Computers & Internet Logo
Question about Logitech Computers & Internet
M310 logitech wireless mouse droped now light does not com on put in new battery still no light how do i fix this
Posted by ricky brewer on
  • Anonymous Jan 12, 2021
    NO PC told.
    it is a bad mouse or lost receiver
    batteries backwards. (plus end to rear )
    new batteries read 1v not 1.5 and are bad.
    the moust on/off slide to "ON" next.
    RTM yet, read the manual
    is the USB receiver missing?
    in the mouse battery compartment is the
    USB nano receiver, lose that?
    https://support.logi.com/hc/en-us/articl...
    try all usb ports on the unstated PC?
    for the nano.
HENRY LEONARD VANDEBOOM
    Problem Solver:
  • 7 Answers
It sounds like the mouse broke when you dropped it. You might want to check the warranty.
Posted on Jan 11, 2021
    one year late, really.
5 Related Answers
Anonymous
SOURCE: Logitech wireless mouse
Went onto laptop today and mouse is working - don't know why !
Posted on Sep 11, 2008
Anonymous
  • 8637 Answers
SOURCE: Logitech wireless mouse and keyboard
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Posted on Jan 19, 2009
cpenzes
DEKR
  • 1102 Answers
SOURCE: Logitech Wireless CE 0682 Keyboard won't work but mouse does
did this come with software
and you might need to do a uninstall reinstall
if it worked on same pc before it should work now.
if you have a reset button on transmitter try resetting it.
Posted on Jan 20, 2009
MUKHTAR
mukhtar21 shaikh
  • 2022 Answers
SOURCE: Logitech mouse n keyboard wont connect
whenever you chage the battery you have to syncnonize your keyboard and mouse to sensor of the reciver. you can see on the back side of the keyboard there is connect button just press it and on the recevre side also press the connect buton same setting do with mouse also.
Posted on Sep 08, 2009
gggg
  • 904 Answers
SOURCE: logitech wireless optical mouse won't move computer cursor
Sometimes on wireless mice the contacts get warped or bent, so when you move it or set it down the batteries are not making full contact on both ends and the mouse loses power.
You can try adjusting the contacts or using a conductive material to make the contact (like a staple or paperclip), but you're probably better off spending the $10 or $20 to get a new mouse.
Posted on Jun 01, 2010
The red light on the top of my mouse is staying red and will not work. I have a battery operated mouse that came with a wireless keyboard as well, i have tried many sets of new batteries, and can not get...
When you put in the new batteries, you may need to press the "Sync" button on the wireless receiver. If it does not have one, I suggest contacting Logitech to help resolve the issue.
Logitech m310 wireless mouse causes cursor to freeze while surfing internet, then computer reboots automatically. pc runs normally with microsoft wireless mouse though. any suggestions?
Make sure you have the latest drivers from the logitech website. Also make sure the batteries are fresh and there's no corrosion on the terminals.
My m310 logitech wireless mouse to activate middle button feature cannot get the link or down load for Mac
you can download software from this link
http://www.logitech.com/en-us/428/6686?section=downloads&bit=&osid=9
Hi I want to Know whether i can Use MK250 Keyboard and M310 mouse at the same time with the same USB stick????? Let me know about it.... Thanks
You need to get a Logitech Unifying receiver. With this you will be able to use up to 6 devices. Here's a description of it: http://www.logitech.com/en-hk/349/6072?WT.ac=ps'6277
But m310 says drivers wont install
Try installing the drivers for your hardware prior to plugging in the device. You should be able to do this with the CD you received with the product. If you do not have a CD or the CD did not work properly, visit the following support website for the Logitech Wireless Mouse M310 to download appropriate drivers and software:
http://www.logitech.com/en-us/428/6686?section=downloads&WT.ac=sc|downloads||dd
1helpful
My logitech lx8 wireless mouse stoped working.
Maybe some internal component is broken. try to connect the mouse to another computer and see if it works. If not, you should replace it.
Dell Wireless Mouse dead
now mouse is open & clean by isoprpile & check battery conector after check now mouse its working.
2helpful
Not working
If there any lights on the mouse when you put new batteries in the mouse? If yes then you can still fix it. On the usb controller of you mouse it will have a button on it. Press that button first and then press the button under the mouse. Repeat a few times and see if mouse responses. Then if nothing happens, unplug the usb controller and place it into another port. Repeat the above process and see what happens. Should work fine.
Setting up the mouse
go control panal aad/remove hardware scan the mouse drive automatically then restart
Top Logitech Computers & Internet Experts
Marvin
Marvin
Steve Nordquist
Steve Nordquist
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
