Question about Samsung Computers & Internet
How do I turn on my samsung keyboard dock - Samsung Computers & Internet
Posted by tabitha on
Larry Ng
  • Samsung Master
  • 6,021 Answers
NO PC stated make and model.
no OS stated
no dock model stated, Samsung model.
no answers.
Posted on Jan 26, 2020
How do I update firmware for dock when monitors won't display while laptop is docked?
Hi
My suggestion is to plug your dock to external displayer (monitor or tv) them set to duplicate display mode. Let me know if helps.
Aug 17, 2015 | Lenovo Computers & Internet
Tablet boots with power supply connected but when on battery power alone when pressed the power on/off button lights up with the hdd light and then goes off then on then off about 5 times.
You need to change the battery, the machine may well show 97 percent but the battery will deplete overtime purely because of t the number of times they are recharged. This is particularly so on newer batteries.....such as li-ion cells. The method of depletion can be deceiving, showing high charge but one that cannot be retained.
Buy a battery, (ies,) from a reputable manufacturer.
At worst you will have a spare
Jul 08, 2015 | Samsung NOTEBOOKS ATIV Smart PC 500T...
How do I get the keyboard to work?
For the keyboard to work, the tablet has to be docked on the keyboard (you will hear a clear clicking sound when you dock the tablet properly). If the keyboard doesn't work when it is docked, it should be brought in for a repair.
Mar 14, 2015 | ASUS Transformer Book T100
If i click the factory reset in my samsung galaxy tab2 7.0..all the pictures and video will be deleted?
When you do the factory reset by default it will erase all the data from the tab .... only default settings will be available
Oct 28, 2014 | Samsung 60-2706-05 Galaxy Tab Keyboard...
I need driver
Apparently a lot of people have complaints about that keyboard dock (see the customer reviews on Newegg.com --> http://www.newegg.com/Product/Product.aspx?Item=N82E16834131399 .)
Go to http://www.samsung.com/us/support/downloads and enter in the entire model number in the search field, including the characters after "T1C". Your drivers should then come up. Post back how it went.
Jan 04, 2014 | Samsung Xe500t1c Ativ Smart PC Keyboard...
How do you turn off the lenovo thinkpad tablet 2 keyboard?
You turn the power off to the Thinkpad Tablet 2 keyboard by holding the power switch to the right for 3 seconds.
Mar 05, 2013 | Lenovo ThinkPad Tablet 2 Bluetooth...
Dell Latitude E6410 : Mouse & ext. Keyboard lost when putting back into docking station
Go to the Control Panel in your start menu whilst the PC is in the dock,disconnect the things you want it to detect, then click on "Add a device" and connect them one by one :)
Aug 16, 2012 | Dell Latitude E6410 Notebook PC - Intel...
Can samsung andriod screen connect to tv
Yes it can.
Samsung have a dock for the Galaxy Tab which connects it to a pretty much full-size keyboard, and props the screen in a position where it's like a laptop's screen. There are also a number of Android devices that have a video or HDMI out capability to output their screen onto a TV, often needing a special converter cable.
Bluetooth is an option for connecting keyboards, KeyPro (AppBrain Link) (Official Website) andTeksoft Blueinput (AppBrain Link) (Official Website) load drivers onto your phone to let you use Bluetooth HID to connect up many Bluetooth keyboards (trial versions are free to test your device's compatibility, but it looks like if you want to carry on using it you'll have to pay to register to make it work fully).
Nov 04, 2011 | Samsung Cell Phones
The C V H T and B keys on my other Dell laptop, an Inspiron 1545 have stopped working
Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Reseat the Keyboard Connector to the Motherboard Caution: Before performing any of the procedures in this section, read and follow the safety instructions in Dell Knowledge Base Article: "Precautionary Measures for Personal Safety" Article ID: 339031. Reseat the keyboard connector to the motherboard. Be sure to handle only the connector and not the cable. For information about how to open the chassis and remove, reseat, and replace components, please refer to your Online User's Guide and browse to the Replacing and Removing Parts section. Remove All Power Sources and Reset the Computer Remove the battery and disconnect the AC power adapter from the computer. Note: For information about how to open the chassis and remove, reseat, and replace components, refer to the Online User's Guide. Click Systems, then the make and model of the computer. Download the Owner's Manual or User's Guide and refer to the Adding and Replacing Parts section. Press and hold the power button for 10 seconds. Reattach the AC power adapter to the computer. Power the computer on. Replace the Internal Keyboard
Nov 07, 2009 | Dell 0Y3740 Keyboard
D630 docked , ext mouse & kybd not responding
If the docking station has power:
Make sure power is off for both the laptop and the docking station. Plug your keyboard and mouse into the docking station. Dock the D630 to the docking station and then power on docking station. This should then turn on your D630. Your D630 should detect the keyboard and mouse.
If the docking station has no power:
Verify that the power cord, AC adaptor, etc. is plugged in. If the items listed seem to be in order,
there may be a problem with the power going into the docking station. (AC adaptor?)
support.dell.com will have the specific details for your D630 and your docking station, et al.
Please let me know if you have success in this.
Binary Bob
Nov 27, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
Top Samsung Computers & Internet Experts
Jean Thiebaux
Jax Planet
Jax Planet
aliasger yq
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
