MY PANASONIS VIERRA 32 INCH TV NOT GETTING ON.GREEN LIGHT IN FRONT KEEPS ON FLICKERING.NOT GETTING ON FROM REMOTE ALSO.
5 Suggested Answers
Anonymous
SOURCE: need remote control code for 32" X2GEN tv
Good luck. I have the same issue. No codes are available for the X2Gen. To make matters worse, it appears to use a non-standard frequency for the carrier signal, maening that other remotes won't work with the TV.
I purchased a learning remote, thinking I would just "teach" it the codes directly from the X2Gen TV remote. This didn't work either.
There appears to be no way to use any remote other than the one supplied with the TV. Whatever you do, don't lose it!
Posted on Feb 05, 2008
Anonymous
  • 261 Answers
SOURCE: Lg 42 inch projection tv has green light and orange light
It is a possibility, if the indicator lights are on it definitely means something is wrong in the light engine system, it could be your lamp, ballast, color wheel or dmd board, when it comes to LGs it's most probable that your lamp might go out. You can replaced it to see if it fixes your problem, if it doesn't, there's a chance it might be yoru ballast.
Posted on Jun 29, 2009
fixyathing
jhun T
  • 341 Answers
SOURCE: i have an onn 32 inch lcd tv that will not turn on
Most probably a switching power supply problem. Have it checked by a qualified technician.
Posted on Aug 16, 2009
Anonymous
SOURCE: Wall mounting Panasonic Viera 32" tv
There's a little more elaboration required on the above post...You need to remember that the base has two long pins that go up into the TV. These pins are held in by two screws each. The screws are on each side of the TV (two vertical inline screws, inside a small inset section). Remove all four screws and the TV will come up off the base. Pull it straight and gently, but firmly, to unseat it from the pins.
Posted on Dec 28, 2009
Anonymous
SOURCE: remote control code for 32 inch lcd EMERSON TV
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
Posted on Dec 31, 2009
How do I fix my Konka led TV?
If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Feb 05, 2016 | Televison & Video
Need fix how do i make it stop flickering
Coby lcd tv keeps flickering Flat Panel Televisions ... - Fixya
www.fixya.com > ... > lcd tv keeps flickering > Flat Panel Televisions
Coby flat panel televisions lcd tv keeps flickering related questions and answers. Ask your Coby ... Why does my Coby 40 TFTV4028 LCD TV keeps flickering.
Coby adjust air fuel mixture Flat Panel Televisions ... - Fixya
www.fixya.com > ... > adjust air fuel mixture > Flat Panel Televisions
Coby flat panel televisions adjust air fuel mixture related questions and answers. Ask your Coby ... Coby 32 in tv ... to last channel, and will stop, and will display the first channel it has got. Then we have to make adjustments on channels. ... Ad. Question about 40 TFTV4028 LCD TV. 1 Answer ... Flickering can be adjusted.
Won't turn. on red standby light changes to on but then
Jan 04, 2016 | Coby 40 TFTV4028 LCD TV
LG LCD TV Remote sensor not responding.
Give it back to the dude that "repaired" it! Remote was working when you took it in so .......................
Call them - maybe they can walk you thru it - otherwise you know what to do!!!!!!!!!
Sep 25, 2015 | LG Televison & Video
Smell of burning then TV went off. Tries to start up but the front light just keeps flickering and not going green
Need the model number of the set, and also does the light blink? If so how many times?
Aug 06, 2008 | Televison & Video
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
If you are using the remote to change channels it sounds like either the front of the remote and/or the receiving “eye” on the TV need to be cleaned, OR (more likely) the button on the remote is sticking. It is actually a button that pushes on a membrane under the entire remote panel. This is generally caused by some sticky liquid (like Coke) getting spilled on it. If you are brave enough, you can take the remote apart and clean it with denatured alcohol. Otherwise you need to replace your remote. If possible borrow a universal remote and see if it still happens. If that doesn’t fix it you have a bad IR receiver and/or a serious internal problem.
Jan 29, 2008 | LG 32LX1D 32 in. LCD Television
Open Questions:
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
