Question about The Audio Players & Recorders
When I turn on my AGPTEK MP3 it goes to the volume screen and when I attempt to go to another screen it reverts back to the volume screen. Any help would be appreciated.
2 Suggested Answers
snakehead
Henry Thomas
  • 1074 Answers
SOURCE: Mitsubishi WS-65711 Volume
have a tech repair your set the problem is in the eeprom circuit or the audio circuit.good luck.
Posted on May 14, 2007
SOURCE: Altec Lansing 4.1 ADA880
if you are a technically skilled person
simply clean all the IC(chip) leads, by using a blower or using a painting small brush
the dust come in contact with the other pins that make this problem
Posted on Jan 24, 2008
The screen is frozen on the PHILIPS icon and when i reset it it did nothing, but when i put it on the charger then reset it, it starts charging, but when i take it off the charger it goes back to the...
Please follow the below steps and check if that resolves the issue:
  1. Press down on and hold the "Power" button on your Philips GoGear MP3 player.
  2. Press down on and hold the "Volume Up" button on your Philips GoGear MP3 player. Continue to hold both of these buttons down for three consecutive seconds. The MP3 player will turn itself off.
  3. Press and hold "Power" until your Philips GoGear MP3 player turns itself back on. Your GoGear will no longer be frozen and you can use it as normal.
If you require further assistance then please revert back.
Regards
Anand Gupta
May 04, 2011 | Philips GoGear ViBE Digital Media Player
Hello, I'm trying to increase the volume on some phones mitel 5220 and 5224, but it only goes to 6. I need the volume level to go to 10. Do you have any ideas? Firmware is 07.02.00.04 Thank you
The ADA compliance requires that the phone when set to the highest volume level will revert back to factory default setting for the next call. This is a safety feature to prevent one's hearing aid from being blown up by a loud caller.
If you turn the volume up to 9, and leave it there, it will stay at 9. If you turn it up to 10, it will always revert back to default.
I hope this helps,
Mark
Feb 08, 2011 | Mitel 5220 IP Phone
Philips GoGear HDD6330
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Nov 20, 2007 | Philips GoGear HDD6330 MP3 Player
Music doesnt show up on mp3 player library, but it does on the computer
-Tha Mp3 Doctor
Nov 14, 2007 | Philips GoGear HDD075/17 MP3 Player
Mines froze with a black screen and it won't freeze
-Tha Mp3 Doctor
Nov 11, 2007 | Philips GOGEAR SA6045 MP3 Player
Ma 4gb go gear is not working
-Tha Mp3 Doctor
Oct 26, 2007 | Philips GoGear HDD6330 MP3 Player
Screen goes blank or freezes until battery dies sometimes or randomly
-Tha Mp3 Doctor
Sep 14, 2007 | Philips GoGear HDD6330 MP3 Player
My philips mp3 wont work
-Tha Mp3 Doctor
Jun 02, 2007 | Philips HDD1630 MP3 Player
-Tha Mp3 Doctor
Dec 25, 2006 | Philips GoGear HDD6330 MP3 Player
29 people viewed this question
Top The Audio Players & Recorders Experts
Roy Cunningham
Level 1 Expert
Michael Roth
Level 1 Expert
Martin van der...
Martin van der...
Level 1 Expert
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
