Televison & Video Logo
Question about RCA Televison & Video
Rca led50b45rq blue screen comes on but there's no picture & no sound is there a way to fix this
Posted by Trina Chappelle on
5 Related Answers
Vista Electronics
  • 1694 Answers
SOURCE: RCA 37'' has sound but no picture
1)confirm service # on back of tv 2)Is sound from tv or surround system? 3)suspect bad flyback xformer.
Posted on Oct 04, 2007
Anonymous
  • 104 Answers
SOURCE: blue screen
It sounds like the Blue drive transistor is shorted out leaving the blue color gun on full blast which is drowning out the other colors. If this is the case the transistor needs to be replaced. A qualified technitian could easily replace this part.
Posted on Mar 11, 2008
TONY BIGNELL
  • 147 Answers
SOURCE: rca D52W20 blue screen when turned on
Almost certainly the blue picture tube is bad. This is a huge job to replace and quite expensive. Generally it is not worth doing.
Posted on Mar 30, 2009
SD Tech
SD Tech
  • 14553 Answers
SOURCE: Have a RCA flatscreen model # L40FHD41, blue power light comes on and stays solid but I don't get any picture or sound. Screen stays completely black as if it doesn't have any power at all.
Other than checking all the connections going to it for signal it is likely a shop repair.
The nature of these sets is someone must open and inspect them and check for voltages missing.
At that point it becomes a guessing game---try the boards (purchase them) and see if a bad board.
It is always possible the front screen unit or display has failed which is fatal cost wise.
You have to weigh the cost of repair, age of set and cost of replacement in this.
The only way anyone can KNOW which board is bad is to actually remove and replace it----most shops look at it and shoot you a high estimate.
let me know if you have questions.
Posted on Mar 14, 2012
blogcnm2345
mika
  • 469 Answers
SOURCE: rca led50b45rq will not power up or come on
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. AmanStino Car Charger Quick Charger USB 3 0 3 Port with Smart Sense IC...
Posted on Nov 21, 2016
No video but sound on my tv. When I reset it the picture shows for a sec then goes off. This happens every 20 sec or so for about 4 times then goes back to black
You have either bad LED lamps in the panel or its possible you have power supply issues as well, but generally its the lamps that fail
RCA LED50B45RQ TV, white line flashes accross screen, then goes black and wont turn back on. Red light on bottom goes off and wont come back on either.
Sounds like T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
Rca 32" lcd tv.vertical lines on entire screen,no pix.
LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW ...
? 5:29
www.youtube.com/watch?v=PWoz_-3OHIMJan 25, 2013 - Uploaded by Tampatec I have a LG 42PM4700-UB plasma tv that just went black. The red power .... I have a RCA 32 inch it has no sound or picture !Just a light blue ...
Picture Color
http://www.partstore.com/ModelDetai...close=1&exact=1
What do you think "CRT ASSY, Projection: Blue" might be?
CRT ASSY, PROJECTION: BLUE
RCA Part Number: 258486
RCA Model: D52W20
52" CRT BLUE P16LTG00BMB, DELTA 250
They want $183,
Top RCA Televison & Video Experts
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
