HELLO WITH MY MAGIC TO CONNECT IN THE TV....THE TV CANNOT READ ANYMORE
Hello, The DVD button is not working anymore and
The remote has its own issues.
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remotes", check the 'include description' box. Usually cheaper than the vendors.
Hardware buttons on devices also fail. There's no magic fix for them. Do other modes select ok?
Jul 19, 2011 | Samsung HT-TXQ120 Home Theater System...
I have a 22" LCD
Hello
Either your DVD players' laser pickup unit or its strip wire has got damaged. Laser pickup unit is one which reads the disc we put into it, and strip wire is one which connected between the main circuit board and laser pickup unit assembly. The strip wire damage is common for all cd players, and dvd players. Just replace the strip wire with a new one of same type; and see the effect. If it helps you it is OK. If not, replace the laser pickup unit assembly with same type and number.
If you wants anymore assistance, feel free to contact me by Fixya. OK.
Mar 05, 2011 | Coby TVDVD1350 13 in. TV/DVD Combo
I have a LG 42LD450, I read and saw videos online showing that you can enable video playback through the USB port. I also read that u need a certain universal remote to access the service menu does anyone...
I used a Magnavox MG500S, some simply use a Comcast Cable remote, some just use a universal from radio shack......all in all....once you get the remote programmed to the TV you have to find its "Magic Button" to open the password screen........then enter code.(0413) for the remote I used. Some were using code 0000. All in all I guess it depends on the remote used.......sorry I cant help anymore than that.........then I can if you find the same remote I used!!!
Dec 04, 2010 | LG 42LD450 42 in TV
The magic focus does'nt seem to reset the auto convergence on the tv. Do you have any sugestions
The Magic focus button,not in effective anymore.The tv is 100% have convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must replaced these parts on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 07, 2010 | Hitachi 46F500 46" Rear Projection...
My psp2004 does not read game umd's anymore:( what to do
oohhh hat was great relief for me ! i just squeesed 2 orange peal wih some ginger juice into the umd slott & enchaned a magical spell. it got all right after yhis inciden.. if u wanna know hose magical words plez conact me at my google account . [email protected]... belive me there is something called magic
Jan 27, 2009 | Sony PlayStation Portable (PSP) Slim...
Blue and Green Bar
run magic focus, If you get a error 4 during the magic focus, that is often an issue with the convergence
Feb 01, 2008 | Hitachi 51F500 51" Rear Projection...
Help
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC3021
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(For low price replacement remotes visit www.sparky-uk.com)
Jan 17, 2008 | One For All URC-3021 Remote Control
My Gigabank will not read on my computer anymore
We are seeing alot of posts reporting problems with these USB connected portable drives. Maybe this is one of those ideas that sounded good, but results in lots of headaches, lost data. First, try the drive on another machine- see if works there. In Control panel, select Administrative Tools, Computer Management, Disk Management... Does the drive appear there? It is possible the drive needs repartitioned/reformatted (not good for your data). You could take the USB drive case apart, check the interface cabling to the drive, and try it again. If it still doesn't work, try removing the drive and installing it in a desktop computer as a slave drive. I've only had one of these USB connected drive assemblies apart, but that one used a drive with a standard 40 position ribbon cable interface, the same as what is used on pre-SATA desktop systems. If you've gone this far, you could try removing the drive from the case, and installing it in a desktop machine as a slave drive, and seeing if you can get anything off it there. Diagnostic software from the manufacturer could also be run here too. None of this may get your project back however, unfortunately. For those highly important things, a backup is really suggested- and you know why- the hard way.
Sep 28, 2007 | IO Magic Corporation GigaBank 8.0...
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
