Question about Denon Audio Players & Recorders
I just received my new Denon AVR- x3600h 120V from amazon. When powering the receiver the power switch light is off no indication that the power supply is powering the unit. The voltage at the power cable is 120V tested be AV meter. I am worried that this unit was powered by another purchaser with 220 v before it was sold to me. If this is the case what can I do to repair it or check it etc as resending to USA is costly as I live in Saudi Arabia many thanks
Posted by hassan chahine on
5 Related Answers
Anonymous
SOURCE: avr receiver
I had same problem with my denon avr 1601.I have fixed it by myself by favour of Haapy Yogy. Thank you.
Posted on Feb 19, 2008
Rob Galayda
  • 54 Answers
SOURCE: Denon AVR-1601
This is a very common problem with denon receivers of the 2001-2-3 vintage. On almost every one, there are 4 little "surge" resistors in the power supply. These werent quite robust enough from the factory and one day would just burn open for no reason. Well, actually there is a reason, the "surge" that happens every time you power the unit up eventually weakens the resistors and then they pop. You need to take this to a denon service shop as I GUARANTEE they have seen this before. They need to check resistors in the picture, locarde above the **** rectangular connector. Resistors numbers R141, 142, 148, 149: 75f69d7.jpg These resistors when measured, should be less than 10 ohms each. If they are more, then they are blown. If they are blown, then have the shop check the channels for blown output transistors. If the outputs are OK, then these resistors should be replaced with 1 ohm 1/2 watt metal -film flameproof resistors. You might need to be prepared for a large bill, because the entire unit must come apart to replace the resistors, however, just checking them takes only about 10 minutes... Good luck and don't try this at home. Rob
Posted on Apr 08, 2008
Anonymous
  • 624 Answers
SOURCE: Denon AVR-1907 blinking red power button
It sounds like you have a bad speaker on the zone 2, or you have the speakers connected improperly.
When you engage the zone 2 a relay clicks and the speakers then become part of the amplifiers circuit.
If the problem was in the amplifier, it would go into protect mode without even having speakers connected to it.
If the speakers all check good, you most likely have the wrong type of speakers, meaning the impeadance is too low, or you have too many speakers connected to it.
On the back of the Denon, you will see right around the speaker output jacks, what ratings the speakers should be. If I remember correctly, it says 6 ohms or more when using only "A" or "B", and it says 12ohms or more for "A" + "B".
If you have two 8 ohm speakers on the same speaker jack you now have a 4 ohm load. That is below the ratings and can cause the amp to shut down (go into protect). Since your amp shuts down right away, I think you have a bad speaker or way too many speakers connected.
I have seen many times when people will connect 2 or 4 speakers to the one of the outputs that are designed for only 1 speakers.
If you are using too many speakers you will need a speaker distribution box. It has a resistor network built into it so the amp never sees a lower impeadance than what it is designed for.
You can connect 4, 6 or 8 speakers to one set of outputs designed for 2 speakers. You do loose a lot of power to the speakers, but it is better than blowing up your amplifier.
If I can be of any further help, let me know.
Posted on Jun 22, 2008
Anonymous
SOURCE: No code for Denon AVR-788 receiver remote through Cox cable.
Denon AVR - 788
Code for DirecTV remote RC64
The code I have found for this one is 31360 and maybe 31104.
Posted on Jul 30, 2009
Seamus377
  • 99 Answers
SOURCE: Denon AVR-683 won't stay on
replace all the electrolytic capacitors in the power supply. i had the exact same problem with mine and once i replaced the capacitors it powered up and stayed on and worked perfect.
these capacitors tend to fail as they're of poor quality.
this fault is very common on denon receivers, especially the later models.
hope this helps?
Posted on Jul 27, 2010
My Denon AVR-75 seems to stay in standby (red standby light is on) and I don'd get surround sound through it. How do I get it out of standby?
if the receiver does not power on from standby there is a problem like bad power supply or even bad macroprocessor. You need to bring it to a service center for diagnosing. 10-years old receiver, maybe better to buy new one.
Nov 23, 2011 | Denon AVR-75
My subwoofer is connected correctly (test mode it works fine). The Denon 589 receiver, however, when everything is set up and ready to go, doesnt seem to send any output to it, so there is no base sound. ...
What's the make and model of the subwoofer? It sounds like it's a passive (unpowered) speaker.
http://www.retrevo.com/support/Denon-AVR-589-Receivers-manual/id/23110dj893/t/2/
See page 9
I seriously doubt your test mode worked fine on the subwoofer level adjustmnent.
Get a powered (active) sub.
Jan 18, 2011 | Denon AVR-589 Receiver
Stand by /on led lights up but that is it. Click sound when ON is pushed. It is like it won't power up. Took off cover two fuses inside appear fine.
Check the main power transformer.
ohm out the primary side should be about 2 ohms. and check for 120v ac when you power it on.
If 120v is present on the primary side check for ac on the secondary. if none you need to replace the tranformer.
If it doesn't have 120v ac on the primary there is an open fuse or bad solder connection.
If you find an open fuse check for a shorted output transistor pair.
good luck
Nov 09, 2009 | Denon AVR-1803 Receiver
Shuts off then red light indicator flashes, disconnected all speakers but still wont work
Hi, this is a power board issue. remove the cover and make sure that this unit doesn't have blow fuse. if the fuse is fine, you will then need to replace the integrated power/ main board.
May 21, 2009 | Denon AVR-1803 Receiver
When Denon AVR-5803 Is powered on, it's making a clicking sound
Some of these unit have a dimmer for the display however this doesn't sound like your problem, I sure your unit is going bad. needs repair
Jan 24, 2009 | Denon AVR-5803 Receiver
Denon AVR-487 power issue
hello my friend denon receivers are famous for the power problem, check all the connections first and if there is not solution your power supply has a problem
good luck
[email protected]
Oct 28, 2008 | Denon AVR-4800 Receiver
Denon RC-978 remote... every button shuts receiver off
Drop the front panel of your receiver,there is ZONE 2 ON/OFF switch.
Good day!
solutiondoct
Sep 12, 2008 | Denon AVR-2807 Receiver
Denon avr-2106 problem!!!
You're drawing too much power from it. Sounds like maybe your sub is hooked up wrong, double check that.
Mar 06, 2008 | Denon AVR-2106 Receiver
99 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
