Question about Philips Audio Players & Recorders
Philips bdm4065uc Monitor
When the monitor is turned on it shows a blue welcome screen, just a little bit dimmer that normal. The backlight is on. After few seconds the screen turns off and the backlight is off. I managed one time to see the no input message before it turned off. What I need to do is to validate if the LEDs or the PSU is broken. Can I apply 42V directly on the wires to the LEDs from the PSU? Disconnecting them first of course. And thus validating if the LEDs are ok. All voltages on PSU measures ok, except the +VLED and -VLED. The +VLED on = 42,5V and off = 27,3V the -VLED is on = 0V and off = 9V. Is the LedDriver on these PSU board known to fail? PSU board no: 715G6985-P01-000-002R Led Driver: TPV101D Are there any known issues with capacitors on this PSU board?
5 Suggested Answers
Anonymous
  • 624 Answers
SOURCE: My monitor says "input ......" and then the screen flashes off.
This is a duplicate post, click the following link to read the active posting: http://www.fixya.com/support/t138012-sony_sdm_hs74p_s_17_monitor_stay_right
Posted on Mar 16, 2007
bammbammfran
Fran Bednar
  • 159 Answers
SOURCE: RE:monitor goes black
Monitor going black after a few seconds can be causd by a faulty power supply or inverter. Some monitors have both as one unit.
Sometimes it is basic failed capacitors, After that then I would look at transistors.
The average monitor from 17 to 20 and sometimes the 22s have usually 4 bulbs in them. One bad bulb will also cause the inverter to not fire up.
Bad bulbs usually show pinkish tint, or flickering or are dark at center top or bottom of the display.
ebays bammbammfran
Posted on Oct 05, 2008
Anonymous
SOURCE: BenQ FP51g LCD monitor
Dear Friend:
There is a Switch transistor to power on -off the hi voltaje for lights. Check 15V from power source go to this transistor colector, Using soldering Iron, make a juntion between colector and emiter, to short 15V to Hi voltaje power. I´m fixing 10 monitor the same trouble. I will remove a liter transistor.
Late I will post here the driver transistor number, and the replace number transistor I will use.
Pictures , etc. Best Regard
Posted on Oct 25, 2008
amit goswami
  • 55 Answers
SOURCE: Screen shows message "no input signal" and monitor goes to sleep.
monitor show "no input singnal" error masage when not gating any type of video singnal ,
so if u realy check your monitor wires for correctty plugged in .
then:-
Two possibilities:
either the video/mainboard of the monitor is defective; or
the video card/ CPU is the faulty.
A way to verify is to try the PC with another monitor or to try the monitor in another PC.
thanks
Posted on Apr 30, 2009
John Cunningham
  • 6771 Answers
SOURCE: Samsung's LCD monitor SyncMaster 740N; backlight
There is a inverter transformer on the board that may be defective that generates the high voltage that drives the lamp, you may end up having to replace the whole inverter board to get it working again.
Posted on Jan 26, 2011
Can i get ur help or not am still waiting on a reply on my question about my philips tv
videos
9k= 1:54 How to lock and
unlock ISF modes
on Philips TVs?
TV Calibration with Darko YouTube - Feb 15, 2016 z 0:45 How Do You
Unlock A Philips
TV?
Wen Wen YouTube - Aug 14, 2017 9k= 2:23 PHILIPS HIDDEN
SECRET SERVICE
MENU/MODE
Carl Cosmos YouTube - Apr 15, 2016 2q== 1:09 How to unlock your
Philips
iTech Unlimited: Unlock... YouTube - Jan 30, 2015 z 1:20 ********* a locked
Philips 25u604 TV
for composite in.
CNLohr YouTube - Dec 23, 2012 9k= 0:28 How to Access
Hotel mode on
Philips TV
Carl Cosmos YouTube - Aug 31, 2016 9k= 1:14 how to unlock a
hotel tv/remove
hotel mode, use
HDMI on hotel tv
draai een keer in het rond... YouTube - Nov 16, 2016 9k= 0:46 HOW TO UNLOCK
PHILIPS MONITOR
CONTROL
Vrushank Maharajwala YouTube - Apr 30, 2013 z 2:45 Unlock Hotel TV
inputs
Channel88 YouTube - Dec 20, 2016 z 1:47 How to make your
hotel television,
like LG TV, allow
you to change ...
