How to fix pedestal onto electric fire or instructions for Inoccenti pedestal /wall mounted electric fire please
5 Suggested Answers
Anonymous
  • 11 Answers
SOURCE: Is this TV wall mountable?
Just mounted this TV this past weekend...Used Peerless flat panel wall mount bought on Ebay for $39.99 free shipping...Remove the stand by removing the 4 small screws on the back of the tv where the stand connects...then slide the stand off from the bottom...VOILA
Posted on Aug 04, 2008
SOURCE: Need another Pedestal
You can find the original stand at Discount-Merchant here:
http://www.discount-merchant.com/SearchResults.asp?Search=mintek+stand
Pretty cheap.. like $33 or so.. Good luck.
Posted on Oct 25, 2009
roety
Eric Rotmil
  • 587 Answers
SOURCE: We had the tv mounted on the wall and now want to
Hi my name is Roety,
I can help you with your issue ,
The pedestal slides up into the back, and is held by 4 or 6 screws thats all
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Posted on Nov 09, 2009
Jaime Hernandez
  • 2337 Answers
SOURCE: We threw away the TV pedestal and used the wall
I might have one from a 42" maxent plasma that could fit on your plasma.
I will measure it and post the the dimentions if you're interested.
Posted on Apr 24, 2010
MayorBill3
SOURCE: removal of flat screen pedestal so I can wall mount tv
There a 4 set screws on the back of the TV. There is actually an arrow pointing down to show you what direction the pedestal. Remove thesze screws and the pedestal comes right off.
Posted on Dec 27, 2010
How do I remove the base pedestal plate from our Conia CL3201FHD television so we can wall mount it?
most have a trim plate at the back of the stand that when removed shows up 4 screws that can generally be used in the wall mount bracket holes
Dec 12, 2015 | Televison & Video
Fix pedestal for samsung 740BF
you can buy a wall mount for under 12 bucks. Or alternately you can buy an VESA 100 mm compatible stand for about 30 bucks
There're are out there lots of solutions for LCD, arms for mounting in desk, wall or poles.
Mar 22, 2014 | Samsung Computers & Internet
I would like to remove the pedestal or stand from a LG 42LG70 TV because I want to place the TV on a wall mount.
Usually the safe way to do this is look first at the owner manual but lay set face down on a padded surface so all weight is on the frame around the screen and no weight on the screen itself, exert no downward pressure in that position or screen may be damaged.
Usually pedestal is secured by 4 or more screws that may require the back cover of the set to be removed first, to get at---a careful look with it face down will show if part of the pedestal is under the rear cover of the set or not.
Dec 18, 2012 | LG 42LG70 42 in. LCD HDTV
I can't remove the stand off the tv
Hi, i have instruction on removing your base stand.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
Note: Extreme care should always be used when removing
the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3) Remove the four screws shown in the diagram below. This will
allow removal of the pedestal stand.
4) Once you have removed all four screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
Feb 12, 2011 | Toshiba REGZA 52RV530U LCD TV
Installation instructions for a Glacier Bay Westminster pedistal sink
Things You'll Need:
  • channel lock pliers, mini tubing cutter, tubing cutter for 1 1/2" tubing razor knife, 24"level drill, 3/16"dia. drill bit
  • 3/8" drive ratchet and sockets, tape measure, Teflon tape, 8" adjustable wrench, black sharpie, small edges (cedar wood shakes) 3/8"x 3" anchor bolts, pedestal sink, faucet with pop up drain, P-Trap,
  • sponge, rags,
  • lavatory supplies
The location for the pedestal sink will need to be prepared for installation. Wood backing has to be installed behind the drywall to give the pedestal sink something solid to attach to. Don't skimp on this wood you want enough wood so the sink doesn't move the wood by someone leaning on the sink. Use the dimensions from the installation instructions or set the basin on top of the pedestal and measure for the location of the wood to be installed.
  • Step 2 The drain for the sink needs to be set just right so that the finish work will go together easier. When setting the drain make the threads for the trap adapter stick out just past the finished wall. If the threads stick out to far then the escutcheon will not fit up tight to the wall. So check the depth of the trap adapter threads before putting the sink in place.
  • Step 3 Press the small foam pads adhesive side down on top of the pedestal. With the faucet and pop-up drain mounted on the basin place the basin on top of the pedestal. Move both pieces together up against the wall with the drain centered with the sink. Check the pedestal for level. If it is not level use the cedar wood shakes as wedges to make the pedestal level. Don't cut the cedar shakes yet this will be done later. Now adjust the basin to make it level as well. With the sink centered and level mark the points where the anchor bolts will go through the china into the wall. Many pedestal sinks come with a wall mounting bracket if yours does then slide the bracket up under the sink and make it tight up against the wall and the china. Be careful not to move the basin, if you have someone to help you have them hold the sink in position while you're doing this. Now mark the holes in the bracket where the anchor bolts will hold the bracket to the wall.
