Question about Rancilio Coffee Makers & Espresso Machines
Rancilio Silva started leaking, and now no longer heats the water. I've got details in the description below. I'm seeking a repair, I'm assuming some new parts? Please help diagnose!
Posted by Jefferson on
5 Related Answers
bansheracer
  • 1089 Answers
SOURCE: 5 year old Rancilio Silva with no heating of water
Hi
Do an ohms check on the element. With an ohms meter check the reading between the elements. The reading should be between 12 and 16 ohms for a 110v machine and 50 to 60 for a 220v machine. If you have no reading or a higher reading you have a bad element.
Replace the boiler
Posted on Jul 24, 2009
wfservices
Wayne Fellows
  • 262 Answers
SOURCE: Yellow light flashes, colored water leaks. Assume
If the water is reddish or black looking the iron insides may be rusted out, and is bad enough that the seal has been compromised. This happens if water is left in iron when storing. If the iron is still warrantied return it to the store where it was purchased, or buy a new one.
Posted on Feb 21, 2010
Anonymous
  • 4 Answers
SOURCE: No Heat
I disagree... I think its the thermostat reset switch. A little red button once you open up the machine. look towards the front of the boiler and bush the button. Same thing happened to my Rancilio Silvia.... I opened it up, hit the reset switch... and voila! Working again! Here's the YouTube Video on the details. http://www.youtube.com/watch?v=zQdJNm9RV68
Posted on Jul 29, 2010
EsWorld
Ernest R
  • 1618 Answers
SOURCE: Rancilio Silva, after working well
Remove the 4 screws on the top panel. Make sure machine is not connected to power. Check the thermostats on the boiler, there should be 3 of them, push in on the small red pin in the middle of them one of them should click in. Now fill up your tank plug machine in and turn on.
Posted on Oct 20, 2010
Anonymous
  • 3911 Answers
SOURCE: 2006 GMC Yucon Denali XL driver and passenger
Get yourself a repair manual on ebay, they cost less than a tank of gas. If the dealer told you which part is bad, then have him order it for you, this is not going to be a parts store item. This is a really common problem, like sitting on a toaster or electric blanket that you keep outside and use every day.
Anything that gets hot and cold over and over is going to get brittle and break.
Posted on Dec 12, 2010
When I run water through my Rancilio Silva it comes out milky. Why?
Rinse the machine with Baking Soda solution (2 to 4 quarts).
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Dec 25, 2016 | Rancilio Coffee Makers & Espresso Machines
Rancilio Silva, after working well for three years, does not heat water when powered on. Suspect heating element bad. But is there a step I can take prior to replacing elements. Also, where can I get...
Oct 20, 2010 | Rancilio Silvia Espresso Machine
Hi
Replace the boiler
Jul 24, 2009 | Rancilio Silvia Espresso Machine
Iam looking for a less expensive grinder to use with my Rancilio Silva. Is there one?
My local coffee specialist suggested a sunbeam conical cafe series grinder. He sells a lot of the Rancilio Sylvia machines and recommends the sunbeam to go with them. Retails at $219. Just bought one and very pleased with it.
May 06, 2009 | Rancilio Silvia Espresso Machine
No Heat
Jan 23, 2009 | Rancilio Silvia Espresso Machine
Super hot water out of the group head on my Rancilio Sylvia
My Rancilio Silva is not making the water or steam hot anymore. Is it fairly easy to replace the heating element?
Dec 29, 2008 | Rancilio Silvia Espresso Machine
Rancilio class 6 E compact authomatic spilling water
  1. check the solenoid valve and electronic comand for boiler filing. solenoid valve could be leaking, electronic part could have weak contact with level detector wire or relay (driver of solenoid valve and motor) has bad contacts, and does not open circuit circuit remains all the time closed.
  2. check the presurestat, be sure that he opens cirquit at 1.5 bar snd does not angage heating element to heat up more.
Aug 13, 2008 | Rancilio S24 Espresso Machine
New Rancilio Silva - steamed milk not perfect
please relay on your experience realizing that you now have new steam pipe(with different holes in the end of it and different pressure)
you will need to get use to them and get maximum quality of that steam pipe.
my advice:
  1. every time hold your hand in the bottom of milk container, so that you will prevent overheating which often gives the result you mentioned.
  2. every time you use cold milk.
Jul 22, 2008 | Rancilio Silvia Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Rancilio Coffee Makers & Espresso Machines Experts
Lawrence Oravetz
ray gallant
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
