Question about LG Televison & Video
I recently replaced one led strip on my lg tv. I got everything put back together & now on a quarter section of the screen its purple tinted. Any ideas why that could be?
    Top Expert:
  • LG Master
  • 30,888 Answers
Here is a question that we see often.
Question:
I've replaced everything in my television because it previously had a black screen with no lighting. Now it doesn't turn on at all and all I have is audio. What could be the cause ?
So your television stops working properly and you think it must be easy to fix, because you can buy boards on eBay, and you can watch YouTube videos. So you make a decision, you buy a board and you fit it, but the television still doesn't work! This is a classic case of the 'let's try replacing this' method of television repair and illustrates why it is a bad idea. It doesn't work for a number of reasons. To correctly diagnose issues, you need to know every board, what is does and every component on the board. You need to know which part has failed, replace the component, or replace the board. The parts you purchased off eBay were probably out of scrapped sets and not tested. The part your put in was dead when you put it in, so you just moved on to another guess at what might be the cause and replace a board that is fine. And so it goes on, you change all the boards and it still doesn't work. Did you notice the large print that says 'No Refunds, NO Returns'. This is to stop you sending your old one back and saying it didn't work, but the unscrupulous use it as an excuse to get money for selling items that may not work! The course to be a television engineer is 2 years full time education, take it to someone that knows how to diagnose and fix. It is by far the cheapest option. The part that failed might be a 20 cents fuse diode hard soldered to a board. They will charge you $2 parts and an hours labour.
Posted on Jan 24, 2020
5 Suggested Answers
Anonymous
  • 337 Answers
SOURCE: Purple tint on screen
Color splases can show up when the sets are move from one location to another or when they have been dropped while moving it,another reason is when a speaker is placed to close to the tv.The tv has an internal demagnetizer witch gets activated when you turn the tv on,I suggest to unplug the unit for about 15 minutes and then plug the unit and turn it on,If the unit was dropped this problem might not be repairable.I hope the information helps .
Posted on Oct 02, 2006
Anonymous
  • 556 Answers
SOURCE: Green and purple tv picture.
this is degaussing problem
keep tv off for half an hour and if you have changed the direction keep it as it was.
if any magnetic thing is there near to tv remove it like speaker or headphone etc.
hope this will help.
Posted on Oct 15, 2007
Anonymous
SOURCE: My tv is turning everything purple like it is magnatized or something.
In English: 1-800-222-7669 or 1-888-772-7669
Hours: Mon-Fri 9:00AM-10:00PM / Sat-Sun 10:30AM-7:15PM EST
Call sony at this number and tell them what your tv is doing? If it is like mine they will replace the optical block. It seems that Sony will cover parts and labor if you do it before the end of the year. If the numbers don't work just go to sony's website and check for warranty or support information
Posted on Nov 15, 2007
Anonymous
  • 12 Answers
SOURCE: DS Lite repair worked, but only until I put it back together
You may have some pressure somewhere that it shouldn't be. The electrical tape takes up space, and could be taking space that is not there when the console is assembled. Or you keep knocking a connection loose when you put it together.
Try it while it's on. If the console crashes or dies at any point, whatever step you were in the middle of is probably causing that problem. Just make sure not to get anything in it while you were, and don't touch any electrical parts, in case you accidentally short something.
Posted on Dec 19, 2008
PLEASE HELP ME!!! OK I bought a LG 55LB5900UV knowing the screen would flicker on for a second and stay black for 5 seconds then flick the screen on for 1 second and repeats as long as the TV is powered...
They must have a good connection, not just taped together.
I doubt the LEDs are at fault, it is usually the power supply for the LEDs that fails.
Aug 10, 2018 | LG Televison & Video
LG Tv backlights won't come on. Replaced bad LED strips and did not fix. Should I move to replace power supply/LED driver?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
{View the site in web view or by a desktop to see the search box. Mobile view has no search box.}/
Jun 28, 2018 | LG Televison & Video
My LG tv model number 42LN5400-UA no picture
It is a common problem for the LG 42/47 LN series LED TV, the problem is defective LED back lights strip (strips).
You have to open the display panel to find the bad one & replace it. The part number usually is printed on the strips, read 6916L-11XXA, you may purchase it from EBay.
Aug 11, 2017 | LG Televison & Video
If I replace the LED driver, do I also need to replace the back light strips?
Hello, those sets are notorious for the LED strips failing. I have replaced dozens of them. If your going to replace them, be sure you replace them all! Pat # is LC420DUE-SFR1 LED Strips. Thanks
Apr 27, 2017 | LG Televison & Video
I have an LG 47LN522-UB LED TV that stopped working after three years and need help diagnosing a problem with it.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 26, 2017 | LG Televison & Video
I have a LG 47ln5700 smart tv. The screen goes black but the sound still works. I replaced the LED strips and the tv worked for about 4 hours and then the same thing happened. Any suggestions?
Bad power supply board can burn out those led strips. Recommend replacing both board and strips at same time. Lg 47LN5700 UH TV Parts
You can order most of the parts here.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Jan 11, 2017 | LG Televison & Video
LG LED LN5200 3 LED strips flash 3 do not. I do have sound and can see screen with flashlight and red power LED flashes 3 times.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Dec 25, 2016 | LG 47 Inch LED TV 47LN5200 LN5200 Series...
My TV backlight started to get dim and splotchy a few weeks before it failed. Do I only need to replace the LED backlight strips on my LG TV?
Nov 05, 2016 | LG Televison & Video
LG Flatron W2234S 22 purple tint problem
your LCD monitor has bad ccfl lamps or inverter circut..
May 08, 2010 | LG 22" FLATRON LCD Monitor
No red tint on TV screen
check the CRT section if there are resistor open,transistor drive of red color is leak,resold the red section of the CRT.
Sep 06, 2008 | Televison & Video
Televison & Video Logo
29 people viewed this question
Ekse
RONALD CARTER JR
