Everything is working threw washing powder in it washed the clothes then rinsed it then it spinned when it was finished we struggled to get the door open of the oko lavamat 508 front loader washing machine
ginko
Ginko
  • 19396 Answers
SOURCE: oko-lavamat 6200 washing mashine does not rinse
When this happens it is usually a problem with the timer. By replacing the timer/programmer you should be able to fix it.
You can find parts here:
If you input model number on this website you will get replacement parts price.
Posted on Jul 13, 2008
I turned the Bosch Series 4 washing machine knob to the off position too soon after the load had finished washing. How do I now open the door?
Most washers will not unlock the door if it senses any water inside, select drain and spin or rinse and spin to rinse the clothes and drain the water. Once it has completed the cycle the door should unlock. If it does not there is usually an emergency release on the look lock inside the machine by removing the top or front panel.
Dec 03, 2017 | Bosch Washing Machines
Why does my whirlpool model WTW57ESVW1 starts to rinse toward the end of the spin cycle?
The rinse is supposed to start during the spin...it's what removes most of the soap from your clothing! The spin forces the water through the clothes, flushing all but a small amount of the detergent away. The rinse cycle itself is more to remove solid debris that may have become trapped in the folds of cloth. It does so by floating and agitating the clothes.
The quick wash cycle is only for things that aren't soiled much, that you need to be done fast. It's not for everyday washing, just for things that maybe need no more than a freshening up. It makes it faster by cutting corners.
Sep 06, 2014 | Washing Machines
Start matsui washing machine
Check the washer drain hose for clogs.
Jun 19, 2017 | Washing Machines
My FP washing machine has starting leaving brown sludgy marks on my clothes. Do I need to descale the machine? Im in New Zealand and the water isnt particularly hard. Thanks for your time, Emma
I'm guessing you use fabric softer....Get some finish dishwashing powder and put a wash on with high water level with no cloths in it. let it do it's normal wash but before it drains any water out, pause the wash let it soak over night. next day unpause it and let it finish. Repeat if needed and do the same thing again with out any dishwashing powder in it to make sure it rinses all the soap out.
The black sludge is cause by using fabric softener. The costic in the finish powder will eat in to the sludge and soften it. If its really baked on it my need to soak for longer, more powder or it may need to be stripper and cleaned.
Mar 22, 2011 | Fisher and Paykel Washing Machines
Finished, wash and spin lights flashing. Door
I just had this problem! To get the clothes out, open door manually (follow answers on other threads here about opening toe panel and gently pulling down on door release). But as it turned out, I didn't need to remove the clothes, and now my washer is working again.
A local repairman gave me this advice over the phone. Make sure dial is switched to off. Unplug your machine, then plug it back in. Hold down the rinse and delay buttons with one hand. With the other hand, switch the dial from off to cold or warm or whatever cycle you want. All the buttons flash a few times, then just the start button flashes. The second time I tried this, my washer worked afterwards. I've done several loads today with no problem.
Jul 19, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Not spinning with clothes in it , but its fine when empty??????????????
Could be too much washing powder, excess washing powder holds water in the clothes and makes the load too heavy to spin.
Try washing a load with NO washing powder (if this is the case there will probably be enough residual powder to wash the clothes anyway).
Follow the correct amount of powder/liquid, more is not better, just wears out your machine.
Oct 19, 2009 | Washing Machines
White marks on my clothes.
Are you using TOO much powder? And is the machine set to the correct rinse tempature? You mention white stuff, does it look like undissolved washing powder? Or fabric softner? Possibly try liquid detergent and see if the problem continues. And follow the recommended amounts of detergent for each wash load, and the tempature settings. And of course the water levels. All of the above are crucial to insure you get maximum preformance and utility out of your machine, with the results you expect. Let us know what you find. Kindest Regards, Slats.
Sep 26, 2009 | Washing Machines
Rinse cycle does not work on washing machine
Sounds like a belt or clutch issue. What is the make and model #?
Nov 02, 2017 | Kenmore Washing Machines
Washing machine does not wash clothes
You are possibly washing at the wrong temp, or not using sufficient powder or detergent.
The m/c is not rinsing properly, check that it is pumping o/k.
If there is a build up off slime and mould on your door seal, then you are definately washing at too low temp.
At least every 4 to 6 weeks, do a high temp wash with powder in but no clothes.
This is called a maintenance wash and helps to keep the inside parts clean..
If your door seal is stained, clean as best you can with a scourer pad or similar. You will not hurt the seal.
plz rate my solution .
Thanks.
Dec 17, 2008 | Washing Machines
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
