Question about Home
We brought to Brazil our lovely Seiko Melodies in Motion Wall Clock and it will only play music when we take it off of the wall. Why won't the music play when it is on the wall/?
Posted by Mary-Ann Cox on
  • Terry
    Terry Apr 16, 2020
    Amazon comments suggest it cannot play while in the dark. Unknown if being on the wall keeps it dark or not. https://www.amazon.com/ask/questions/Tx1...
5 Related Answers
mcdevito75
Michael C. De Vito
  • 1970 Answers
SOURCE: I have a seiko musical wall clock that no longer
mcdevito75 here, I'd bring the clock to a small watch repair shop in the area and have them look at it.
Posted on Jun 27, 2010
mcdevito75
Michael C. De Vito
  • 1970 Answers
SOURCE: I have a Melodies in Motion Seiko clock that is
mcdevito75 here, Sounds like 1 or both hands are hanging up on themselves or something on the face of your watch, look for a small watch repair shop in your area, or check here at fixya, bottom of page, click on repair service directory the watches.
Posted on Jul 03, 2010
watchandpen
Watch and Pen
  • 45 Answers
SOURCE: My seiko musical wall clock
To test your Seiko Melodies in Motion Clock:
1) Check the volume knob in the back of the Seiko clock to make sure the volume has not been adjusted all the way down.
2) Make sure the on / off switch is set to on.
3) If it is extremely dark in the room, the clock will not play, it has a light sensor. Make sure the room is well lit.
4) There are separate batteries usually that operate the clock and the music. Change the batteries paying special attention to any acid / corrosion caused by old batteries. Clean out any acid and it should play. Also, be careful not to touch the positive or negative contacts on the new batteries, as this could inhibit proper connection.
If you have done each step above and it is still not operating, your clock is defective. Contact Seiko Service Center directly at: 800-722-4452 extension 3.
If you have had the clock less than a year, and it was purchased from an authorized dealer, it is under warranty, and any repairs will be free. Otherwise, there may be a charge for the repair.
Posted on Feb 23, 2011
small6363
  • 18429 Answers
SOURCE: INSTRUCTIONS
try this link
http://www.theclockdepot.com/seiko_westminster_clock_instructions.html
Posted on Mar 14, 2014
gopakumarg43
  • 76466 Answers
SOURCE: instructions for seiko musical wall clock
http://purbakala.hol.es/seiko-qhr016-manual.pdf
Download user manual for similar clock by above link.
Posted on Jul 18, 2016
Where can I find replacement case parts for the Seiko model QXM211GRH Melodies in Motion wall clock?
Hello, David -
From the Seiko Clocks FAQs web page:
https://www.seikoclocksusa.com/faq.html
Question about where to purchase Seiko clock replacement parts;
Answer:
(Quote)
Please contact your local Authorized Dealer to order replacement parts. You can consult our Seiko Clock Store Locator to identify dealer locations.
(End quote)
Best wishes.
May 29, 2018 | Home
Seiko wall clockNeed battery cover and repairs Model #QXM139SRH
I sent my clock off to Seiko for repair, useless, they said it was in the circuitry. I had them send my clock back. I ordered a new gear box $2.00, replaced that, it will work as long as it's flat. If you look you can see how the clock cycles I made sure it was "locked" in (you can hand force it) then I removed one of the gears so it doesn't cycle down but stays in the up position at all times. Music plays, lights go, just no motion now. Call Seiko for replacement battery cover.
Jun 22, 2014 | Seiko Melodies in Motion Clock
When my melodies in motion clock plays the music (Beatles), it sounds distorted.
You may have a loose speaker wire connection or the speaker could be bad.
Dec 09, 2013 | Seiko Melodies in Motion Clock
Seiko wall clock pendulum not working
When was the last time it was serviced? The movement probably needs a good cleaning and/or oiling.
UsedClockParts.com
Jan 09, 2013 | Seiko Melodies in Motion Clock
My seiko musical wall clock doesn't play music anymore
Feb 23, 2011 | Seiko Melodies in Motion Clock
Home Logo
126 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
