Question about Sony Televison & Video
My Sony Trinitron wega TV, shows visible display of osd menu but video input is very dark help me solve the issue.a point of correction.
5 Suggested Answers
cathim
SOURCE: Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Posted on Dec 01, 2008
Anonymous
SOURCE: My Sony Trinitron TV does not respond to remote control commands
the tv wont come on the standy timer light is on
Posted on Jan 02, 2009
Anonymous
  • 563 Answers
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 11, 2009
digitaldump
  • 115 Answers
SOURCE: Sony FD Trinitron WEGA KV-32FS120 timer flashing 9 times
WARNING- VOLTAGES STORED INSIDE YOUR TV CAN KILL YOU EVEN AFTER ITS BEEN UNPLUGGED FOR DAYS..your problem is in the zero cross detect circuit . youu should take it to a repair facility. -Or replace diode D647 . Or on remote in this order press "display -5- vol down - pwr ." and then you could watch it right now ..kinda
Posted on Oct 01, 2009
Testimonial: "Thanks for the amazingly quick response. This is very helpful information."
techman007
Lavell Turner
  • 1112 Answers
SOURCE: Sony Trinitron Wega TV keeps shutting off and red
There are two Ic's that need replacing on the Deflection Board (D) board.. These regulate power for the High Voltage and Chopper PWM circuits. The IC location on the board are IC6501 and IC8002
Posted on Nov 19, 2009
Sony fd trinitron wega kv34hs510
The set may have a self check mode or error buffer--most of these that do with the set turned off: Display, 5, vol. down and then power.
If it has the buffer a box will appear in middle of screen with several items listed-----------all should have a 0 to the right of them---a number indicates a error detected and noted.
If no error found or no display for that contact Sony for the reset code which usually is gained by going into tech menu (different from error menu) and with remote pressing 7 and enter---this does a hard reset and returns set to all factory defaults--if that did not cure it you have a interesting trouble...........
Mar 19, 2012 | Sony FD Trinitron WEGA KV-34HS510 34" TV
The Channel display will not turn off.
You will need the original remote and press the display button until it says off.
Bummer you don't have the original remote.
You can check out remotes.com and input your model number.
I hope that this helps you out.
May 05, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Top left side screen shows video 5
Get the original Sony remote. Select TV or the Video input you want to use. Then press the Display button to make the text dissapear.
Jerry G.
Nov 13, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Help now!!
Press Display button once on Remote Control, OSD (on screen display) will disappear.
Aug 12, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Video input permanently displayed
If there is no "input video" button on the control panel of this series of set, as like the older Sony sets had, you need to order the original remote from the Sony service center, or Sony parts directly. Universal remotes (any that I know of) will not access this menu in your Sony set.
Jerry G.
Jul 06, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony trinitron xbr 32"
Did you correctly select the S-Video input on the TV via the remote? In other words, if the TV is not set to look at the S-Video input then nothing will happen. You have either an "input", "source" or tv/vcr button that will allow you to select what input the tv will look at for a signal. Make sure it's set to S-Video.
Nov 13, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
"VIDEO 3" ON SCREEN
It is normal for VIDEO 3 to be displayed in the upper left of the picture if there is no signal present at the INPUT 3 jacks. This is to let you know that although the picture is black and there is no sound, the TV is still on. If you have a good signal at INPUT 3 and the VIDEO 3 stays on the screen, take the Sony remote, point it at the TV and press the DISPLAY button until you see "DISPLAY OFF" on the screen. About 3 seconds later, the words should vanish.
Aug 18, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Dark screen on all inputs, OSD clear
luminance is missing or the brightness. try to inspect the board at the back of the CRT see if there is an open resistor
Jan 14, 2007 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Televison & Video Logo
78 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
