Question about Maytag Washing Machines
Maytag Maxima XL, Mod. MHW6000AWO. I get error rL during "Clean the Washer" cycle. The drum is empty, BTW. Is there a control board reset? If not, what is the best workaround?
5 Suggested Answers
shawnryan111
  • 121 Answers
SOURCE: Maytag Washer LA7300 Water leak bottom of drum
This page will help http://www.appliance-repair-it.com/Maytag-tub-seal.html
Posted on Sep 03, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: My empty washer keeps giving me an rl error while
The rl code is displayed when the control detects a load of clothes in the washer during the clean washer cycle.
This code should only come up when you're trying to run a clean cycle.
There can be two causes for this message if there are no clothes in the washer while you're running the clean washer cycle.
The most serious cause of the problem would be the spin bearing. Try and turn the basket by hand and see if you fill any restrictions.
The basket can drab because of the bearing or because there are clothes between the spin basket and outer tub.
Turn the basket by hand and see if you notice anything.
You can also try to remove the belt and run the clean cycle and see if the problem repeats. If the code doesn't repeat with the belt off and there is nothing between the tub and spin basket most likely the spin bearing will have to be replaced. The bearing is part of the rear half of the tub and will require a complete tear down to change.
The rL error code during the clean cycle is likely caused by friction on the spin basket shaft since you indicate that you hear squeaking when the washer is spinning.
The squeaking is normally caused by a bad bearing in the rear tub shell.
I recommend that you have the washer diagnosed and repaired by a Sears service technician.
This type of problem will normally require an extensive tear down of the washer to repair.
It is not a problem that you can normally repair yourself.
Open the door & slowly rotate the spin basket to see if you can feel any kind of drag on the bearings.
If the bearings check good, the control board is sensing a load & will need to be replaced.
If the message rl repeats with the belt off then the most likely cause of this problem is the machine control board.
http://media.fotki.com/1_p,sqfgswqgwssgwfwxgtqsskgwtqkq,vi/ssfqsqssrxkbbdrggfw/1/1303472/5961857/image34400img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: EXTREME SHAKING DURING SPIN CYCLE
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: HE2plus. I keep getting rL on clean washer cycle.
Posted on Sep 14, 2010
lordmiguel
SOURCE: I have an Maytag Epic Z frontload washer. The
have the lag bolts been removed in the back - the ones used to stabilize the drum in transit?
Posted on Feb 20, 2011
On a Maytag Maxima XL front load washer, please tell me on what cycle to wash a bathroom rug. zo vs
the heaviest cycle there is . but it sounds like the control board is not advancing the timer if it sits that long on one thing perhaps a call to a repairman is called for .
Jun 22, 2015 | Maytag Neptune MAH5500B Front Load Washer
Rl on the control panel
The "rl" (remove load) error code appears when you are running the "Clean Washericon1.png" cycle. You must not have a load of clothes in the washer during this cycle. Remove the clothes from the drum, and restart the cycle. The "Sud" error indicates that the detergent is over-sudsing. The Duet washer automatically combats this by reducing the amount of suds in the washing machine. Let the washer finish the suds-reduction steps. Use less detergent during the next wash cycle.
Oct 21, 2012 | Whirlpool Duet GHW9150P Front Load Washer
An error F34 how can i solve this problem
Hi and welcome to FixYa, I am Kelly
Somehow you selected a clean cycle.
http://maytag.custhelp.com/app/answers/detail/a_id/2892/~/display-shows-rl-or-f34---front-load-washer
This error code indicates that items were detected in the washer during the Clean Washer cycle.
The Clean Washer cycle is used to keep the washer fresh and clean. Do not place garments or other items in the washer during the Clean Washer cycle. Use this cycle with an empty washer basket.
If you have a Maytag.... (no model number given so I chose one)
See the Use and Care Guide for details; find it by entering your model number in the search tool below.
Remove the items from the washer.
To remove the error display, press Pause/Off or Pause/Cancel or Power once.
Thanks for choosing FixYa,
Kelly
Mar 21, 2011 | Washing Machines
Got an error code rl. Took the clothes out, now know re-start procedures
Hello, the rl error code means that at the start of the cycle a load is detected inside the drum, and what you have to do is to remove the cloth from the drum and start the cycle again.
Thanks
Jun 10, 2010 | Maytag Neptune MAH5500B Front Load Washer
When cleaning the washing machine it stopped and the RL came on. What is RL?
RL means at the start of the CLEANING WASHER cycle a load isdetected inside the drum.
Try removing clothes from drum and start the cycle again.
Apr 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My kenmore HE2plus washer gives an error code (rL) when we try to do the cleaning cycle.
Oct 19, 2009 | Kenmore HE2 Plus Front Load Washer
My empty washer keeps giving me an rl error while trying to run cleaning cycle
Sep 26, 2009 | Kenmore Elite HE5t Washer
Error code RL keeps occuring when washer is in CLEANER MODE
rl code is load detected in drum during cleaning washer cycle. Book answer is to remove clothes and start the cycle again. Here's everything that Whirpool doesn't want you to know or do to your machine. Don't blame me if you do anything that damages your product. This is a link to the on-line 'technician' only service manual for your washer.
http://www.scribd.com/doc/7075573/Whirlpool-Kenmore-HE2-Plus-Troubleshooting-Tech-Sheet-8540259
May 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Mar 03, 2009 | Kenmore HE2 Plus Front Load Washer
Front load washer problem
rl means there are clothes in washer during cleaning cycle...however .there is a glitch in the program and have seen that rl code with no clothes in washer...don't bother calling repairman it's a program issue with the computer last i heard there was no fix forthcoming and customer were to be told to use normal cycle as they would the clean cycle
Sep 06, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