  • Step 4 Move the pedestal sink out of the way. Use the drill with the 3/16"dia. drill bit to drill pilot holes on the marks that you made. Next screw in the anchor bolts into the pilot holes. Make the wall mounting bracket tight to the wall. The anchor bolts that go through the china need to be removed.
  • Step 5 Take the lavatory supplies and wrap the tops of them with Teflon tape. This will create a gasket like seal. Attach the supplies to the bottom of he faucet. Make sure to get a good tight connection you don't want these to be leaking later on. Next take the J-bend portion of the P-trap and slip it on the tailpiece of the pop-up drain. Measure the height of the center of the drain where it sticks out of the wall. With the basin sitting on top of the pedestal put the p-trap together and make the trap arm the same height as the drain pipe. Mark the top of the J-bend on the tailpiece so you have a reference mark. Next take the basin off of the pedestal and tighten the slip nut on the J-bend. Make this connection secure it will be very difficult to get to this connection later on.
  • Step 6 Move the pedestal into position and set the basin on top of the pedestal. Check the small adhesive pads if they have fallen off stick them back in place. Line up the holes in the china with the holes in the wall and screw in the anchor bolts. Don't tighten these yet you still have to adjust the basin and level the pedestal. Put the cedar wedges back in place to level the pedestal and adjust the basin. Now that everything is level tighten the anchor bolts. Be careful not to over tighten the bolts they could crack the sink.
  • Step 7 Use the tape measure2_bing.gif and measure from the center of the J-bend opening to the trap adapter. Add about 1 1/4" to this measurement so some of the trap arm will be inside the adapter. Cut the trap arm to length with the tubing cutter. Next slip on the slip nuts and washers and don't forget the escutcheon. Install the trap arm. Catch the slip nuts with your fingers and tighten as much as possible by hand. Tighten the rest of the way with the channel lock pliers. You'll notice the first nut on the J-bend is almost impossible to get to that is why you must tighten it before you set the sink.
  • Step 8 Take the lavatory supplies and gently bend them to line up with the supply valve connections. Now mark the supplies where they will fit into the compression joint on the valves. Use the mini tubing cutter and cut on your marks. Slip the compression nuts and ferrules onto the supplies and put the supplies into the valves. Catch the nuts with your fingers and tighten by hand. Now finish tightening with the adjustable wrench2_bing.gif.
  • Step 9 Remove the aerator from the spout of the faucet. Turn on the hot and cold supply valves and run the water in the sink to flush out the lines. When the water runs clear put the aerator back into the spout. Close the pop-up drain and fill the basin with water. While it is filling check underneath the sink for any leaks and repair them if necessary. When the basin is full open the pop-up drain and let the water out. Check under the sink once more for any leaks and repair them.
  • Step 10 Use the razor knife to cut off the excess cedar wood that sticks out past the china on the pedestal. Next caulk around the base of the pedestal where it meets the floor. Also caulk along the top edge of the basin where the basin meets the wall. Dampen the sponge and wipe off the excess caulk to make a smooth caulked joint. Clean up and admire your handy work.
  • Mar 30, 2010 | Pegasus Technologies Home
    How can I remove the the stand so I can mount it on the wall
    1)Carefully lay the front of the unit face down on a flat,
    2)Remove the jack pack cover on the back of the TV to expose
    without tools.
    3)Remove the five screws shown in the diagram below. This will
    4)Once you have removed all five screws holding the pedestal
    5)Now you are ready to install the wall mount brackets
    I hope this helps and good luck!
    Feb 28, 2010 | Toshiba 32HL67 32 in. LCD Television
    We had the tv mounted on the wall and now want to mount uit back on the pedestal. We have the pedestal but seem to be missing the piece that locks the tv into the pedestal
    I will reply asap
    Thanks
    Nov 09, 2009 | Samsung LN-S4095D 40 in. LCD HDTV
    Try to mount TV to the wall and need to release the TV stand
    To Display your LCD TV using a Wall Bracket:
    If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
    37HL17: 46.3 lbs (21.0 kg)
    42HL17: 59.5 lbs (27.0 kg)
    1) CAUTION: Two people are required for installation.
    2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
    3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
    4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
    1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
    2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
    3) Remove the five screws. This will allow removal of the pedestal stand.
    4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
    Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
    Pedestal Stand for an NEC plasma 42in
    I have a stand and I want to convert to a wall mount...can we trade?
    May 03, 2008 | NEC PlasmaSync 42MP3 42 in. Television
    Televison & Video Logo
    21 people viewed this question
    Top Televison & Video Experts
    Marvin
    Marvin
