Question about Car Audio & Video
Is wiring harness plug in 16 pin same for KD -G335 and KD-G420
Posted by Byron Charles... on
5 Related Answers
Anonymous
  • 944 Answers
SOURCE: Setting Clock for JVC-KD-G420
Here is the link for the manual http://books.jvcservice.com/download/289413083/38360.pdf page 7 Hope this helps :)
Posted on Mar 17, 2007
Anonymous
SOURCE: cannot set clock on my JVC KD-G335
You need to hold the sel button down for a little while then it will change displays thats when you use youe right seek button until you hit the Clock H to change the clock hour or Clock M to change the minutes when you hit it you use your volume control button to change the time.
Posted on Jan 18, 2009
Philip Armitage
  • 437 Answers
SOURCE: i dont have a wiring diagram for the 16 pin plug
red -Acc power
yellow -12 memory power
black -ground
blue -amplifier remote
blue/white -power antenna
SPEAKERS
white left front +
white/black left front -
grey right front +
grey/black right front -
green left rear +
green/black left rear
purple right rear +
purple/black right rear -
Posted on Aug 25, 2009
Rob C
  • 547 Answers
SOURCE: Problems with Metra METRA PR01-0001 PIONEER 16-PIN UNIVERSAL WIRING HARNESS?which wires are which
I don't know what pins are what on the METRA harness, but the wires coming from the back of the Pioneer unit should be:
black ground
red accessory (KEY)
yellow memory constant power,
blue is remote,
orange is for the dimmer,
green with black is left rear neg.and green is positive,
violet black is right rear negative and violet is positive,
white is left front positive and white with black is negative,
gray black is right front negative and gray is positive.
If you don't have the pioneer harness (and so these wire colors dont' mean much to you) just message back here, and I'll map those wire colors to pin positions on the back of the unit.
Posted on Oct 02, 2009
Anonymous
  • 20 Answers
SOURCE: I have an old clarion DRB5176 cd player but i got
there is one on ebay at this link below 7.99 http://cgi.ebay.com/CLARION-16-pin-wire-WIRING-Harness-DRB4375-DRX8175-cl6-/200330020811
Posted on Mar 04, 2010
I have a power issue display will light up cd will go in and out ,but cannot get unit to come on? (jvc kd-g420 )
It's likely wired wrong - if this is a new unit.
Did you install yourself?
Is it new?
Did you use a wiring harness?
CHECK THIS TIP for general wiring tips.
let me know if you have additional questions.
Thanks!
Nov 27, 2010 | JVC KD-G420 CD Player
I WOULD LIKE TO OBTAIN A INSTRUCTIONS MANUEL FOR A JVC KD G420 EITHER DOWNLOAD OR GET A COPY OF MANUEL [email protected]
You can obtain the manual here, scroll down on the page, and give an email and enter the letters. The manual is free.
http://www.retrevo.com/support/JVC-KD-G420J-Car-Receivers-manual/id/989ci952/t/2/
Don't forget to vote
Oct 12, 2010 | JVC KD-G420 CD Player
Need wiring diagram for plug on back of jvc kdg420
Visit books.jvc.com
http://books.jvc.com/booklist.asp?Model=kd-g420
Download the installation manual for free
Feb 28, 2010 | JVC KD-G420 CD Player
Looking to put remote start and bypass module in 2007 saturn vue need wiring diagram
12 VOLT CONSTANT ORANGE (+) IGNITION SWITCH HARNESS STARTER YELLOW(+) IGNITION SWITCH HARNESS STARTER 2 N/A IGNITION 1 PINK(+) IGNITION SWITCH HARNESS IGNITION 2 N/A IGNITION 3 N/A ACCESSORY/HEATER BLOWER 1 ORANGE (+) IGNITION SWITCH HARNESS ACCESSORY/HEATER BLOWER 2 N/A KEYSENSE LIGHT GREEN (-) See NOTE *1 IGNITION SWITCH HARNESS PARKING LIGHTS ( - ) N/A PARKING LIGHTS ( + ) BROWN (+) @ BCM, PIN B10, GRAY 24-PIN PLUG, See NOTE *2 POWER LOCK RED/BLACK (TYPE A) @ BCM, PIN A8, 16-PIN GRAY PLUG, See NOTE *2 POWER UNLOCK ORANGE/BLACK (TYPE A) @ BCM, PIN A7, 16-PIN GRAY PLUG, See NOTE *2 LOCK MOTOR WIRE GRAY (+) IN DRIVERS DOOR HARNESS DOOR TRIGGER See NOTE *3 @ BCM, PINK 24-PIN PLUG, See NOTE *2 8957_VUE_(-) NEGATIVE DOOR PIN ISOLATION CIRCUIT.pdf DOMELIGHT SUPERVISION WHITE (-) @ BCM, PINK 24-PIN PLUG, PIN A1, See NOTE *2 TRUNK RELEASE N/A SLIDING POWER DOOR N/A HORN BLACK (-) @ BCM, PIN B2, PINK 24-PIN PLUG, See NOTE *2 TACH ANY WIRE NOT PINK or RED @ IGNITION COIL WAIT TO START LIGHT N/A BRAKE LIGHT BLUE (+) @ SWITCH ABOVE BRAKE PEDAL FACTORY ALARM DISARM DISARMS with FACTORY REMOTE ONLY ANTI-THEFT YELLOW (+), ORANGE/BLACK (-) and RED/WHITE (Not used) GM's PASSLOCK 2 System, these wires exit the Ignition Switch Tumbler together and are in the Main Ignition Switch Harness in the Column.
Feb 27, 2010 | 2007 Saturn VUE FWD 4
Installing a cd player in a 1992 honda accord
The harness looks like what is depicted on this link: http://cgi.ebay.com/JVC--16-PIN-WIRE-HARNESS-FOR-CD-PLAYER-BLACK-BRAND-NEW_W0QQitemZ370214069143QQcmdZViewItemQQimsxZ20090612?IMSfp=TL090612198008r8862
This connector fits the following JVC Car Radio/CD/MP3 Players with 16 pin connection.
All wires are labeled.
Hope this helps....................sodeep
Jul 26, 2009 | JVC KD-G220 CD Player
Is jvc kd-g335 blue tooth compatable
If it is a "Ready for BlueTooth" model you will need this adapter JVC KS-BTA20
Jun 04, 2009 | JVC KD-G340 Car CD/ MP3 Player
Time setting
Here is the current link for the user/instilation manuals:
http://books.jvcservice.com/booklist.asp?Model=KD-G420
Try page 8 of users manual for clock.
Jan 19, 2008 | JVC KD-G420 CD Player
JVC KD-G420 in 2000 Toyota Tocoma
today's in-dash cd players are a 2 part mounting system. One part is the carrier chassis that is hard mounted to the dash. Then the cd player slides into part 1 and latches. To remove player from part 1, insert 2 long and narrow metal tools along each side to un-latch the player. The tools come with a new unit. To make these, try making them out of 1/16 inch thick metal and trimming to following dimensions: 6 inches long by 1/2 inch wide and at one end, narrow down to about 1/8 inch about 1 inch from the end. deburr all edges. This 2 part system is designed for anti-theft defense.
Aug 26, 2007 | JVC KD-G420 CD Player
Mar 17, 2007 | JVC KD-G420 CD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
