Question about Panasonic Microwave Ovens
My Panasonic microwave the genius 1250w will not stop beeping and flashing through power cycle numbers P10 - P1...how to stop beeping?
Posted by Michael on
Harjeet s. bola
  • 49 Answers
Replace main board
Posted on Apr 02, 2020
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: cleaning interior of microwave door
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 28, 2008
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Panasonic Sensor 1250W Microwave cycles off after only 5 seconds.
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector.
If so, see http://www.microwavedisplay.com/safety.txt , http://www.microwavedisplay.com/disassembly.txt and http://www.microwavedisplay.com/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find many Panasonic owner's manuals for free download here.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
If you're not in the US, see Panasonic.net.
Posted on Dec 26, 2009
Testimonial: "Extraordinarily helpful, comprehensive advice within 24 hours of posting my question. Thank you so much!"
Anonymous
SOURCE: My Panasonic Inverter Genius Sensor 1250W Lights
microwave is in lock mode. How do you unlock to use?
Posted on Apr 24, 2010
Anonymous
  • 8909 Answers
SOURCE: Hi, i am having NN-5753 -1250w panasonic genius
I would check the door interlock switches and if that doesn't fix it, a new control panel should.
Hope that helps.
Posted on Nov 11, 2010
John Mock
  • 932 Answers
SOURCE: My Panasonic genius sensor 1250W microwave has stop working, now is their fuses i need to check,or is their a way i can, check the heating element to see if i us out.
Kevin,
There is a fuse in a microwave. One way you can tell for sure if the fuse has blown is that there will be no lights or any activity when you push buttons. The screen will not light up either. If that is your case, then you can be fairly certain that your fuse has blown. I would suggest before working on it that you plug something else into the same outlet and see if it works okay so that you can eliminate that you lost power in your outlet. If all of that is okay, then turn your microwave around so that you are looking at the back and take out the screws that hold the cover on. Remove the cover and look at where the power cord goes into the back of the unit. Find the black wire from the power cord and follow it to either an inline fuse holder, or a fuse block, or a circuit board. Depending on your model, you should have one of these three options. Make sure that you replace your fuse with the same amperage fuse that you take out. Look on the metal rings at each end of the fuse and that will tell you what amp fuse you need. Hope tis helps!
Posted on Feb 26, 2015
Manual for Panasonic sensor 1250w
Do you mean a Panasonic 1250W microwave with 'Genius Sensor' technology? If so, you should check the model number on your microwave to find the correct manual.
Panasonic has several models with sensor modes. The manual will usually be on the product page. Search for the model from http://shop.panasonic.com and scroll down to the manuals section. Alternately, go to http://shop.panasonic.com/support , then do the model search. This will automatically go the the Owner's Manual section on the product page.
A manual for the NN-SN933 (and several other models) is here: ftp://ftp.panasonic.com/microwaveoven/om/nn-sn943_nn-sn933_nn-sn743_nn-sn733_en_om.pdf . This is a 2.2 cu. ft. model that was advertised on target.com as a Genius Sensor microwave.
I hope this helps. Please add a comment with the model number of your microwave if you need a different manual.
Aug 23, 2017 | Panasonic Microwave Ovens
Panasonic genius inverter 1250w door stuck
Sounds like a spring let go, or the plastic piece that the spring hooks onto broke. Either way, the top cover will have to come off. Could be an easy fix unless something broke.
Jan 25, 2014 | Microwave Ovens
I have a Panasonic Genius Sensor 1250W that went on "demo" mode when the power went out and we don't have a manual to get it back on regular mode. Any suggestions?
http://www.generalmanual.com/Microwave-Ovens/Panasonic-NN-P794SF-Microwave-Oven.htm
click on the above link it will take you to the correct site to download all service and operation manuals for your panasonic m/wave
Jul 01, 2011 | Microwave Ovens
Feb 17, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Dec 25, 2009 | Panasonic Microwave Ovens
Microwave Ovens Logo
Top Panasonic Microwave Ovens Experts
Paul Bade
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
