The instructions say to press the SET button to program. I gave searched the remote and internet and there is NO SET button! How do I get the remote into program mode??
5 Suggested Answers
Anonymous
  • 50 Answers
SOURCE: emerson tv codes for GE RM-24930 4-Device Universal ...
check this site for your codes. (Jasco is GE)
http://www.jascoproducts.com/support/universal-Remote-codes.asp
Posted on Nov 18, 2007
Anonymous
SOURCE: TVTECH Universal Remote (3 Devices)
i got a universal remote it dont have my code in the book i have a durabrand tv do you have any i deal what the code is
Posted on Dec 31, 2009
Anonymous
SOURCE: TO CHANGE PULSE MODE TO TONE MODE- INSTRUCTIONS ON
-Press "Program button"
-Press "AUTO" buttton (Just left to the "TALK ON/OFF")
-Press "*" two times
-Press "Program"
Along BEEP sound will come. That's all..!!
Posted on Feb 16, 2010
Anonymous
SOURCE: RCA Universal Remote Programming Instructions RC800L-C 1239
if u do not have the code most universal remotes will allow you do it manually and you will have to follow these steps and insted of putting the code you can turn the tv on then press the on/off button on the remote till the tv shuts off then press enter
Posted on Mar 02, 2010
Chunghop E-T908 Does anyone have clear instructions on programming this remote for a TCL HD TV?
Denis, google search instructions for remote, make and model # instructions. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Program an RCA Universal Remote Using Manual Code Search
GE Universal Remote Codes
How to set up universal remote
universal remote instructions Google Search
Jul 19, 2016 | Televison & Video
How do I program a dvd code into my crk76ta1 remote and what are the codes to a toshiba dvd
Hi, i have found the codes and instructions.
Toshiba Codes - 2015.2049, 2051,2055, 2065, 2093, 2116
I. Turn on the component to be programmed.
2. Press and hold the button on the remote you want to program.
3. Enter the code from the code list.
4 Release button, and then press ONeOFF to see if the component responds to the remote commands. If it doesn't, try pressing the component button and then ONeOFF again.
5. If you get no response, repeat these steps using the next code listed for your brand, until the component responds to the remote commands.
If none of the codes work then try a code search. Instructions below.
The following instructions can be used to program the remote to control each of the devices connected to your TV. If you want to exit the automatic code search without programming any of your devices, press and hold CLEAR until the LED turns off.
I. Turn on the device you want to control (VCR, SAT, etc.)
2. Press and hold the button you want to program (VCRI, VCR2, etc.) While hold'Ing the device button, press and hold ONeOFF until the red light on the remote turns on, then release both buttons.
3. Press and release PLAY, then wait 5 seconds or until the LED stops flashing. At this point the remote is searching for the correct code to program. If, after 5 seconds, the device you want to control does
not turn off, press PLAY again to tell the remote to search the next
set of codes. Continue pressing PLAY until the device turns off or you have searched through all of the codes. There are 20 total sets of codes. If the device does not turn off after pressing PLAY 20 times, then the remote cannot control that particular device. If the device you want to control does turn off:
I . Press and release REVERSE, then wait 2 seconds. Repeat this step until the device turns back ON.
2. To finish, press and hold STOP until the red light on the remote turns off.
Feb 12, 2011 | RCA Televison & Video
One for all urc2060 need codes for sharp tv
Enter your model of the tv and search for the tv manual.... http://www.sharpusa.com/CustomerSupport.aspx
OR
The following will take you to the instructional pages for the remote. Start with one of the two links below.
Your remote will set up in one of the following ways:
Set Up #1
  1. Press the button for the device you want to program, then release.
  2. Press and hold the Magic button until the red LED gives a delayed blink.
  3. Continue holding the Magic button while you enter your 3 digit code.
  4. You should receive 2 quick flashes after entering your code.
Look on the back of your remote for the instructions. If they match these, press here for more instructions for his remote.
Set Up #2
  1. Press the button for the device you want to program, the release.
  2. Press and hold the Magic button. You will see two blinks on the remote. Release.
  3. Press the three digit code for the device you want to program.
  4. You will see two blinks. Your remote is now programmed for that device.
Look on the back of your remote for the instructions. If they match these, press here for more instructions on this remote.
