Alarm sound going off when plugged in. Tried unplugging and plugging back in several times
5 Suggested Answers
Anonymous
  • 4 Answers
SOURCE: set time
Slide the switch with a lock, wake 1, wake 2 and clock to the clock position. Using the backwards and forwards buttons get time to the correct time. When correct time is reached, slide the switch to the lock position. Time will now be set.
Manual can be found in PDF form from RCA here: http://support.rcaaudiovideo.com/Downloads.ashx?prodid=56&mediaid=620&force=true&file=products/RP5430/media/RP5430_UMEN.pdf
Posted on Jul 14, 2008
Anonymous
SOURCE: After a power failure, Wii will not turn on - I
Really common problem, but it's just a security feature. Unplug the Wii completely, wait 5 minutes, and it should work again. Has to go through something called a Power Cycle. I live in Florida, so it's happened to me twice...lots of lightning here.
Posted on Jun 17, 2009
Anonymous
SOURCE: LCD TV takes a long time to turn on
Its a common problem with many Samsung LCD TVs. We had the same problem on our Samsung TV. Based on some info on the net we called Samsung Support department ( 1-800-SAMSUNG). After describing the problem and mentioning that I have read on the net that its a common problem, representative asked for the model number and serial number of the TV ( I read them to her from a sticker on the side of TV). The Samsung Rep acknowledged that it was a common problem for my model and few other LCD models and they were fixing the problem without any charge to customer eve though TVwas out of warranty. She took the required info and gave me the ticket/transaction number and forwarded it to a local technician. Technician called next day and setup the appointment with us. Technician came within the 4 hr window that he had promised and changed the faulty capacitor on the power board and was done within 10 mins. Samsung rep had indicated that the technician will determine if the issue was with capacitor or not. If the issue was something else then tecnician will charge the regular service charge to fix the issue.
Posted on Jun 30, 2010
walterkunesk
Wally Bald Guy
  • 683 Answers
SOURCE: I have a samsung fridge
http://www.usersmanualguide.com/samsung/refrigerator__top_freezer/page49
try this page and see if you can find what your looking for. let me know.
Posted on Feb 21, 2011
TyrantKing
SOURCE: No sound at all on
Just fixed this on my TV today! (after 2 months of the sound intermittently failing to turn on and failing completely yesterday) Go to Mitsubishi-tv.com. Go to support. Enter your model number. You will be directed to the documentation for your model which will include a zip file for a firmware update and a PDF file with instructions for installing the update. This fixed my sound.
Posted on Apr 12, 2011
I have an Orbit 4 station timer, I've tried to reset / program several times. The problem is it repeats each station 2 times.
sounds like you have multiple start times. unplug, remove battery after 5 minutes plug transformer back in and install battery. If unit is ne return it
May 30, 2017 | Orbit Hardware & Accessories
Sony rear proj tv, no picture, menu appears, but in three seperated colors pin cushioned.
Best to first if you have not done so---UNPLUG the set for several minutes and plug back to power to see if that fixes it (it does a lot of the time especially if you had a power outage).
Nov 30, 2012 | Sony Televison & Video
No sound at all on Mitsubishi LT-52151. Fixed before by unplugging, waiting 30 seconds, plugging back in. Was occurring more and more often to the point of having to do this every time I would turn it on....
Mar 02, 2011 | Mitsubishi LT-52151 52 in. LCD HDTV
I opened the trunk to my 91 190 benz and the from and back ligts came on blinking. I can't close the trunk door and my car won't start. I think the battery died too because of the lights. I also already...
sounds like the alarm was set and when you opened the trunk it activated the alarm system, seems you got no sound though.
you can go to the drivers door, lock the car up even when the trunk open, then unlock it might have to do it several times. this will reset the alarm
Aug 28, 2010 | 1991 Mercedes-Benz 190
I just bought a mercedes 420 sel 1986, can not get a hold of the seller is there a trick to start the car, we tried earlier and set off the alarm, tried to start again, but it wont start afraid of setting...
Hey ther, If have not found an answer try this.
On the pass side of the remove the floor mat/carpet under the carpet you will see a black panel, remove the panel and there you will see several modules the secutiry modules is closet to the center console on it you will see two connector large one at the to unplug it and a small one at the bottom unplug it this will turn off the alarm system.
To start the car you may need to put the car in neutral and back in park the sensor is may be going bad. try starting the car.
if you want to keep alarm system you will need to by a new module this should fix your problem.
May 02, 2010 | 1991 Mercedes-Benz 420
Sounds like an alarm going off
Have you tried to unplug the unit...wait a few minutes and plug it back in?
Apr 23, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I bought A 65" Mits and had it two days approx. 2hrs. of run time
check the lamp. it sounds like it failed. you will probably see the broken glass inside the lamp housing
Jan 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
GES050 SPACESAVER CD PLAYER/RADIO ALARM
I haven't tried this yet, but I see online that WHILE it is ringing, unplug it for at least 20 secconds, and then plug back in.
Keep your fingers crossed!
Dec 30, 2007 | Audio Players & Recorders
Sharp Air Conditioner
This is from Sharp's website...apparently an addendum to the instruction booklet. When you get E1:
Unplug. Press and keep pressing the On/Off button on the unit. Plug unit back in. Wait until unit beeps (about 5 seconds) then release On/Off button. Unplug unit. Plug unit back in.
You're good to go.
Sep 04, 2007 | Sharp AF-S120FX Air Conditioner
Ekse
 Grubhead
Grubhead
