Question about Cameras
Hello I own a pSony pcm d50 with a broken lcd display. Anyone who owns a dead pcm d50 and willing to sell to me for parts or sell me just the display please let me know. Thanks!
Anonymous
SOURCE:
Anonymous
  • 215 Answers
SOURCE: Broken LCD Display
You should find it easy to pull apart if you take your time and find all the screws. Just don't use brute force or a hammer:-) Maybe a friend can help you if you feel wary. Once the back is off be carefull there may be cables connected to it so don't get carried away. Often the LCD is lying on top of the remainder of the camera and sometimes it's attached the rear of the camera. You'll know as soon as you get it open. Find the screws retaining the LCD and remove them. You may find some adhesive tape holding the LCD down too. Carefully remove this and keep it.The LCD will have one, maybe two flat ribbon cables protuding from it. To disconnect these the sockets they are attached to will have either a tiny plastic flap across the top of the cable holding it down and if it's one of these then carefully pry the flap up with a thin blade. If it doesn't have a flap the you'll notice a different coloured piece of plastic rinning under the cable with very small protusions at each end. With a small screwdiver you should be able ease these protusions away from the socket. Do one end and then the other but don't push too far. This will loosen the cable and you can pull it out. You will probably find two standard type wires coming out of the LCD as well. If you're lucky they terminate in a plug which is easily removable. If not they will be soldered to a PC board. Do a rough drawing of the board and mark where which coloured wire is soldered. For a replacement you can try Fuji but if you think the cost is over the top take a look at Ebay and see if there's the same type camera as yours which is being sold for parts or repair. If you do find one make sure the LCD is intact and bid away on it. Ebay is a goldmine of spare parts and I've used it many times to get cheaper parts for myself. EG a cmplete camera with broken lens for less than Sony wanted for freight for the part I needed. If you don't find one wait a few weeks and one may turn up. When you get the replacement use your memory and put it all back together without ending up with a spare screw or two. Good luck. BMW
Posted on Jul 02, 2006
Anonymous
  • 62 Answers
SOURCE: Broken lcd display Nikon sb-800 flash
You can order the part from NIKON or I can fix it for you .
Berrie Smith Camera Repair
[email protected]
Posted on Feb 06, 2008
gvel
  • 3 Answers
SOURCE: Broken LCD Screen FujiFilm FinePix S700
i have a fuji s7000 that has a good lcd screen but the processor inside doesnt work. You could use it for parts.
Posted on Oct 30, 2008
Anonymous
SOURCE: 32'' Winbook Lcd Tv bad main board
eBay: Find WINBOOK LCD TV CONTROLLER BOARD 6870C-0060F in the Electronics
I located this board at anewparts on ebay, hope this helps you also
"Q"
'Til the Wheels Fall Off!!
Posted on Apr 20, 2009
Anonymous
SOURCE: motorola 9505 iridium phone
I am a service and repair technician for satellite phones, and we have a very large inventory of all parts associated with satellite phones including LCD screens, front and back housings, antenna socket housings and boards, PCI boards, keypad boards, data ports/charging ports, antennas, sim card readers, and more. We can also do electronic component repair such as resoldering of headset jacks, and power jacks. We support models Kyocera ss66k, 9500, 9505, 9505A, 9555 and more.
Call 877-943-6383 ext 920 for prices of parts or repairs..
Posted on May 13, 2009
Sony PCM-D50 Mu Sony PCM-D50 takes between 3 and 20 attempts to boot up. Once on, if the unit is left idle for more than 6 seconds, all the controls will freeze - it will not even switch off. The only way...
i dont have a solution but this seems like the only way to contact a user. im experiencing the EXACT same problem right now with a pcm d50. Did you ever figure out what to do?
Apr 29, 2011 | Sony PCMD50 (4096 MB 125 Hours) Handheld...
Dropped Nikon Camera Sadness
Hi Al
not sure if i can help here but will try.
Ive not owned the D50 but i have the feeling the highlights function is similar to other cameras in the Nikon range.
On your cursor when viewing an image, just press down on the cursor maybe once or twice to remove the highlights .This is just a pointer for you like the histogram.
Now it seems like you may have damaged the sensor and will not collect enough light.
