Sony CDX-S2010 CD Player Logo
Anonymous Posted on Sep 19, 2009
CDX S2010 CD player acting up
The faceplate is lit, however the "off" button is the only button that functions. I had the stereo on when this happened. I was increasing the volume and when i released the button it continued to climb to max volume, played for a moment and then quit playing. If I insert a CD, it will autoplay the cd but only at max volume, none of the buttons will function and my only option is to eject the CD to make it stop playing. I did check the copper contact from the faceplate to the actual stereo and it appears to be intact. I disassembled the faceplate and all of the buttons are working internally, despite my thoughts that one might be stuck. Ideas?
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Sep 19, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
942
Points
6
U have a faulty wire.
  • Anonymous May 17, 2012
    what do we do to fix this faulty wire? im having the same issue.
Sony Marine Stereo CDX-M6OUI Face plate lights up and all the controls work. CD Plays, Radio Plays, MP3 Plays. Problem: The faceplate shows no information(ie song, CD, radio station) Just a blank lit...
The display disappears from/does not appear
in the display window.
• The dimmer is set "DIM-ON" (page 17).
• The display disappears if you press and hold (OFF)
Press and hold (OFF) on the unit until the display appears.
• The connectors are dirty (page 21)
https://docs.sony.com/release//CDXM60UI_EN_ES_FR.pdf
I've had my Sony Xplod CDX S2010 Radio/CD player in my Jeep for years and it has all of a sudden locked up on me. The CD player will play and eject CDs, however it doesn't allow me to adjust volume or skip...
i'm not sure if there is a flexible cable that goes from the face to the motherboard. if there is, that could be the problem. it could also be a bad switch.
2helpful
I don,t have the owners manual to instruct me to
Press and hold 'SEL' button. (the setup display appears) Press 'SEL' repeatedly until "CLOCK-ADJ" appears. Press 'DSPL' button. (the hour indication flashes) Pess the volume +/- button to set the hour. Press 'DSPL' button to select minutes, use the volume +/- to set minutes. Press 'SEL' button to start the clock. Press and hold 'SEL' ...setup is complete. To display the clock, press DSPL. Press DSPL again to return to the previous display. Reference page 4 in this link to Sony for your CDX-S2010 Operating Instructions.
http://www.docs.sony.com/release/CDXS2010.pdf
1helpful
How do I replace a fuse on Sony CSX-S2010?
there will be a fuse on the back of the radio, you will need to keys to reove it, also check the fuses in the car fuse box.
1helpful
CDX-GT710 CD/Front panel will not move
I called the manufacturer who privides FREE instant support 24 hours a day and doesn't try to sign me up for memberships.
Sony Xplod CDX-S2210S
It is more then likely your faceplate has become non functional, and if so the cd player is almost none functional. If you can remove the faceplate try cleaning the connections that clip into the cd player. But by the sounds of it, your face plate is die'ing out on you. Sorry
Good luck,
IF you need any more help just ask.
Thankyou
2answers
Sony CDX-MP40 only works after hitting reset button
If you dosn't find a solution, then I'am very interested in buying the faceplate for this unit. [email protected]
Please Help
check face plate maybe contact dirty if not well our in trouble sometime it not worth to repair it cheers
Faceplate not responding / acting very weirdly
Sounds like a bad connection with the faceplate and the multi connector that the faceplate mates with when closed. check for dirt and bent pins on both connectors. Luck
Top Sony Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
 Grubhead
Grubhead
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
