A1-830 doesn't support MHL (micro-USB to HDMI). So the micro-USB to HDMI adapter will not work. The tablet's USB port will only support connecting to the charger or a PC's USB port. Here's a list of known MHL devices: http://www.mhlconsortium.org/devices.aspx . The previous model (A1-810) had a micro-HDMI port that could connect to a TV's HDMI port with the appropriate cable. You might be able to use the AllCast app and a Roku or FireTV box. You will need to upgrade to the Premium version for any files longer than 5 minutes.
The other way to mirror content from the Iconia A1-830 would be to transfer it to your computer. Then send the file to the TV via Plex or SmartShare depending on the file and your TV. If you can upgrade the tablet to Android 4.4.2 or higher, then a ChromeCast will let you mirror content directly from the Iconia A1-830. This will require steps that can make the tablet unusable (research rooting an Android device).
I wish that I had better news for you. Unfortunately, even if you have a TV with a USB port, it probably will not access the files on the tablet. (Many only support FAT32 or NTSC file systems.)
Jan 25, 2015 | Acer Iconia A1-830 Tablet - 16GB
How do i play movies from a tablet i plugged a hdmi cord but no response
You mentioned a "usb cable" but you cannot connect an external display to a tablet's USB ports. If you are using an HDMI cable, then you will need to select which display is active through the tablet's settings (Android) or control panel (Windows) and also make sure that the TV is set to the appropriate HDMI connection through the input selection.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Dec 31, 2014 | Toshiba 19SL410U 19 LCD TV
How can I connect an alcatel to a tv using the microUSB?
Two ways:
1. If your TV has a USB port, connect the phone to that port using the Micro USB cable that came with the phone.
2. Get a Micro USB-to-HDMI cable and connect your phone to an HDMI port on your TV using that cable.
The question is: what are you trying to accomplish ?
Dec 22, 2014 | MetroPCS Alcatel ONETOUCH Evolve 4G...
How do i connect sony mobile phone to sony tv
Watch and listen to your Xperia TM content on your TV
Open this link & watch this video will let u know how to connect sony mobile to bravia via mirroring.
Thank You
Dec 01, 2014 | Sony Cell Phones
9" Inch Google Android 4.2.2 Allwinner A23 Tablet PC Dual Core WiFi 8GB UK how do i connect to television?
micro usb to hdmi cable or flylead, check amazon - type - allwinner a23 tablet to tv cable into amazon search & get over 4000 results.
Nov 11, 2014 | Tablets & eReaders
Can i connect my archos 97 cobalt to tv
• Micro USB 2.0: Mobile Transfer Protocol (MTP)
• USB host via OTG
• microSD (compatible with 64 GB cards)
• HDMI output (Mini HDMI / HDMI cable sold separately) If you have the Mini HDMI to HDMI cable you may be able to connect to HDMI input of TV, or try USB out of the device to Computer input on the TV....
Apr 30, 2014 | Audio Players & Recorders
How do I hook my phone up to tv through head phone jack to party music from my phone through tv speakers
First determine what you have available on the phone and TV. monoprice.com has all sorts of X to Y cables. If your phone has a micro HDMI port then the best quality would be a micro HDMI to HDMI. That is if your TV has HDMI available. Reply with your TV make model and phone make model and I can give you a better answer.
Jun 01, 2012 | Droid Tunes Android Apps
Televison & Video Logo
Top Seiki Televison & Video Experts
Andrew Taylor
Andrew Taylor
Stan Ford
Are you a Seiki Televison and Video Expert? Answer questions, earn points and help others