Try setting the camera to A = aperture priority and take a shot in bright light...no flash.
Are the images still dark ?
If so raise your iso to 800 and shutter speed to 1/250 at F5.6 aperture in mode S =shutter priority and take the shot in bright conditions.
Are the shots still dark ?
Nov 11, 2009 | Nikon D50 Digital Camera
Fuji Finepix F450 broken LCD
Possibly search ebay for broken cameras of the same make or replacement parts. Fuji's contact center may sell parts or possibly fix your camera for free.
http://www.fujifilmusa.com/support/ServiceSupportRepair.do
May 26, 2009 | Fuji FinePix F450 Digital Camera
The piece of **** we own is pt# r-1500. In less than a year the lcd display shut down. Now the switch assembly has broken and we have been informed the entire control panel assembly is unavailable. Nice...
Both parts are readily available - you can order them from Martin Microwave Inc.
(toll free 1-877-894-0035).
The lcd / control board / display is Sharp part # CPWBFB075MRU0 and it sells for $79.99
The button assembly is Sharp # JBTN-B122MRF0A and it sells for $13.99
You can also check with www.microwavedisplay.com for a rebuilt board
Sep 10, 2008 | Sharp Microwave Ovens
Nikon D50 lcd problem
I'm sure that the auction/sale has ended for this, but I'll go ahead and answer it. Yes, it could be a simple loose/broken cable. But when it comes to cameras, is that a good thing? Something had to jar that cable. Nikon builds are strong, possibly the strongest. The guy who owns that camera was probably very rough with it, and therefore MUCH more could possibly be wrong it (fractures, scratches, etc.)
I bought my d50 used, but the guy I bought it from was smart enough to take SEVERAL pictures, including that of the glass, the mirror, display, everything. I had the option of buying a d50 for $150, and all it had wrong with it was a crack going along the outside of the analog lcd and down part of the camera. Problem was, how hard did he drop it? He might have even knocked the internals around!
Save yourself headaches, and most probably expensive future investments, and be sure what you're buying is in mint condition (body scratches and general wear on rubber grips, etc. aside). Most people who own SLRs (with exceptions to some professionals) cradle their cameras like it's their baby.
Aug 19, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
Broken LCD Display
Yes Fuji does sell parts for all their cameras goto www.fujifilm.com for thier comtact information.
Jun 30, 2008 | Kodak EasyShare M853 Digital Camera
Hinge assembly broken
I had the same problem but is so easy to fix.The part costs from $25.00 to $50 depending where you buy it from.Once the part gets to you email i will guide you step by step.Just use this link for the part lovemacs_2022_236981589
May 29, 2008 | Apple Cinema Display 23" HD Monitor
Lcd monitor/display broken
Call the manufacture of the camera to see if they will sell you spare parts. Most, and including their authorized service reps will not sell directly to an end user. They have some lagitimate policies about why they will not. It is more than simply making money fixing their products.
It would be best to let the manufacture service rep do the repair.
__
A simplified point of view from the manufacture and service rep side:
Many times people will buy specialized parts to try their own repairs, and damage the parts. This is especialy with CMOS and very delicate parts. Then they go back and have an argument with the manufacture that the parts were defective when they were really originaly not defective. I have seen this many times myself when I was doing service.
The other aspect is that when the customer repairs his own equipment, he will not have the training and skills, and proper test equipment and tools to properly do the service. He ends up with a high end product that cannot perform well, and this can work against the repution of the manfucture.
With TV sets, microwave ovens, and other high power devices, there are safety conserns where manufactures are very nervous about having customers venture inside. Selling a part to a non qualified or approved person can pass on legal safety responsibility from the manufacture.
__
Some of these display panel modules require special heat seal connectors and ribbon cables to be changed. This depends on their particular design. Some models require IR surface silver soldering to replace. You may replace the display yourself and find that the new one does not work because there are other parts that were also damaged along with it, or you may accidently damage the display from static or some other means.
Jerry G.
Mar 16, 2008 | Panasonic Lumix DMC-FZ30 Digital Camera
[email protected]
Aug 17, 2006 | Nikon Speedlight SB-800 TTL Flash
Cameras Logo
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