Margebird YouTube - Mar 24, 2016
How to lock / unlock a channel in Philips TV? - Philips - Canada
https://www.philips.ca/c-f/.../how-to-lock--unlock-a-channel-in-philips-tv
  1. Cached
How to lock / unlock a channel in Philips TV? Press the 'MENU' button. Press the cursor right. Press cursor down to select CHANNELS. Press cursor right. Press cursor down to select CHANNEL LOCK. If the PIN code is correct, the channel list reappears. Select the channel with the cursor up/down and press the 'OK' button ...
How to lock / unlock a channel in Philips TV? ' Philips
https://www.usa.philips.com/c-f/.../how-to-lock--unlock-a-channel-in-philips-tv
  1. Cached
Locking/Unlocking channels in Philips TV ' Philips
https://www.usa.philips.com/c-f/.../lockingunlocking-channels-in-philips-tv
  1. Cached
Published: 2017-03-02 ' Make sure remote control is in TV mode by pressing 'SELECT' button repeated until 'TV' lights up green.
Jun 21, 2018 | Philips Televison & Video
Tip
Philips TP2784C TV Manual Download
Download Philips TP2784C TV Manual
Would you like to review the features of the Philips TP2784C TV?
Have you lost your Philips TP2784C TV Owner's Guide?
Would you like a free digital, searchable, pdf version of the Philips TP2784C TV Manual?
Follow this link (& click FREE) to download a pdf version of the Philips TP2784C TV documentation.
I hope that helps.
___________________________________________________
on Jul 27, 2010 | Philips TP2784C TV
Tip
Magnavox Factory Service Centers in USA
ATLANTA Phillips Factory Service
550 Franklin Road., Suite F
Marietta, GA 30067
800-273-1501
TAMPA
Philips Factory Service
1911 US Highway 301 North, Suite 100
Tampa, FL 33619
800-442-2027
SAN FRANCISCO
681 East Brokaw Rd.
San Jose, CA 95112
800-300-9013
HOUSTON
1110 N. Post Oak Rd., Suite 100
Houston,TX 77055
800-952-3254
CLEVELAND
950 Keynote Circle
Brooklyn Heights, OH 44131
800-331-7037
DETROIT
25173 Dequindre
Madison Heights, MI 48071
800-438-1398
DALLAS
415 N. Main Street, #107
Euless,TX 76040
800-952-3254
LOS ANGELES
20930 Bonita, Ste.V
Carson, CA 90746
800-300-9013
CHICAGO
1279 W. Hamilton Pkwy.
Itasca, IL 60143
800-531-2922
KNOXVILLE
One Philips Drive
Building 2
Knoxville,TN 37914
800-821-1767
PHILADELPHIA
354 Dunks Ferry Rd.
Bensalem, PA 19020
800-847-9320
on Jun 02, 2009 | Philips Magnavox 27MS343S 27" TV
From 1 to 10 ten been the best how good are this tv 55PP9363H/17 1 TOSHIBA 6211M15 1 SONY KFSOWE620 1 MAXENT MX26X3 1 SAMSUNG LN32BS40P8D 1 MAXENT MX26X3 1 MAXENT MX42XM11 1 SONY KDLS2VLISO...
The Samsung LN40B540P8F I would rate a 9. Only God is 10.
All the DLP sets, you can throw out
All the Older Projection sets you can throw out
I would take the rest for scrap parts.
I hope this is helpful.
Dec 18, 2010 | Philips Magnavox 51MP392H Rear Projection...
Need code for phillips big screen lost manual for jumbo remote
Code 002 for Philips TV Code 003 for Philips TV Code 004 for Philips TV Code 008 for Philips TV Code 012 for Philips TV Code 019 for Philips TV Code 062 for Philips TV Code 068 for Philips TV Code 069 for Philips TV Code 075 for Philips TV Code 076 for Philips TV Code 086 for Philips TV Code 087 for Philips TV Code 088 for Philips TV Code 130 for Philips TV Code 132 for Philips TV Code 134 for Philips TV Code 167 for Philips TV Code 183 for Philips TV Code 196 for Philips TV
Jul 12, 2009 | RCA RCU600M Remote Control
PHILIPS PM3S codes
I need philips sp 060r remote
Feb 27, 2008 | Philips PM3S Remote Control
Top Philips Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
