Question about OCE Office Equipment & Supplies
What is Error 20501 for a Oce Plotwave 500? - OCE Office Equipment & Supplies
Posted by Francisco Gonzalez on
Marvin
    Top Expert:
  • OCE Master
  • 85,239 Answers
The use of A: Attributes for Item Specifics has been changed. You will need to use C: instead of A: as that option in no longer valid.
I've tested and confirmed with your file that changing to C: will resolve this error.
Posted on Apr 16, 2020
4 Related Answers
Anonymous
SOURCE: oce plotwave 300 error 8513
Dear Sunilkudal20,
the error code referes to an electronic failure in the fuser section.
  • You can try to reset the system by turn the machine off and on.
  • Check if there is no media is in the fuser section.
If this is not solving the issue, I advice you to contact you local service organization.
If you leave your country of origin, email adress and / or your telephone number, I can ask a colleque to contact you.
Kind regards,
Jack de Weirdt
Oce Technologies B.V.
The Netherlands
Posted on Aug 01, 2011
rsatishniki9
rsatishniki9
SOURCE: oce plotwave 300 error maintenance
Error Code 15709 is coming frequently... what should i do for this? please do the needful...
Posted on May 24, 2012
SOURCE: Oce plotwave 300
This error will be caused by a jamb inside the cutter assembly of the lower roller drawer. Remove the two black Torx screws at the left and right sides inside the lower paper drawer. Next remove the galvanized cover. You should then be able to see the edge of the paper. Grasp it firmly with a pair of needle nose pliers and pull straight up and out. Clear your errors and commence printing.
Posted on May 03, 2013
nick_west12915
Oce Guy
  • 217 Answers
SOURCE: Hi i have a problem with oce plotwave 360 give me an error NO COMMUNICATION WITH CONTROLLER - 95 please help me what i need do
The controller is on the left hand side of the printer. Most likely there is a problem with the controller and you have to call an authorized Oce representative to fix it. This has proprietary software and hardware in it and the hard drive contains your license which is tied to the hardware address of the motherboard on the controller.
Posted on Jun 13, 2017
Plotwave340 what is error 12535?
Oce PlotWave 340 User Manual Page 374
I didn't find error 12535 may be this user manual will provide some help. it is a searchable link.
https://www.manualslib.com/manual/573016/Oce-Plotwave-340.html?page=372#manual
Sep 05, 2018 | Office Equipment & Supplies
OCE PlotWave 300. Error 8130. Hello, OCE PlotWave 300. Error 8130. What it for an error and how to get rid of it?
Fuser Temperature Protection Circuit Failed. Turn off the printer completely. Power off in front, and turn off main power at right, rear, bottom and unplug from the wall. Open up the fuser and take off the right hand cover. This is High Voltage. If you are uncomfortable with risking your health, do not proceed further. You will see 4 connectors (black, usually but with red insulators) that plug into the right hand side of the fuser. Unplug them and check the connectors as well as test if they are seated correctly. Ensure the red insulating jackets are pushed toward the connectors. IF everything looks OK, and the printer still exhibits this error code you will have to call an authorized Oce service technician.
Jun 07, 2018 | OCE Office Equipment & Supplies
Error code 5106 on Oce Plotwave 500
Extreme Toner Low ADC. If you filled up the toner and this still doesn't work, it could be a whole list of other smaller components that would require a whole lot of explanation and instruction to remove safely. Its best to call an authorized Oce service technician to check this out.
May 10, 2018 | OCE Office Equipment & Supplies
Hi i have a problem with oce plan printer 500 it gives me error code 03504 please help me what i need to do
Oce (Canon) makes 3 different types of "500" plan printers. The ColorWave 500, the PlotWave 500 and the old TCS 500. If you mention the proper model number you might get a faster answer. If you have the TCS500 this is a head calibration error. Was a printhead recently replaced? If so it is more that likely that either the plastic seal was not completely removed from the new printhead, or there may be some ink on the contacts on the inside of the printhead socket. Reinsert the printhead in question, and see if this solves the error. Power down the printer and unplug it from the wall. Clean the inside of the printhead socket with a long swab and some isopropyl alcohol. Plug in and power on the printer after replacing all printheads. On extremely rare occasions brand new printhead do fail, so if you have determined you might have a faulty printhead, replace it with another.
Feb 08, 2017 | OCE Office Equipment & Supplies
Oce 500 plan printer error code 03504
Hi i have a problem with oce plotwave 360 give me an error 22552 we change the sd card but still have the error
Hi i have a problem with oce plotwave 360 give me an error (NO COMMUNICATION WITH CONTROLLER - 95) please help me wath i need do
Apr 19, 2015 | Office Equipment & Supplies
I have an Oce Plotwave 300 giving 22529 errors. Have replaced the spider board and usb cables. Any suggestions ?
Clean the paper tray, rollers, and clear any jams. The OCE Plotwave, being a large scale printer (used for posters and the like) is prone to jams and gumming up of the rollers. The error occurs when the paper doesn't move along properly and the sensors that read the surface and adjust the paper can't get it to adjust. Other issues can cause the same generic error. This includes incorrect PIN settings on the mainboard (some of these printers have PIN controllers that determine if it will read a certain way). It could be a read/write error in the USB control board (check to make sure all ribbons are correctly seated and all connections are making proper contact and are in the right ports). I suggest trying the OCE cleaning tool to see if that helps. Oc PlotWave 300.
Jul 31, 2014 | Oc Plotwave 300 Developer
OCE PLOTWAVE 300 ERROR CODE 8510
JAI UN PROBLEME AU PLOTWAVE 300 MARQUE OCE
CODE ERREUR 8510
C QUOI LE PROBLEME ET C DU A QUOI ET QUESQUE JE DOIT CHANGER
MERCI
REPONDEZ PAR EMAIL
[email protected]
Jun 27, 2012 | Office Equipment & Supplies
Top OCE Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ngoro
JMJr
Are you an OCE Office Equipment and Supply Expert? Answer questions, earn points and help others
