Question about LG Refrigerators
I have a LG LSC27931SW/04 refrigerator looking a water filter, I haven't got any warning to change water filter, I've had this unit for quite while
Posted by Fred Spanier on
STEVE
    Top Expert:
  • LG Master
  • 34,902 Answers
Most dont have any alarm to tell you a new filters needed. change it once a year..amazon sells them all
Posted on Jan 19, 2020
ray gallant
    Top Expert:
  • LG Master
  • 67,013 Answers
CHECK WITH MANUFACTURER
5 Related Answers
Anonymous
SOURCE: Water filter warning light
Push the light - it will flash red after a few seconds -then turn green.
The answer above on this page was correct
Posted on Oct 14, 2009
aasc
Mike Smith
  • 1606 Answers
SOURCE: Our water dispenser on our GE side by side
At the bottom of the freezer door ( remove the kick plate , 1 screw on each side ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
If the water line in door is frozen , GE has a heater kit , pt # WR49X10173 , for this particular problem . It comes , with installation instructions .
Posted on Jan 01, 2010
Testimonial: "We will try this! Thank you!"
Anonymous
SOURCE: Where to get bypass plug/cap for LG Refrigerator
i totally aggree bypass the built-in filter on the lg and get a universal in line filter, do the math it all most cheaper to buy bottaled water all the same taste- u still change filer every 6 months but it's 10- year not 70 - 100- ,get real....
Posted on Apr 27, 2010
burdfrenzy
Joe Burdek
  • 348 Answers
SOURCE: Water flow of filter too slow
When was the last time you changed the water filter? If the filter is clogged from long usage it will slow down the water flow. Filters should be changed 6-12 months.
Posted on Jul 11, 2010
toolkits
Sanyade Akinwale
  • 1099 Answers
SOURCE: how to replace the filter
Take the new water filter out of the box and remove the two red shipping caps on the end of the filter.
The water filter is located on the front panel down near the floor.
Push the release button located just to the left of the water filter grille cap, this will release the filter.
Remove the grille cap from the filter by twisting it counterclockwise.
Reinstall the grille cap on the new water filter.
Insert the new water filter in the refrigerator making sure the words on the filter are the correct side up.
Push the water filter in until it clicks in place.
Flush Water After Installing New Filter
Be sure you flush out the water from the new filter after you replace it! Many readers are having trouble with airlocks because they are skipping this important step. Kenmore recommends you run the water out of the water and ice maker for a few minutes to flush out the new filter. This also helps remove air bubbles from the system. If you don’t do this it’s possible that the water dispenser may not work properly due to an air lock.
This particular water filter claims to reduce:
Cysts and turbidity – linked to gastrointestinal problems
Lead
Chlorine – taste and odor for better tasting water
Sediment – for clearer water
o-Dichlorobenzene – linked to risk of liver, kidney, or circulatory system problems
Benzene – linked to increase risk of cancer and anemia.
Note continue changing the filter on a regular basis.
Hope this helpout....
Posted on Aug 01, 2010
How do I buy and replace the water filter on my fridgeGWL207FBQA?
In a nut shell this is how to do it:
Find the water filter housing in the top area of the Refrigerator. Remove the cap/cover (turn left). Remove the old and install the new filter (turn it to the right to lock it in place). Re-install the cover and drain 2 gallons to flush the system.
Here's what the maker says: (look about 1/4 down the page until you see "Changing your LG REFRIGERATOR's Water Filter" and follow the steps. http://www.lg.com/us/support/answers/refrigerators/scheduled-maintenance
The filter number is 5231JA2006. Costs about $50 (check eBay or Amazon). Or here at LG http://www.lg.com/us/appliance-accessories/lg-LT600P-water-filter
Hope this helps...
Jan 10, 2015 | Refrigerators
How do I fix the water dispenser on my LG refrigerator?
#1 cause is the water filter. There may be other blockages in the line. Change the filter one more time and allow the air to purge out of the line. You will make a mess.
Nov 12, 2014 | LG LSC27910TT (265 cu ft) Side by Side...
Ice Maker works but water dispenser doesn't
The solenoid valve is located where the water line connects to the fridge. There is a micro switch that the paddle in the door operates when you push a glass against it. Sometimes the plastic locating pin that holds the switch in position breaks and allows the switch to move away from the actuating lever.
Aug 26, 2017 | LG Refrigerators
Where do I find the filter that needs to be changed
Hi
There are two types of water filter fitted to this model they are both located in the top right hand corner of the refrigerator section.
1. The standard water filter looks like an upturned bowl, to change this you need to unplug and switch off the unit, turn off the water supply and unscrew the filter around 1/4 turn anticlockwise.
Replace the filter and tighten the bowl checking that the O rings are in place. You may make a bit of a mess with water dripping out as you remove the filter bowl. These can be quite stubborn if they have not been changed before.
2.Pure source filter is on the face of the unit next to the thermostat, again shut down the unit and turn off the water before removing the filter, there is a small button lower right on the face, when you press this the filter should pop out, again spilling some water.
It is vital that you prime the system properly before using the water or ice this means running at least 2 gallons of water out of the water valve on the front to make sure that all the air is out and that pure water is in the machine.
You manual is available at this link
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/241856000en.pdf
Hope this helps
Gordon
Apr 26, 2011 | Frigidaire FRS3R5EMB Side by Side...
Since changing filter have no water in door and no ice
usually there is a reset button on the fridge that needs to be pushed.you may also try and unplug the unit for a few minutes
May 19, 2010 | LG LSC26905TT Side by Side Refrigerator
is there a way to bypass the filter on a lg refrigrator?
Jan 07, 2010 | LG LFD21860ST Stainless Steel Bottom...
How do i remove the water filter
The filter will come out attached to the cover .. look inside the cavity . there should be a space there for the filter .. the ones at the top of the fridge are quite small compared to the ones that go at the bottom on some fridges. Most appliance or building supply stores will have replacement filters on hand .. have your make and model number to get the correct replacement., or the old filter ..
Feb 02, 2009 | LG LSC26905TT Side by Side Refrigerator
WAter dispenser stopped working
Change the filter in the refrigerator. ..just change it..
Is there something wrong with the kitchen faucet?..
drinking bottled water..??.. are you drinking ACID RAIN??.... think not...??
read this:
Acid Rain Students Site PH Scale
now read this..
Analyzing Comparing Brands of Bottled Water
Oct 11, 2017 | GE CleanSteel GSL25JFTBS
Refrigerators Logo
140 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
deecee73
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
