Question about Video Cameras
+how to set up clock mod 88901 - Video Cameras
Posted by Cornelis Visser on
1 Related Answer
Anonymous
SOURCE: SkyScan Atomic Clock Model 88901 keeps displaying
My outdoor unit does not pick up on the clock
Posted on Nov 12, 2010
How do i set clock on Dunelm cream microwave mod no52753
So just to make sure that it wasnt an easy fix, I went to the Dunelm site to see if they had a manual. No such luck.
I did however see that on the front of this microwave (the cream one), there are 6 buttons near the top. One of them is the Preset/clock button.
What I have known with most (not all) is that with the clock feature, you press the clock, set it and press clock once more.
HOWEVER
With this model because clock is the SECOND item listed, I suggest to press that button twice, wait for the clock to come up 00:00 and set it using the same button (preset option).
Unfortunately I don't know this for certain as I am only using an educated deduction on other brands of microwaves with similar front panels.
I really hope this helps, please let me know if it works as I will be contacting Dunelm to ask for a pdf manual.
Jul 21, 2016 | Microwave Ovens
Ho to set Clock on GE Mod JRS068 J1BB
On GE ovens there should be a CLOCK button to press first. Then if the control has number pads 1 to 0 you enter the correct time and press clock or start again to finish. If it has no 1 to 0 pads there should be 2 arrow type buttons with + on one and - on the other. Press clock and then use + to go up or - to go down. Holding either button in will make it change fast. When you get close to correct time hit button slowly to finish. Hit clock button when time is correct.
Mar 09, 2015 | GE Ovens
I have just installed an Baumatic wall oven mod. no. B605MS.1. The clock has lit but the oven does not actually switch on and heat. Please help. Thank you
The electronic timer/clock must be in the manual mode for the oven to work. Consult your instruction booklet and set to manual. Your oven will then work.
Mar 07, 2011 | Baumatic Ovens
I have an intel core 2 duo E4400 CPU (800Mhz FSB, 2GHz clock speed) with the gigabyte motherboard GA-G41MT-D3 but the motherboard seems to insist on running the CPU at a clock speed of 1.2GHz. The BIOS...
hello there i am also using a intel Core 2 duo that i have over clocked to 3.3GHz reason i am bring that up is i had to mod the mother board i would say lets start there if you need help with modding the Gigabyte let me know. as its going to be a long email =)
Jan 23, 2011 | Gigabyte GAG41MTD3 Motherboard
Need a manual for an iLo DVD Recorder, Mod. #DVDRO4
need a copy of the DVDR04, help set recorder and clock.
Apr 16, 2009 | iLO DVDR04
Need operating instructions for RCA clock radio Mod. 5430
The instruction manual will not help you, because it doesn't address this problem head on.  You're having this problem because the time changed, and the clock has an automatic setting.    As long as the batteries are in the clock and it's plugged up, it automatically computes the time. I just discovered the solution.  Unplug the clock, take out the batteries and WAIT about an hour.  Plug it back up, and the time will flash, allowing you to change the time.  You do this with the button on the top back which says wake up 1 and wake up 2.  Push that button all the way to the right to the setting that looks like a little clock, then press the forward button on the top of the clock to set the correct time.  Then put your batteries in and you're good to go!  (til the time changes again:)  Good luck!
Oct 27, 2008 | RCA RP5430 Clock Radio
Xbox error code 16
16 - dashboard - Clock cannot be set.
Basically it comes down to this. Error 16 has to do with not finding the menu setting with which you can set the clock of the hdd. This happens to a lot of people that erase their hdd (original/upgraded) or MS dashboard files and after that they don't immediatly install the hdd but leave the xbox without power longer than 5 hours.
It's all about the hdd can't find the menu with which it can set the clock. This is mostly because the xbox hdd is empty (you removed dashboard or fux0red it via ftp). The problem arises when xbox searches for menu to set clock with, can't find it and voila: error 16. Well read on please!
So you have an error 16 huh? Don't worry "nothing" is broken!
You have an xbox hdd that is locked. And normally you can boot in original and modded mode. Retail or upgraded doesn't matter. You start playing around with xboxdash.xbe etc. using ftp programs. While doing this you "accidently" remove your MS dashboard and also your alternate dashboard (Evox, etc.) so there is no dash anymore on the xbox hdd.
You end the ftp session and after that you shut off your xbox. Normally when you would start up again it gives you an error 13/14 ( no dashboard found). No worries with a slayer Evox cd (and a hardmod), all is ok. BUT this is only WITHIN 3 hours or so.
This is because the internal clock of the xbox will only be kept alive by the capacitors for only 3 or 4 hours. So when you leave your xbox unplugged from electricity for over 5 hours after you have played with the .xbe's AND you have removed your (ms and evo-x) dash from your xbox than you are fux0red. Why do you ask?
Why can't I boot from disc?
Its as follows Xbox starts booting==> (almost 1st thing a xbox does is) searches for internal clock==> doesnt find internal clock because there hasn't been any electricity on the xbox for 5 hours so battery that kept clock alive is empty and clock is gone==> searches for the proper dashboard menu to set clock with ==> doesnt find msdashboard or evo-x dashboard menu becuz you have removed it from the hdd for whatever reasons you had==> xbox gives error 16: cannot set clock.
So what do you do about it? Two options!
1. There are some bios'es around that allow the chip to boot past the clocksetting. (do a search!). So how do you get that bios on your chip because you cant boot to a flash program or something? Well you need to have an external flasher.
It seems the m8 bios will take care for you of booting past the clocksetting. Or use the latest Xecutor bios
2. This is the more easy and newbie friendly strategy
-Get a friend with a modded xbox.
-Unlock his hdd with eeprom management from a slayer evo-x cd.
-Than, place his hdd in your xbox.
-Boot with your chip on.
-Now the xbox DOES find a dashboard when you boot in original mode and you can set the time in the msdashboard clock settings.
-Shut off xbox and remove your friends hdd
-PLace his hdd back in his xbox and lock it again
-Install your hdd
-(clock has been set) So boot up with slayer cd.
-Install normally whatever you wanna install
-lock hdd
Nov 27, 2007 | Microsoft Xbox Console
Setting clock on Amana Microwave Mod#FBG623T
It may possibly be locked, in which case holding the enter/start pad for over 3 seconds may unlock it.
Otherwise, you may want to call Maytag / Amana at:
1-800-688-9900 U.S.A
1-800-688-2002 Canada
Nov 04, 2007 | Bosch HMB402 Microwave Oven
Video Cameras Logo
Top Video Cameras Experts
Tony Parsons
Tony Parsons
Tom Chichester
Are you a Video Camera Expert? Answer questions, earn points and help others
