Question about Philips Audio Players & Recorders
Philips cd recorder cdr760. not recording. have correct blanks audio rw keeps displaying no audio.
Posted by TONY PRINCE on
ray gallant
    Top Expert:
  • Philips Master
  • 69,233 Answers
TRY A DIFFERENT TYPE OF DISK
Posted on Jan 20, 2020
5 Related Answers
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: Philips CD recorder CDR870 not recording
Consumer CD recorders require CD-Audio or CD-Music blank CD's to record.
Posted on May 16, 2009
carlsbiz
Carl
  • 1124 Answers
SOURCE: A CD was recorded on a Philips digital CD-R
It would need to be finalized..
That is the only way at this point..
Hope this helps !!
Posted on Jul 14, 2009
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: audio cd recorder cdr775 won't accept
It also says "audio" or "music" if you look closely. Data disks won't record on consumer recorders.
Posted on May 03, 2011
Channa Hirantha
SOURCE: My Philips CDR760 CD Recorder problem is it reads
You can not use normal Data CDs. Use CD-R Digital Audio CDs or CD-R Audio recordable CDs. If you use correct Digital Audio Recordable CDs, it will show OPC. Once you press Recording, audio out is coming. Otherwise you can not listing to audio. Please read manual carefully. Above will solve your matter.
From Channa
Posted on Nov 13, 2012
victorin1
  • 9 Answers
SOURCE: I have a philips
hi
maybe is to late but here is the complete guide of opc fail on this machines. First of all you may noticed that the very old TDK or Philips discs still record as they should. The new cd digital audio media have a "toc" info above 32x speed, and for the old 760 model the firmware cant see or read any kind of media above 24x. I am pretty sure that on this days there are no media makers with this low speed toc info. Regardless of Brand keep in mind that old TDK and Philips or some older Sony's are made by CMC magnetics. here is the complete info of one old TDK that Works flawlessly on this kind or recorders:
Erasable: No
Free Sectors: 359,847
Free Space: 736,966,656 bytes
Free Time: 79:59:72 (MM:SS:FF)
Next Writable Address: 0
MID: 97m26s66f (CMC Magnetics Corp.)
Supported Write Speeds: 10x, 16x, 24x
ATIP Information:
Disc ID: 97m26s66f
Manufacturer: CMC Magnetics Corp.
Start Time of Lead In: 97m26s66f
Last Possible Start Time of Lead Out: 79m59s74f
Performance (Write Speed):
Descriptor 1...
-> B0: 0x00, B1: 0x00, B2: 0x00, B3: 0x00
-> EL: 359998 (0x00057E3E)
-> RS: 4,234 KB/s (24x) - WS: 1,764 KB/s (10x)
Descriptor 2...
-> RS: 4,234 KB/s (24x) - WS: 2,822 KB/s (16x)
Descriptor 3...
-> RS: 4,234 KB/s (24x) - WS: 4,234 KB/s (24x)
the only solution that I know that Works is to buy a mod chip in order to get the recorder be alive again. But you must find a person with the skills to get the chip soldered.
Posted on Jan 21, 2014
My 760 recorder keeps show no audio when I try to record. I've tried hooking it up serval ways no luck. However it plays perfect.
From Channa
May 10, 2011 | Philips CDR760 CD Player
PHILIPS CDR 870 FLASHING "OPCFAIL" AND WON'T RECORD
I HAVE A PHILIPS CDR 870 "OPC FAIL" PROBLEM. I HAVE RECORDED ONTO CD-RW, AND NOT YET FINALISED THE DISK AFTER RECORDING, IN ORDER THAT I CAN GO BACK LATER TO ADD FURTHER RECORDINGS. AFTER SWITCHING THE MACHINE BACK ON OPC THEN OPC FAIL FOLLOWS, EVEN WITH NEW DISKS CD-R AND CD-RW. MGHT THE MACHINE ITSELF REQUIE CLEANING OR IS THIS A FAULT? I AM USING MAXCELL DISKS, BOTH TYPES. THANKS. JEREMY. GATESHEAD.
Mar 19, 2010 | Philips CDR870 CD Recorder
My cd recorder wont read blank cds help me please
Do as it asks, insert blank CD-Audio or CD-Music media.
Discs for recording
For recording, make sure to use special audio discs only.
These discs are marked with “Digital Audio” and the logos shown below.
There are two different types of audio discs for the use on this CD recorder:
– CD-Audio Recordable (CDR) discs
These discs can be recorded on once and
play in all standard CD players and CD
recorders, when they are finalized.
– CD-Audio ReWritable (CDRW) discs
These discs can be recorded on, erased and
re-recorded many times and play in CDRW
compatible CD players and CD recorders,
– All Philips CD players and CD recorders
with the sticker shown here are CDRW
compatible.
To ensure proper working of the set we recommend the use of Philips audio CDR and audio CDRW discs only.
Note: Do not use a computer CDR or CDRW as recording will not work!
Go here and download the manual. You'll need it.
http://www.p4c.philips.com/files/c/cdr602_00s/cdr602_00s_dfu_eng.pdf
Mar 04, 2010 | Philips CDR602 CD Recorder
Hello i have a Philips cdr 870. With every blank CD inserted, the display shows NO AUDIO. Pre recorded CDs play OK. Unable to record. I have recently aquired this machine and this is the first time I have...
You are probably inserting blank computer discs, eg 650 or 700mb rather than blank music CD-R or CD RW`s which this machine is designed to work with. The correct discs are labelled "music audio" or 80 minutes. You can only use these types of discs. Why? When these recorders first came out, it was a way of battling piracey in copying discs. I believe there is a "hack" to enable this player to use blank computer discs.
SMA
Jan 13, 2010 | Philips CDR870 CD Recorder
May 16, 2009 | Philips CDR870 CD Recorder
Won't record record to CD-RW
First make sure your cdrw disc is blank. If it is blank try another good known cdrw brand disc and burn it in 12x speed for a good burn.
If it still fail check the software side of your cd rewriter first and lastly the cd rewriter unit.
Mar 28, 2009 | Crosley 4-in-1 Entertainer CD Shelf System
98 people viewed this question
Top Philips Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
