My mastertech tv won't stay connected to the Internet after the tv is turned off and you turn it back on
2 Suggested Answers
Anonymous
SOURCE:
Andy Fraser
SOURCE: Toshiba tv won't turn off/ stay on
Try unplugging your television for a half an hour or so. It might reset to original settings, Your problem might be input lock features. If you can get to the menu after unplugging your tv for awhile we might be on the right track. I'm just looking thru a Toshiba manual that I have.
Posted on Apr 13, 2013
My TV will not stop switching itself off
Hi, The first thing to do is troubleshoot your TV independent to any other service provider that has a box that probably connects to your TV via a HDMI cable or old version scart.
Simply turn off your TV and turn off the socket that the TV is plugged in for 20 mins. Also turn of any Virgin media boxes.
After 20 mins turn on the TV. Do not worry if you get a message saying no signal detected. Wait and see if the TV stays on with no messages such as auto-standby. If the TV remains on with no problems then turn on your Virgin Media Box. The box will need to initialise ( about 30 seconds ) and then the TV should recognise the HDMI signal and you will see the Virgin TV.
If your TV turns off at any point during this process you have a fault with the TV, If when you turn on the Virgin box and no signal is detected you have either a cable connection problem or a Virgin Box problem, so using your TV REMOTE turn your TV back to ARIEL input to receive the normal television broadcasts via your Ariel that give you the normal freeview television that all modern TV's can receive, if you can get the normal reception contact virgin support who will troubleshoot your problem.
Nov 07, 2017 | Internet Computers & Internet
TV goes off suddenly. Searching for connection.
'Searching for connection' sounds like it's looking for a network link. check your internet connection. If it's supposed to be watching cable or broadcast TV, check the setup menu.
Oct 21, 2014 | LG 37LH40 37 in. LCD HDTV
Why a Mastertech tv doesn't turn on, it just stay in stamby
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 13, 2014 | Televison & Video
Philips 32" tv won't stay on
Quite possibly one of the heat sinks has come loose or a power supply cooling fan has failed.
Have you tried blowing it out using canned air?
Nov 01, 2017 | Philips 32PFL3504D 32 in. LCD TV
New laptop won't stay connected wirelessly on start up
Connection problems can only be caused by two things.
A bad or week signal from your router, try moving it or moving the computer closer to it.
A faulty receiver in the laptop itself. This happens. Try it in Starbucks or MacDonalds to check it.
Nov 26, 2017 | Samsung np700z5b-s01ub 15.6" series 7...
Daughter's TV was on during bad electrical storm. Screen went black and made high pitched sound. cable, internet and telephones all digital through Time Warner Cable. Now TV will not even turn on;...
Ur Main Fuses in the circuits breaker box must be to be restart it back.Turn off/on all the fuses on the main circuits breaker box to all the fuses in the box of the box to restart.All ur electical power outlets should work again.If not those power plug in outlets are shorted and dead must have to be replaced.
Aug 22, 2011 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
My 42LD450 won't stay on! It turns on for a few seconds and works fine, then the screen flashes then comes back on, then flashes again after a couple seconds, then turns off. Rinse and repeat. Tried...
I hope that you can use the warrantee.
Otherwize, it must be possible to repair it with a fried comfortable with electronic because the problem is not permanent. This kind of problem is usually an old capacitor or a bad connection (soldering).
It would be important to check if changing the ambiant temperature fixes the problem. (I.E. move it to the seller for 2h and try..)
Regards,
Jul 10, 2011 | LG 42LD450 42 in TV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
