Question about Ricoh Office Equipment & Supplies
Ricoh dx3243 says insert ink even thou ink is there.when I change with new ink it will try to replenish ink in the drum but fail and say no ink. what could cause this, please help
5 Suggested Answers
Anonymous
SOURCE: change drum soon will not clear after new drum inserted
Reset of the drum counter
Open the front cover.
Press the Options key on the control panel.
The display will show "REPLACE DRUM - 1.YES 2.NO".
Press 1 to reset the drum count.
Close the front cover.
Hope this helps...
Posted on Jun 12, 2008
eric moirez
  • 134 Answers
This machine is reset with a plastic sheet that come in the new drum unit. When the drum is inserted for the first time, the sheet slides out and trip the exit sensor in a certain way. Then the counter is cleared. If you still have this clear plastic sheet, then you can reinsert it into the top of the drum unit and try it again.
Posted on Jun 30, 2008
Anonymous
  • 5 Answers
SOURCE: my cannon printer pixma ip1800 cannot detect ink pls help me...
If after you install the cartridge you get a yellow light and error message:
“The following may have run out of color. The function for
detecting the remaining ink level will be disabled since the
ink level cannot be correctly detected. If you want to
continue printing with out this function, press the printer’s
start button. Canon recommends using new genuine Canon
cartridges in order to obtain optimum quality.”
Do not click “cancel printing”. Press printer start button
to start printing. This action will bypass the ink level
detection from the recycled cartridge. It will not damage the
printer! With a recycled cartridge this action needs to be
done one time.
A full recycled cartridge ink level may not display correctly.
It may show empty.
If you want to check the ink level, you can do a “Nozzle
check” by follow the directions below:
Go to menu File select print click on “Property” click
on “Maintenance”
Click on “Nozzle check” to print out the color check.
Click on “Cartridge Alignment” to align the cartridge.
See pictures for above process at Inktelligent ip 1800 topic
Also the refills refered to above are at the IP 1800 inkfilling page
Posted on Feb 23, 2009
Anonymous
  • 92 Answers
SOURCE: Shows black ink empty after new cartridge inserted
Replacing the cartridge should resolve this problem: Follow these steps to replace the cartridge:
Installing / Replacing the BJ Cartridge Follow this procedure to replace the BJ cartridge:
1. Make sure the MultiPASS is plugged in.
2. Open the document tray.
3. Lift the document guides to open the ADF (Automatic Document Feeder).
If the ADF (Automatic Document Feeder) does not open easily, slide the document guides outward and then open the ADF (Automatic Document Feeder).
Or slide the Document Feed Lever to either the automatic or manual setting.
4. Pressthingtopress.gif. If installing the BJ Cartridge for the first time, skip to step 6.
Caution: Do not try to manually move or stop the cartridge holder since this may damage the unit. Do not touch the components shown or any metal parts since this may adversely affect operation of the unit and/or affect print quality.
The MultiPASS has an automatic protection feature that helps keep it from overheating. If the cartridge holder does not move, unplug the MultiPASS and let it cool for several minutes. Then plug it in again.
Press thingtopress.gifto move the cartridge holder.
5. Raise the blue cartridge lock lever on the cartridge holder and remove the BJ cartridge.
Caution: Discard the old BJ cartridge immediately according to the local laws and regulations for disposal of consumables.You may want to place it in a plastic bag to keep any residual ink from spilling. Spilled ink can stain any surface; protect yourself and your work area. If removing a BJ cartridge to use one of the optional BJ cartridges, be sure to store the BJ cartridge in the container provided with your MultiPASS. Otherwise the ink will dry and affect print quality.
container.gif 6. Remove the new BJ cartridge from its package, then remove the orange protective cap (1) and tape (2).
Caution: Discard the cap and tape. Never attempt to reattach them to the BJ cartridge print head. Install the BJ cartridge immediately after removing the cap and tape. Spilled ink can stain any surface; protect yourself and your work area.
7. With the label facing outward, insert the BJ cartridge into the cartridge holder. Lower the blue cartridge lock lever until it locks into position.
lockinpos.gif 8. Press thingtopress.gif.
The cartridge holder moves to its home position on the right side of the unit and begins cleaning the BJ cartridge print head. This process takes about 55 seconds.
9. Close the ADF (Automatic Document Feeder).
10. Close the document tray.
Note: If you need to unplug the MultiPASS, wait until the unit is in standby mode (date and receive mode displayed in the LCD). Otherwise the cartridge holder may not be in its home position causing the BJ cartridge to remain uncapped and dry out.
Posted on Apr 29, 2009
Derek
  • 68 Answers
SOURCE: I have a Ricoh GX 3050N printer. It says
you will have to change all the cartridges together then power cycle the printer to run initilization to reset the toner condition.
if this resolves your issue please rate my answer accordingly
regards
Posted on Sep 14, 2009
Remove and check cartridge on right stays on even thou it is a new cartridge
what kind of printer is it? some have a Ink Reset mode that needs to be run.
can you give me the Model number please
Feb 08, 2011 | HP Office Equipment & Supplies
Camera says memory full, even thou I have put in a brand new memory card?
With the card out of the camera, go into the menu and find "format"...follow the on-screen instructions. Then, insert the card and do the same thing.
Feb 25, 2010 | Samsung NV3 Digital Camera
Door open error even thou door is closed
check the door closure sensor on the main hatch, it may be clogged with paper dust or the ink cartridge may not be fully inserted causing the door the be ajar ,causing the error.
Jul 14, 2009 | HP LaserJet 1300 Printer
The ds works, but it shows that there is no ds
you can buy an r4 somewhere so the games will work propaly
Jul 11, 2009 | Nintendo DS Lite Console
I get a message that says ink collector almost full. I cleaned it and i replace it. But i got always the message :"inkcollector is not set. replace inkcollector". What have to do ?
After you replace the ink collector there is a counter you have to reset it to tell the printer that you are inserting a new collector
Jun 09, 2009 | Ricoh Aficio GX3050 GelSprinter
Ricoh 4420L ink isn't fusing to paper
If you are using regular fax paper, the paper is fed in up side down-real fax paper does not use ink-it uses impressions and the paper needs to be flipped upside down.
Mar 16, 2009 | Ricoh Office Equipment & Supplies
I am totally lost on how to add more toner to the
You can go here and download the manual. Even though it's a Gestetner...it cross references to a Ricoh Aficio CL2000. Ricoh builds all of their machines. Look for it under "printers"..."color":
http://www.ricoh-usa.com/downloads/manuals.asp?tsn=Ricoh-USA
I don't know if this will solve the "blue ink everywhere" problem
*Please rate me :)
Mar 14, 2009 | Gestetner Office Equipment & Supplies
I have a Ricoh G7500 printer that is giving me an ERR-990 when I turn it on. I don't see any documentation on Ricoh error codes.
990 A Waste Tank Full Sensor Defective
The waste ink tank full sensor (a
photosensor) on the corner of
the waste tank is not operating.
• Waste ink tank sensor on the corner of
the ink waste tank is defective.
• Replace the waste ink tank.
Aug 23, 2008 | Ricoh Office Equipment & Supplies
44 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
