Question about Blu Cell Phones
BLU PHONE VIVO XL2 i have a new battery that has to be soldered in will i lose any info when i disconnect the old one ??I will remove the sims and card .
Posted by slow learner on
Gustavo Ortiz
  • 637 Answers
I don't think so, you only lose the info on your cell if you make a factory reset. If you can make a back up with an app.
Posted on Apr 16, 2020
5 Related Answers
Anonymous
  • 40 Answers
SOURCE: sim card transfer
on the A707 you can go to address book, right soft key is options, copy, copy to sim, multiple, click all, press ok. Thats the way the transfer from phone to sim.
if you are transfering from another phone to the a707, let me know, can tell you that too....
Clint Cartee
ATT Wireless
Posted on Jan 22, 2008
Anonymous
  • 417 Answers
SOURCE: sims card
Restore Factory Setting In on The Phone
Posted on Jul 17, 2008
Anonymous
  • 4 Answers
SOURCE: how do I remove the battery and put the sim card
These are steps from the Nokia 2760 manual found at :
http://nds1.nokia.com/phones/files/guides/Nokia_2760_UG_en.pdf
(pages. 12-13)
1. Press and slide the back cover toward the top of the
phone to remove the cover .
2. To remove the battery, lift it as shown
3. Carefully lift the SIM card holder from the finger grip
of the phone, and open the flip cover
4. Insert the SIM card, so that the bevelled corner is on
the upper left side and the gold-colored contact area
facing downward.Close the SIM card holder, and
press it to lock it into place
5. Insert the battery into the battery slot
6. Align the back cover with the back of the phone. Slide
and push it toward the bottom of the phone to lock it
Posted on Apr 14, 2009
Anonymous
  • 51 Answers
SOURCE: htc 8925, error message ''no sim card detected''
Ensure all SIM contacts are straight & in line with each other. To clear corrosion on the contacts try using a clean pencil eraser. You don't mention if you get any error messages so I am supposing you aren't.
Posted on May 26, 2009
Anonymous
  • 20 Answers
SOURCE: my tracfone died - battery fully charged - going
you can't transfer sim cards on tracfone, unlike other phones
Posted on Feb 03, 2010
How do I add an sd card to blu vivo xl2
The sdcard might fit between SIM cards 1 and 2. There is a space about that size in the middle. Some sim card trays have a diagram etched inside suggesting the proper order. If you do not have a second SIM card, insert an adapter frame in that empty space so sdcard won't slip. These are sold as a set under "sim card adapter." They will not fit sdcards, however.
Apr 09, 2018 | Blu Cell Phones
Can I simply take the sim card out of my ZTE at&t prepaid smartphone and stick it in a new Blu Vivo X?
if it fits --yes but you will have to redister the sim card in the new phone to the service provider
Mar 20, 2018 | AT&T Cell Phones
My BLU XL2 won't notify me of incoming test messages
Did you check your notification settings? Sometimes the most simple things are the ones you miss.
May 24, 2017 | Dual Cell Phones
How do i install micro sd card into blu vivo xl2?
I have a Blu Dash X and have 2 sim cards plus a micro SD. If you can get the back off (a fingernail in the little crack on one of the corners) you can open it up and slide the card into the slot that is marked for it. The contacts go toward the front of the phone.
Apr 08, 2017 | Electronics - Others
New unlocked cell phone won't turn on
Hey, same problem. Push and hold the hangup button. It will prompt to insert sim , but I only have one. The phone works. The website and the manual are useless. Just gotta play with it, I guess.
Mar 06, 2013 | Cell Phones
I forgot the screen pattern for my BLU VIVO 4.65 HD cellular phone How do I get around it?
if you forgot your pattern lock, just give few more tries to continue wrong efforts. at an instant, the OS will report 'attempts exceeded, enter with your gmail'. at this point just enter your email address and in the textbox for password just give value as 'NULL'. this will instantly ask for new pattern lock and you are done!
Feb 19, 2013 | Blu Products Cell Phones
Puk code
  1. Do not enter in any codes if the phone asks for a "PUK" or "SIM lock" code. Contact your cellular provider immediately and request the code because if you enter in an incorrect code, your SIM card will permanently deactivate itself.
  2. Contact your cellular service provider and have it provide you with a new SIM card. Let it know your account and phone number so that it can transfer your phone service to the new SIM card.
  3. Check the manual that came with your phone to see if the SIM card is found in the standard location beneath the battery or if it's located somewhere else.
  4. Turn your phone over and remove the back plate by pushing down on the slide panel and sliding it away from you. Remove the plate and then put your finger in between the battery and the side wall. Push the battery away and pull it out of the phone.
  5. See if the SIM card has a metal covering. Remove the covering if there is one present and then pull the SIM card out.
  6. Place the new SIM card in the card holder and then snap back down the metal covering. Make sure to place the card in the same direction as the old card or your phone will not be able to read it. Put the battery back in and then place the back panel back on. Power on your phone to ensure that the SIM is working properly.
Sep 24, 2009 | Cell Phones
Cell Phones Logo
Top Blu Cell Phones Experts
Jean Thiebaux
Lawrence Oravetz
Harrie
Are you a Blu Cell Phone Expert? Answer questions, earn points and help others