Feb 06, 2011 | Universal Remote Control
TRYING TO PROGRAM REMOTE IT IS A RCA REMOTE LOST INSTRUCTIONS TO REMOTE.
HI, Direct Code Entry:
Find the code your device.
1. Press and hold "CODE SEARCH".
2. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
3. Enter the 3-digit code number.
4. Release "CODE SEARCH".
5. With the device on, press another button to test (volume control/power button).If it does not work, repeat steps 1 to 5 with other codes which you have.
follow the below steps to set remote without codes
Code Search: 1. Turn on the device you wish to control.
2. Press and hold "CODE SEARCH".
3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
5. Press ON/OFF repeatedly until the device turns off.
6. When the device shuts off press and release ENTER.
7. Try using the remote. If it does not function repeat steps 1 through 6
To Get The Code Please Go To Below Website:
http://www.rcaaccessories.com/remotefinder/
You need to select the following information from the drop down list
1.Model of the remote 2.Type of device to which you want to program(TV/DVD/VCR)
Thank you
Nov 08, 2010 | RCA Universal Remote Control
Need to program my rca universal remote to myTOBISHA TV .the remote style # is RC27A. I dont have any instructions and have no idea how to program it.
HI,
Direct Code Entry:
Code Search:
Thank you
Sep 13, 2010 | RCA 3-Device Universal Remote
I have codes but dog chewed up the instructions part. Lol. Please help with instructions to program remote 311b to tv. Thanks very much
HI,
Direct Code Entry:
Code Search:
Thank you
Sep 12, 2010 | RCA RCR311B Remote Control
I need instructions and codes for Innovage Jumbo Remote
www.remotecentral.com
This is a link for a list of codes.
or
Code search setting is an alternative method to programming your device without using the code list
Turn on the device you want to set
Aim the remote control at the device
Press the decive button for the item you want to program
Press and hold the SET button until the LED light up solid red
Press the MUTE/SEARCH button. The LED will shut off first then light up solid red.
When the device turns off, press the OK button to store this code.
Code Retrieval
Press and hold the device button you want to display on the remote control
Press the NUMBER 1 then count the number of flashes
Press the NUMBER 2 etc
Press the NUMBER 3 ets
Press the NUMBER 4 etc
If the LED light flashes 10 times the number is 0
Nov 11, 2009 | Innovage Jumbo Remote Control
Need to program a new remote for RCA TV
Programming Your Universal Remote.
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
  • TV-000
  • VCR-000
  • Cable Box-000
  • AUX is programmed with VCR code 037
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
For more info, copy and paste this link in your address bar so you can get codes for you remote:
http://www.thompsontv.com/rcarc.html
Aug 24, 2009 | RCA Universal Remote Control
Proteam jumbo universal remote
Turn your device on.
Hold down the set button and press the button of the device you want to program (e.g. TV) then release the set button.
Press the set button again and the red light will start flashing.
Press the power button repeatedly until the device switches off.
This is now the correct code.
Press the device button once more to set the code in to the memory.
Hope that helps.
Nov 07, 2008 | Big Button TV Universal Remote
Code
Orion Code is 035
The Instruction given is for programming a remote to control a TV set. Please substitute CABLE or VCR in place of TV to program for other devices.
1.Find the three digit code(s) for your TV set.
2. Manually turn on the TV set.
3. Press and hold the CODE SEARCH button until the indicator light is lit. Then release the CODE SEARCH button. (The indicator light is located above the TV button).
4. Press and release the TV button. (The indicator light will blink and then remain lit).
5. Enter a three digit code found at step 1 using the Number Buttons.(After the code is entered the indicator light will turn off).
6. Aim the remote at your TV. set and press the OFF/ON button. If your TV. set turns off, then proceed to step 7. Otherwise, repeat step 3 to 5 using the next code on the list. Press CHAN up button to double check for accuracy of the code. the programming is complete if the TV set responds by going up a channel. Otherwise repeat steps 3 to 6 using the next code on the list.
7. Press CHAN up button to double check for accuracy of the code. the programming is complete if the TV set responds by going up a channel. Otherwise repeat steps 3 to 6 using the next code on the list.
8. Try the code search method If there is no more code left to try.
Dec 16, 2007 | Televison & Video
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
