Question about Power Acoustik Car Audio & Video
I have a power acoustik pd 701 how do I play videos off my iPhone thru usb cable
Posted by C F on
Attique-ur-Rehman
    Top Expert:
  • Power Acoustik Master
  • 2,677 Answers
  • Smart Control enables select Mobile 8 models to communicate with the media player of most Smartphones and tablets
  • Smart Control sends playback commands by the AUX cable connected to the headphone output of your smart device
  • Control track selection, play/pause, and even answer incoming calls. AUX cable included. Variable Subwoofer Pre-Amp Output
  • Play audio, video, and picture files through Mobile 8 from DVD, CD, or 32GB SD/USB flash drive. Supports MP3 & WAV audio files & MP4 video files, and JPG pictures.
  • Safely make and receive hands-free phone calls, scroll contacts lists, and stream MP3's via A2DP from your enabled Smartphone. Most Bluetooth enabled Smartphones seamlessly pair
Posted on Apr 17, 2020
5 Related Answers
Anonymous
SOURCE: cannot see video
electric tape the wire to the metal on the top of the unit. thats it. ive had it that way for a year and its worked great
Posted on Sep 13, 2008
Anonymous
SOURCE: i have a power acoustik ptid-5850n, It will not play any cd, dvd, mp3, ect., it will not play anything except sd card, usb, and radio???
I HAVE THE SAME PROBLEM WITH MINE CAN SOMEONE
PLEASE HELP THANKS
Posted on Jan 23, 2010
luckyII
  • 130 Answers
SOURCE: POWER ACOUSTIK PD-931NB won't turn off when my
It is miss wired to power instead of the switch that turns off the car.
Posted on May 08, 2014
Terry Corrow
johnny rebel
  • 10875 Answers
SOURCE: POWER ACOUSTIK PD-103B In-Dash Single DIN DVD AM/FM Receiver with 10.3-Inch will not play movies from s/d card or usb port
its not supposed to do that,read your manual,it only reads memory cards,,it plays dvds
Power Acoustik PD 103B
Posted on May 30, 2015
bigdawg7299
  • 2559 Answers
SOURCE: I have a power acoustik pd 624hb and the background color that needs to be black is white how do I fix this problem
This is indicative of a failed/failing lcd screen. If under warranty return to manufacturer. If not probably cheaper to replace.
Posted on Jul 04, 2016
What format video will play from a flash drive
If you wish to play video on any usb-supported devices using usb stick or flash drive, kindly check compatible format for the devices. Try searching it around using google. Some devices only supports .avi or just .mkv but there are also devices that can support various formats. The video format can be changed using FormatFactory. This software can convert pictures, videos, songs to different format according to your preferences.
May 04, 2014 | Power Acoustik Ptid-8920b In-Car DVD...
USB ISSUES
I have music video and 3 movies download on my USB and when I tried to plug in it says unsupported format.
Mar 04, 2013 | Power Acoustik PTID7002NR Car DVD Player
Will the Samsung UE27D5000NW LED TV play video from external hard drive?
"Wondering if an external hard drive will draw too much power/amps thru the TV's USB."
Yes, it probably would, so you are better off using a self-powered (one that you plug in to a wall outlet) drive.
And even if you got it running, it might crash halfway through a movie or something. But, for sheets & giggles, if you have all of the data that is on the 2.5" backed up somewhere else, give the 2.5" a try.
Good luck.
Jan 17, 2018 | Microsoft Xbox Computers & Internet
I was wondering how do I play music through my iPhone with this cd player. I have a direct cable but I'm not sure what to press to make it play through my cd player. Thank you.
Once you plug in your iphone and set it to play your song(s). Set your car player for AUX this will then pick up the device playing into the direct port. Hope this helps Fix ya up.
May 12, 2011 | Power Acoustik PTID7002NR Car DVD Player
Play while driving
in the USA that is ilegal but if you wanted some of my colleagues put the parking cable of the stereo to ground.Good luck
Apr 03, 2009 | Power Acoustik PTID8400 Car DVD Player
Power Acoustik PTID-4007
Ignore the above comment... SD cards and USB play fine on there (i have one).
Mine does the same, but leave it for 5-10 seconds after it says close and it loads it up!
Mar 29, 2008 | Power Acoustik PTID-4003TV Car Video...
Car Audio & Video Logo
Top Power Acoustik Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
